Subaru Crew - Meet The Members
1232426282958
  • subaru_teamsubaru_team Member Posts: 1,676
    Hi Mike!
    I think a lot of it is perception (based on what our tech. group has advised). Once again, as a reminder to all, if it is something that you find troublesome, your dealer has access to information that can change the perception but will not affect braking performance.
    Patti
  • Hi Patti,
    I agree that it's mostly a perception issue (which is why I put "soft" in quotes), which will vary among drivers. Personally, I don't find the 91 L or 00 GT brake feel much different than my 93 Civic. Thanks for the reminder about what the dealer can do; I'd forgotten about that.
    ..Mike
  • lucien2lucien2 Member Posts: 2,984
    I nailed the threshold braking exercise in the OB at driving school three passes out of 5 (twice the ABS jumped in). Suffice to say, I had no shrift with the brakes!! :)
  • dsackmandsackman Member Posts: 145
    Patti,
    Do you have a reference to the information the dealer has to change the perception of the soft brake feel? Is there a service bulletin number or something like that?
    I am taking my Forester for its 3,000 mile service and need this perception changed desperately.
    Thanks for all your assistance and care.
    Daniel
  • kate5000kate5000 Member Posts: 1,271
    I put 600+ miles on the Forester over weekend, mostly on the twisty roads in Sierras. I should say I'm very impressed with the power: the only thing that held me back on the twisties were some slow-dragging Explorers or Tahoes and I had to wait for a passing lane, to leave them in the dust. I had 2 passengers and A/C on all the time.
    I was anxiously awaiting H6 in the Forester line, but now started wondering: do we really need H6? So far, I had no problems with outrunning anyone on the uphill or freeway merging (that cannot be said about my old Loyale and husband's Accord). Of course, if we towed something that would be a different story.
    I'm also very impressed with A/C: it was 57-97 (depending on elevation) outside, and A/C kept us all nicely cool running at the minimum setting.
    Sound is so-so. I should have opted for premium sound, or I should look into the automarket. Bass is OK, but there's something funky with the treble. Oh well, you cannot have everything, right?
    Strange thing: after going uphill almost all the time (0 - 10000 ft), on the twisty roads, my mileage was exactly the same as for the flat freeway driving: 22.8 mpg. Both old Loyale and Accord usually do about 30% worse in the mountains.
  • locke2clocke2c Member Posts: 5,038
    There was a TSB on some Legacy trims about the
    master cylinder, if I recall correctly... Nothing
    that applied to your Forester though. The first
    thing to do is make sure the brakes are bled
    properly and fairly often --once per season would
    be ideal, once per year at bare minimum.
    After you are sure the fluid has no air or water
    in it, the pedal will have two distinct zones. For the first 1-2" of travel the pedal will be soft but the brakes will be grabbing. After that first distance, the pedal suddenly becomes firmer and you must apply a fair bit of force to attain maximum braking.
    I prefer a single stage brake booster, the pedal
    feels the same for the entire stroke. It's more
    difficult to modulate the brakes when the first
    1-2" requires little effort and the rest of the
    stroke requires a lot.
    -Colin
  • kenskens Member Posts: 5,869
    tlima -- Are you refering to the slight "rocking" when you're cranking the engine? I'm fairly certain that's normal. Every Forester I've driven has done that -- I attribute it to the horizontal layout of the engine. The engine shouldn't do this while idling.
    kyotz -- I've heard other owners mention the "soft" feel of the pedals. Like Colin mentioned, you can have the feel adjusted a bit. Rest assured, Subarus have better brakes than most vehicles in it's class. How many other models in the same price range get dual caliper, 4-channel ABS brakes? In fact the 2001 OB gets even larger front disc brakes.
    kate500 -- I agree that the H6 is not as big a necessity for the Forester as with the OB. I regularly go to Tahoe with a full load and the H4 does fine. What I'd like to see the Forester get the upcoming Impreza turbo engine. In fact, the FHI engineers who originally designed the Forester thought the EJ20 Turbo engine was the best match for what it was intended to do. Only the US got the 2.5L standard because they felt that US customers favored low-mid end torque.
  • c_hunterc_hunter Member Posts: 4,487
    If you don't have the tweeter kit, go for it -- it's the best (and easiest) way to improve treble response. High frequencies really get lost when coming from speakers in the bottom of the door, and tweeters can help quite a bit.
    Craig
    Hi Daniel! Check out post #24 for more details. Your dealer can find the information by contacting his technical helpline or ask him to call me and I can direct him/her to the right place.
    The information was provided to the dealers via a "technical tip" vs. a service bulletin (a more informal communication method.
    Ken beat me to it. He said everything I was going to say about the brakes. Just get a 2001 for the bigger rotors.
    Tony: congrats on the new purchase. I also have a Forester L.
    fido rs: welcome! I'm sure you'll be right at home in the Mods topic, we've been pretty active lately.
    Colin: the RS a "truck"? I was LOL.
    -juice
    First of all, a special thanks to Darlene from QSubaru for the free T-shirts at the SCOA meet in Gettysburg this past weekend. She supplied two dozen grey "Subaru Lifestyle Sports" heavyweight T-shirts, very nice! :)
    Sorry if you weren't able to attend, they flew away and I'm all out.
    Second, I'd like to point out what a class act Patti Mickel is for the wonderful catered basket full of goodies delivered to the same event! We truly appreciate your thoughtfullness! :)
    (psst: Tati loved the Oreos!)
    Finally, a special thanks to Garry Grimes, another class act, for putting the event together and inviting the Crew.
    Gettysburg is worth the drive. It was crowded! We had to fight to find enough parking spots to park in a group. We enjoyed the munchies, handed out T-shirts, and took a nice scenic bike ride around the battlefields.
    We also talked shop for quite a while. I met FrankMc from the Crew; always cool to put a face to a name.
    If anyone can attend the Fall Folliage Tour, I strongly recommend it. They'll have a Gimmick Rally and Tour, and it should be just as fun as Gettysburg.
    Hop over to the Events topic for more details.
    -juice
  • bat1161bat1161 Member Posts: 1,784
    Well, this past Saturday I finally did it. My wife and I went ahead and are in the process of buying a 2000 Outback Wagon from Staten Island Subaru, thanks in part to Mike(Paisan). We had originally went to look into the Forester, but as we were talking with the dealer he showed us an Outback 5spd that he has not been able to sell. To make a long story short, the dealer did right by us, and after a nice test drive we did the deal. He is now adding a couple of items and hopefully by this weekend I will be driving my first new car! (Just in time to drive down to Edmunds Live at Englishtown, NJ)
    I really want to thank everyone who has helped, especially Juice and Paisan. I know I asked a lot of questions, especially about the Forester, but after driving the Outback and working things out, this is best for me for now. Besides, I told my wife once she gets her license and feels comfortable driving I'll give her the Outback, and I will go for a new (Grand?)Forester! Mike thanks for coming down and introducing me to Mark in person. He is definitely a nice guy, easy to work with. No pressure and very inciteful.
    Patti for your wish list, how about variable interval wipers, front and back, on the Outback; and autodimming side view mirrors to go with the rear mirror.
    Sorry for the long post but I am excited and again , thanks all!
    Mark
    Juice, thanks for the SPT (Subaru Performance Tuning) stickers! Got them Saturday... hmm, maybe Friday as often as we check the mail.
    They'll be mounted on magnetic backing and I'll take some pictures at the next autocross this Sunday.
    -Colin
    I went the same way -- shopped for a Forester, hooked by an Outback. They're both great cars.
    Enjoy the ride!
    Craig
    Patti,
    You are the BEST!
    Thanks a lot to you and SUBARU. It is extremely refreshing to find a company that is dedicated to their clients in this manner.
    This is really appreciated.
    Thank you,
    Daniel
    was on certain legacys for a master cylinder replacement. To correct poor perfomance in temperatures below 20 degrees. FWIW.
    That brake recall also affected my Forester. Hey, a new brake master cylinder and a free brake-bleed job, fine with me!
    Mark: congrats. OBs and Foresters have a lot in common, to each his/her own!
    Edmunds Live in NJ? Hmm, how far is that? It was so fun I wouldn't mind going again. Seriously. How far is that from DC?
    Colin: call it a belated b-day gift. Hopefully the extra 5-6 horses stickers provide will help your lap times. ;)
    My web site has been updated with Gettysburg photos, plus some intake changes, and a few fun snow pics with Loosh. Check it out here.
    -juice
    Goes to show how much monitors have advanced; I figured 100dpi would be fine for a web page photo. Not bad I guess, but clearly I will send future stuff at a higher rez. Thanx!
    juice,
    I cracked up at that photo of the coffee can. Who's was that? Here's a cool tip: paint a "Type R" (the R *must* be a capital red) on it and it will add another 20HP. Amazing, but true.
    Ken
  • tlimatlima Member Posts: 124
    The shake is exactly as you describe - a rocking motion when cranking the engine. Once at idle, engine exhibits little to no vibration felt at the drivers seat.
    I also read in the owners manual (do people still read manuals?) that the A/C will shut down when certain loads (hills, acceleration, etc) are placed on the engine. This may have been what I felt on acceleration. I'll wait until after the break-in before I re-test any acceleration runs.
    -Tony
  • guxxguxx Member Posts: 33
    I bought my 2001 Forester S in June, with the new gold color, and I have only seen one other gold Forester as of yet! Usually, I drive past Foresters in white, green, and red. Only seen one other gold. Not sure if I've seen the blues either, come to think of it..
  • nypdaunypdau Member Posts: 38
    Finally got the VIN from the dealer; says my new Forester S in Blue Ridge Pearl should be 2-3 days behind the paperwork:) My Optilux bulbs are waiting, as are halogen back-up bulbs and some Zaino products. I visited the XPEL site after seeing some postings about pebble damage. Anyone have any experience with these clear 3M laminates?
    If the information on the site is accurate, they seem like a wise investment. On my darkish color blue,the film would be nearly invisible close-up.
    GPS Navigation: The Magellan unit looks fine, but I am planning on replacing my 6 y/o Garmin 95XL with the Garmin 295 color, it is an aviation unit that has street mapping capability. I've never used one in a vehicle, but handheld GPS units have come a long way and we use them for navigation on the ground at JFK for taxiway identification!
    Break in: Is the owners manual clear about break in procedures? On the same subject, how is the owners manual in general? Well written or will I need to ask Colin for advice every other day? :)
    Signed, Soon to join the Soob ranks!
    -James
    The AC does disengage under engine load. I had a Honda Civic that did this too. While the Subaru seems to go about it a little smoother, I still think it feels clumsy. When I turn the AC on, I would rather just have it stay on -- I usually adjust my driving habits when AC is on, and it's not too much of a problem. AC is pretty benign on the 2.5L boxer engine. Having it cycle on and off makes it obtrusive and annoying to me.
    Craig
  • armac13armac13 Member Posts: 1,129
    Mine's a gold 'S, but since I'm in Vancouver you probably haven't seen it around. Rufus is also a June baby.
    Ross
  • alingaling Member Posts: 598
    I live in Coquitlam and I haven't seen any gold Foresters around here either. Mostly green, red, silver, or the maybe black.
    Drew
  • teddy_bteddy_b Member Posts: 5
    Hello all, I am juice's brother, and I have now become a subaru(scooby-doo? :) fan.
    Just wanted to say that I had a good time at the gettysburg meet on Saturday, and that I hope I can find a way to go to the next one (or maybe Edmunds' Live!!).
    teddy_b
    P.S. I am also glad to be a new member of the town hall.
    That you are Juice's bro... You are stuck with him for life... J/K ;)
    Welcome aboard.
    -mike
    Juice,
    If you are interested these are the directions to the Englishtown location:
    FROM THE SOUTH
    New Jersey turnpike North to Exit 8 to Route 33 East. Go 8 miles to the Englishtown exit. Take Route 527 North. Go through Englishtown.
    Right onto Gordons Corner Road. Go 1/4 mile; make a left onto Pension Road. Go 2 miles, entrance on right.
    I hope to have my Outback on Friday so that I can still go Saturday with my wife. I am curious how this compares to the Jeep 101 we attended last year.
  • Jose, glad you made it to Gettysburg. I'm sorry I missed it; I was on vacation in Hingham, MA. Hope to meet you soon. Your brother is a genteel fellow and an automotive encyclopedia, to boot!
    Welcome aboard.
    ..Mike
    PS - LOL, paisan!
    strangely enough, is only available on the 'S (not the 'L or the Ltd.) here in the Great White North.May be one reason for its relative rarity. I've seen only one other. I've always enjoyed being somewhat out of step so I don't mind. :-)
    Ross
    LOL
    Thanks. Actually, me and my brother were looking forward to seeing your xt. I also hope to meet u soon.
    -teddy_b
    Mike: You think my bro is genteel, until you try to talk to him while he is hopping up his soob!! (j/k)lol
    teddy_b
    Loosh: it was on my end that the photos lost quality. Notice the first looks fine, the rest aren't. Blame Bill Gates, I used MS Publisher!
    Ken: I just rested it on my exhaust as a gag. I wonder how it would sound? And hey, I thought yellow was the color for stickers that added the most horsepower? ;)
    Tony: yes, I RTFM'd (read the ... manual) and was surprised to learn about 6-7 things about the Forester early on. The new VW commercials poke fun at that, have you seen them?
    James: like me, you'll be in the Mods topic asking Colin questions twice a day. :o)
    That's right, Edmunds Live is this weekend. No can do. I've been to several Soob events in a row, and it's my turn to watch the baby.
    Bummer. Teddy was dying to go. Could'a given him a little early driver's ed, ya know?
    Good point, no XTs or SVXs showed up. :(
    -juice
    Thought about that, but then wondered why people always remembered nick "Juice"............. needless to say, I preferred this one :)
    -teddy_b
    James,
    I recently purchased a Garmin Streetpilot and mounted it on the lid of the storage compartment on the dash. The streetpilot has a larger screen than the portables, and it is possible to download various detailed maps from your PC. It is also available with a color screen and an exterior arial.
    The unit is very easy to use and possible to manipulate even while driving. OK, it is almost as bad as a cell phone. The only draw back is that it does not give directions to a location like the unit in the Acura does.
    The unit is not quite portable as in "stick it in your pocket and go", but quite transportable between cars and the boat.
    I got mine at 4X4books.com. They had the best prices. If you get it, also buy the carry pouch. It protects the unit very micely when you transport it between vehicles.
    Daniel
    Quick question: Is the Subaru Extended Warranty worth going for? I ma going by the dealer either tonight or tomorrow and I know they will try to sell me one. Any opinions about after market warranty companies? I received a pretty decent quote thru autobytel--- almost half the price of Subaru's.
    My friend Niels paid $150 from Sports Authority for his. I'm trying to get more details and will share them.
    Mark - follow Edmunds' link to OneSource. At least you'll have 3 quotes to compare.
    -juice
    My friend recently went to Europe, and rented an Opel there. He came back bragging how he drove the German car on the Autobahn, blah-blah-blah. I mentioned that Opel is actually GM these days. He argued (as a former owner of a pretty bad Chevy Cavalier) that no it's not. Can you educated people please tell me is Opel a branch of GM or not? I'm still catching up after years of blissful ignorance about the car stuff :)
  • barresa11barresa11 Member Posts: 277
    You're absolutely correct, Opel is a branch of GM as is Holden in Australia and Vauxhall in the UK. It was no accident when Opels were being imported by GM in the late 50's through early 70's. GM has since bought into car companies such as Isuzu, Suzuki, and Subaru. They have partnerships on various levels w/Fiat, Honda (engines), and Toyota (build Prizms and Corollas in CA). GM also used to own Daewoo which Ford is set to buy. Daewoo was the mfg that brought the Pontiac Lemans subcompact (late 80's) to the States. It's funny that the Aztek kind of looks like it in SUV drag...coincidence? The line for conspiracy theories begins on the right (no pun intended). Seriously though, did you bet your friend that you're right? If not, you may want to. :-)
    Stephen
  • p0926p0926 Member Posts: 4,423
    I wouldn't get one cause:
    a. They are huge profit centers for the companies that offer them. That right there tells me they aren't a good buy.
    b. Reliability is one of the main reasons I bought a Subaru in the 1st place.
    If you're still considering, you should wait until your original manufacturer's warranty is about to run out and decide then (yes you can do that). If you do decide to get one, I'd go with Subaru's. Otherwise, you may have trouble getting the issuer to honor any future claims. Especially if it's significantly cheaper (you get what you pay for....yes this is over simplified but you get my drift).
    -Frank P.
    YOU might be able to do that, yes. I cannot. Whether or not you can depends on the state in which you live-- hmm, or perhaps the state in which it was purchased. Yes, I think the purchasing state. Anyway, some states have created protection laws like what you describe. Most people don't have that option and they either buy it when they buy the vehicle or not at all. That said I'd opt for not at all, unless the vehicle had been troublesome AND you could get a great deal on the extended warranty.
    Another reason why you might want one is if you don't have proper savings. You should of course have at least 20% of your annual income available in conventional savings-- if you don't, surprise purchases can hurt, like a costly powertrain repair. Again I say no thanks and instead make sure you have adequate savings... many Americans don't though.
    Always read the fine print too. Some extended warranties are co-pay on certain items, or parts only on certain items, etc.
    -Colin
    patti so far helped my dad in getting a non-covered item covered because he has the protection gold or whatever subaru's extended warranty is... if you are gonna get an extended warranty I'd go through the manufacturer...
    -mike
    Opel is part of GM, but there is little to no commonality or similarity between stateside GM models and Opel's European products. The only exception I know if is the Saturn L series, which is loosely based on the Opel Vectra. Saab (also part of GM) has a model based on this platform as well. But, the euro versions of these cars are very different from anything you can drive here. To me, driving an Opel on the Autobahn in Germany is still a very "European" experience, never mind who owns the company!
    Craig
    That's because of the suspension tuning, which even on European-based models seems to get the standard Americanization package-- softer springs and much softer struts. Ah, perfect... now it wallows like a Buick.
    You also forgot the Cadillac Catera / Opel Omega. The Omega is more attractive.
    -Colin
    Back to Subaru stuff!
  • soon2bsubeesoon2bsubee Member Posts: 137
    Another Opel product here in the US is the Cadillac Catera
    I said that in my hidden, off-topic reply. ;)
    Let's talk Subaru. Who here has or intends to buy a dedicated set of winter tires & wheels for their AWD Subaru? I went without last year and to be honest it wasn't much better than not having AWD. AWD + crappy all seasons (RE92's, thank you Subaru) doesn't help you stop or turn.
    I'm going with snows this year.
    -Colin
    James,
    You mentioned a while back that you were considering changing your order to a Premium S instead. What ever happened with that?
    Ken
    I prolly will IF I go and get GT rims. then I will put snows on the 15s that come with the car. The marginally grippy XW4 Michelins did an adequate job last winter though, so I may wait til I wear 'em out.
  • grahampetersgrahampeters Member Posts: 1,786
    The variations in the products from GM subsidiaries is interesting. In Australia, the most popular car is the Holden Commodore, a spin off from about 20 years ago from the Vauxhall Carlton/Senator and the equivalent Opel model. Australian driving conditions are markedly different to European and closer to US. European roads are tighter, much faster and the paving different, meaning that smaller cars are preferred. Full size US models are generally considered a joke in Europe as they are patently impractical.
    In Australia, there is a strong demand for a larger family car with a powerful engine. Rear drive is preferred as towing boats and caravans is very popular. Automatics are the preferred choice for most drivers. Given that many Australian roads are unmade, handling on dirt is a key factor. When ABS was first introduced, the programming, originally set for European conditions was found to be unsafe here with most drivers being able to stop more quickly without it on dirt. The technical reason for this is complex but essentially turns on the most efficient braking pattern on gravel being about 15% slip which allows a build up of a slight wedge of gravel in front of the wheel. Mercedes, the first major manufacturer to introduce ABS reprogrammed the system although I never felt happy about the brakes on my European C Class when on gravel or snow. I figured I could get shorter low speed braking distances by slight modulated locking of the brakes.
    The Commodore and the equivalent Ford, the Falcon are excellent cars although a little on the agricultural side after sophisticated European cars. Japanese imports are far more popular than in Europe and Subarus far more common than in England. Somebody described them as sort of Saab like quirkiness which seems to fit. Incidentally, if you are a computer programmer or tech-head, the car of choice is a hot WRX. There is one in our office car park that has a trick pearl effect paint job which turns from pink/purple to gold/yellow as you walk by. It looks as awful as it sounds but somebody obviously thinks it is lovely.
    Holden here do import several model ranges, including the Vectra which is made by Opel and or Vauxhall. One of my colleagues has one which I have not driven to compare to the European version. I anticipate minor suspension and tyre variations from the UK version.
    Cheers
    Graham
    Welcome!
    Stick with the name. Sounds like it fits! Just what do you do in Belize? I didn't know there was any chance for a Subaru there.
    Cheers
    Graham
