Visitor Agreement.
questions and I'm sure more qualified posters
could help you.
But, I also had a check engine light issue
w/ my 2000 OB @ about 8700k or so.
Well that a long story, but as long as your
car is under warranty and you have done all
you can with the gas cap suggestion, a service
check is in order.
It could be any number of things. Let the tech's
take a reading for the code ref. the ECU is
sending out.
Just a suggestion.
Every modern car (at least any gasoline engine one) sold in the USA (and probably Canada, and it leaks to foreign markets because of the size of the US market, but I am getting ahead of myself) has what is called the OBD-II engine computer codes. OBD-II is actually a government mandated standard, and it is considered part of the emissions control system. (OBD, by the way, stands for On Board Diagnostics, and II is just the roman numeral two.)
Of course, the emissions control system has lots of sensors and parts that try to make sure that the engine runs "efficiently", i.e., burns all the gasoline and puts out just plain CO2 + H2O, none of the nasty acid-rain components (sulfur and nitrogen oxides), no ozone, no smog components (unburnt hydrocarbons), etc. To do its job, all those sensors have to be working properly. The gas cap is also part of the emissions control system, because if the gas cap is loose or missing, gasoline can evaporate right from the tank, putting lots of completely unburnt hydrocarbons in the air.
Now, when you take your car in for a smog check, it might need to be inspected by a poor minimum-wage slob who once had 30 minutes of instruction to use some government-mandated bit of emissions-testing equipment, and that is about it. So, in order to get their money's worth from this guy, the government folks figured: why not have each car diagnose itself? They can tell the guy: "You must look at the check engine light. If it is on, the car fails." Then they just have to make sure that the light catches most emissions problems.
To catch such problems, the light will come on if a sensor glitches. It will then stay on unless and until it is (a) reset by someone using appropriate equipment, or (b) the glitch goes away and stays away through some minimum number of self-test cycles.
The exact details of the self-tests that have to pass to clear any current "check" condition are either some big secret, or just not well known. Or at least, I have not found a list of them anywhere. They appear to include some minimum number of cold starts, warm starts, travel at low speeds, travel at high speeds, etc. For all I know you have to turn the radio off and on too. :-) Seriously, though, if all is well -- such as, if the gas cap was loose and is now tight -- there is some set of conditions after which OBD-II will have passed its required `all is well' tests and the light will go out again.
UNFORTUNATELY, given the one `something is wrong' light, everyone also uses it for more serious problems than `some sensor glitched for a moment' or `your gas cap is loose'. So the Right Thing To Do, when you have a check engine light, is to hook it up to a Check Engine Light Reader and find out why the light is on. The `reason' is a code indicating some part(s) giving back `funny readings', i.e., the engine computer's equivalent of `there's a funny noise coming from over there, kind of a squeeka-squeeka-clicka, when it's supposed to be a clicka-squeeka-plink!' Once you have read out the `reason', you can reset it, and see if the problem is still there, and you can decide how serious it is and how soon you want to take care of it.
You can find a list of OBD-II codes here. There are some portable readers you can buy for home use, although they are all kind of expensive, or you can just take it in to a shop that has the right kind of reader. Although OBD-II is `standard', the connectors are not, so you have to get one works with you particular car.
Chris
-juice
Any ideas about a less expensive source?
Norman
Hopefully Chilton's makes one. Try a Track Auto or Pep Boys near you.
I haven't needed one yet because nothing seems to break on these cars. Sorry to disappoint you!
-juice
Check out the Sube-Directory (get it?) for suppliers:
http://home.earthlink.net/~gndiamant/subaru.htm
and join us in the Mods topic for more details.
-juice
Thanks to everyone here for their sound advice. I wonder how many people have had the same issue with their oxygen sensor? I don't mind, since they fixed it for free, but it did cost me some time and inconvenience....
Thanks again for your post, Mike. Your info may very well help a fellow comrade.
..Mike (Smith)
..Mike
As a fyi, just about 2 weeks ago, the fuel injector on cylinder 1 also failed (leaving me stranded in the middle of nowhere).
There's another reader on these boards who has had the same problems as me - but I'm making a hypothesis, that these problems plague a good percentage of the '00 model year Outbacks, and that other people will continue to see them, unless Subaru starts ironing out the bugs.
-- ash
I'm planning to buy a '97 Legacy L wagon
that still has almost 2 years or 22k miles
left on Subaru's 5year/60k mile powertrain
warranty. Theoretically. Can someone tell
me whether Subaru will honor the warranty
despite the fact that I'm not the original
owner? This will be a critical factor for
me in buying the car, and your quick response
is much appreciated! -- Dave
A little tighter than snug.
Dave
Subarus in particular used to be famous for a little trick where the head gasket would fail allowing coolant into the combustion chamber. When the car was running the coolant would be seen as steam or "white smoke" in the exhaust. The funny thing would be when the car was not running; coolant would fill one of the combustion chambers, and when the hapless owner tried to start the car it would not even turn over. Water will not compress like air! We used to get the strangest diagnoses on those - everything from "battery too weak" to "starter motor failure" to "bent crankshaft". Then we'd pop a sparkplug out and the coolant would tinkle out onto the ground. Ah-ha.
The only thing I can think of is what I'm going to categorize as a WAG (wild-a$$ed guess). If your car is turbocharged it might be possible that somewhere along the induction path there is a leak into the cooling system, and the pressure of the turbo is enough to force some of the unburned air/fuel mixture into the cooling system.
Ask the mechanic who discovered it, and make damned sure it's a reputable place. And let us know what it turned out to be!
Good luck,
WDB
..Mike
..Mike
Dave
My last call was to the dealership where the work was done and spoke with a different service advisor. He had more time today to explain what the problem MIGHT be and talked with me about whether or not to worry too much about it.
calen
I got the feeling that it is something I don't really have to worry about but I should certainly keep an eye on the coolant level. I also checked the overflow tank for bubbles while the car was running and thankfully there were no bubbles.
Thanks again for your help!
Chris
Sonny: I'd check in three places: the driver's side door jamb, the label under the hood, and in the owner's manual. Those specs are bound to be in one of those three places. You usually see tire pressures and spark plug gaps in those places too.
Subee1: try visiting a dealer and drive a similar model. Does the engine revving sound similar? Soobs have a characteristic boxer sound to them, very different than other cars.
Also, is the tranny an automatic? If so, I'd have the dealer check it out. Leave it overnight if you have to, since perhaps the problem only pops up when the car is cold.
-juice
Only the 2000 models have had problems. Bad batch.
lug nut torque-
aluminum wheels means 65-80 ft-lb. I'd set 70 personally, and recheck in a week.
warranties-
fully transferable.
-Colin
Dave
I never noticed this "fan" thing before...is this normal? Any ideas? Appreciate any advice.
..Mike
..Mike
the engine is cold going around a corner. The car
only has 300 miles so far, so I'm still checking
if its only when the engine is cold or all the time. Should I take it back to the dealer?, or
is this normal on the 2.2 auto?
What I am interested in is, The titles of the manuals and the prices QSubaru charges.
John
-juice
interior tailgate panel coming loose after one
month of ownership.<<
Hmmm. They need to take a close look at the interior panel supplier. The only thing that's gone wrong with my 00 Legacy L Wagon is the drivers door interior panel was warped and wouldn't stay secured! Just had the new one installed today. And likewise, other than that, it's been great.
Dave
Hopefully they'll collect the feedback and do some extra QC before delivery.
-juice
Anyone know, did the thread move somewhere else?
Mary
My advice is to do a thorough pre-delivery inspection. Test drive the exact car you will buy. Inspect the interior for tight fit and finish, try all doors and latches, check the paint for orange peel finish, and drive it in varying conditions to check the accelerator's response, the braking, and the handling.
-juice
I own a 2000 Outback Ltd, which I love.
One of the weird things that I've noticed with this car is a loud occasional whistling noise coming from the driver side window. This isn't the infamous 'mirror noise' tossed around a while back. This noise only happens when there is a gust of wind across the car that causes a large pressure difference between the inside and the outside of the car. The pressure difference appears to make the driver side window 'lift' away from the door causing a short blast of noise. It only happens to the driver side door, and only when the wind is very strong. I noticed it on a long drive through the country side in windy weather. It has never happened in the city.
Any ideas what's up? Does anybody else get this? It's not super annoying, because it only happens rarely, but it would be -very- tough to reproduce for the dealer to fix.
Mike
I'm not sure that I understood your description completely, but I have heard increased wind noise in my Impreza during really severe wind-- good old 60-80 MPH stuff here in Kansas.
In my case it's just the top of the window being unable to seal against extreme conditions.
-Colin
Yeah, that's what I mean. It's not a continuous whistling, but a short burst of noise/air, and it does seem to come out of the top of the window. It makes sense that this is the result of frameless windows. But why does it happen only on the driver's side window, not the passenger side or on the two rear windows?
Mike
Why would someone want a tailpipe extender--is it just flash or does it serve a purpose?
Mary
Besides replacing it, I'm reaching.
-Colin
Some examples, last month they overfilled the oil.( Up above the upper twisted part on the dip stick!)
I think this is unexcusable. I also, have problems with my radiator cooling fans cycling on and off at start up. On two service visits, they've been unable to duplicate the symptom, therefore believe it's OK. There's more, but basically they don't listen and tend to our needs.
Curious, I asked the service manager if he or any of the mechanics drive Subaru cars. None of them do. I really don't expect any mechanic to have the Subaru driving knowledge we have unless they are in one everyday. Not that they aren't good mechanics and attentive to Subaru knowledge. Yet, I think a mechanic driving a Subaru would know all the little quirks, squeaks and detailed problems we so patiently seek to solve with our new Subarus.
We've invested a good portion of our income in our new OB. I would hope that the dealer service center at least invest the same and greater into the education and training of their service mechanics and related personnel.
Any recommendations would be greatly appreciated.
CJ
I live in the SF Bay Area and have had a good experience with Diablo Auto in Walnut Creek, but have been doing most of my own maintenance. I brought mine in only to check out a "check engine" light glitch that was perhaps (guessing here) merely due to strong wind combined with high speed highway travel in the Arizona desert. (Code #P0107, "intake manifold air flow sensor low", light went away before I could get the car in, no apparent fault in the air intake or sensors.)
Chris
Exlemonowner
Karen
I'm sure all the club members will find
this information useful.
At 9k on my Outback, I experienced a
problem with my ECU which caused me some
difficulty. I too thought the SoA was the
party dragging their feet.
I've now have 14k,and its still like new.
without even a hint of a problem.
I too think Juice gives some good advice on
these boards. I've been able to put to
use some of his pointers.
Let us know when you get your new Subie. K.
later
