2019 Cadillac XT5 Lease Deals and Prices
Ask your 2019 XT5 lease questions here. Get info about prices, money factor, deals, incentives, and payments.
Look up info about the 2019 XT5 here.
.00012 and 53%
.00076 and 58%
.00076 and 59% (yes, 39 months is better)
.00032 and 54%
$1000 customer incentive
AWD
.00078 and 58%
.00078 and 59%
.00157 and 54%
.00002 MF and 60%/58% residual for 24/27 mo
AWD
.00038 MF and 60%/58% residual for 24/27
$1000 customer incentive on either drive
.00053 and 58%
.00053 and 59% (yes, 39 month residual is higher)
Thanks - Dan
Luxury FWD - .00051 and 58%; $1000 customer incentive
Both terms
>>> available incentives, North NJ (NYC Metro),
>.00053 and 56% - both terms
Hi Michaell,
Thanks for all the numbers. Did the December numbers change again? A dealership mentioned that the 39/15 is the same as it was previously, .00067 and 55%. Can you let me know if it's .00067/55% or .00053/56%. Not sure if there's any change with incentives?
FWD or AWD?
Are the Residual and MF the same for dealers in 08822 and 07632? Are the Residual and MF rates national for Cadillac? If not national, are the rates based on where the dealership is located or the zip (07649) where the vehicle will be registered?
Both ZIP codes
Generally, it's based on dealer location.
.00078 MF and 56% residual
> Both ZIP codes
Hi Michaell,
Dealership showed me a chart generated from GM financial based on VIN of an AWD Luxury XT5, and for 39/15, it lists 55% and 1.61% (.00067). It also had numbers for other terms.
Are the numbers that you provided from GM financial or another GM financing company?
I'm trying to understand why there's a difference. I would like the better rates.
> Both ZIP codes
Hi Michaell,
The dealer is correct.
Our charts have recently inserted a 30 month term (just for Cadillac), that moves every column over one slot. So, we gave you the 36/15 numbers, rather than 39/15.
Which means I'm going to have to go back and check my recent responses.
AWD Luxury 39/12, 39/10 (Dealer quoted MF of 2.61%) and
AWD Premium Luxury 39/12, 39/10
Zip code 12186
Thank You
Luxury - .00067 and 57%
Premium Luxury - .00128 and 57%
Could you share RV/MF and incentives for Standard AWD, Luxury AWD, and Premium Luxury AWD trims on a 39/12 lease in Zip 87113? Thanks very much!
Lux: .00004 MF and 56% residual
PLux: .00018 MF and 52% residual
36/10 - .00032 and 42%
39/10 - .00046 and 41%
.00018 and 55%
.00032 and 54%
Luxury
.00002 and 57%
.00016 and 56%
$1000 incentive
There will be an adjustment to the residual for the miles, but we don't know the format GM uses.
