https://www.cedarworks.com/
Are you doing some social engineering asking about my age?
You'll probably have to look up what it means on the internet.
I will say this, My age is more than 3 times the number of years since the century number changed and I do more pushups a few times a week than my actual age.
I do like to take a few short walks every day possible.
that ain't happening these days!
FWIW, I'm still waiting for Mike to send my airfare money. Hopefully, before this Winter is over.
If it strikes once your odds are probably good it won't strike again.....oh no, that's lightening I think!
My grandfather’s house had the A.C. ducting and air handler in the attic (but a typical compressor on the side of the house) and it always felt nice and cool in there with the cold air blowing down. The house also had forced hot water radiators, great combination.
Sometimes, not all the time, you have a house without a basement, and you want to add an a/c unit later. If you install it on the roof you need minimal duct work to carry the air into the house. Since cold air falls it is actually pretty efficient.
In the case of the 150 year old farm house, there was no furnace and no duct work, and it was heated with electricity....a grid plastered into the ceiling. The easiest solution was an a/c unit on the roof. There was minimal duct work. Stores use roof a/c's all the time...efficient and less expensive.....also fairly quiet.
Probably good in areas that could flood too.
Summers, on the other hand, are extremely hot in both places. When I used to drive to Vegas from Palm Desert, I often had to pull over due to ice and snow on I-15 at the higher elevations. But 3000+ foot altitudes in winter (like Vegas) can be quite cold.
As Ned Stark said many times before his beheading...”Winter is coming”!
Sorry.....couldn’t help myself with a little Game of Thrones....
Yep, I've been in Kansas for 40 years and never seen one. Knock on wood.
Invariably, the folks who live on the River’s banks bemoan that they suffer lots of damage to their homes when this happens and that insurance is extremely expensive (or, they can’t obtain insurance at all). Yet, they do rebuild.
Then, it happens again, and the same people get in the same snit all over again.
Just like tornado alley, or living where there are active earthquakes, or living where monsoons, tsunamis, hurricanes, etc occur on a semi-regular basis, if you don’t like where you’re at, you’re not a tree. You can always move.
Yes, the ductwork just goes in the attic. I have recently noticed that they are beginning to use flexible plastic tubing instead of metal ducts in these cases. The type used for venting clothes dryers, just a little bigger. This is especially useful in houses that were built without a duct system and are being retrofitted with central AC.
That is exactly how my Grandfather's house was done. Flexible insulated ductwork in the attic. Coil/air handler was in attic and the compressor outside. Lines for the refrigerant were run into the basement and up wall next to the chimney in the attic.
This was installed in the late 80s, so they have been doing it a while
Our home in Seattle is a relatively new build (2012) and has no basement. All of our HVAC, Hot Water, etc is in a corner for the garage that is blocked off by a couple of pylons. Most of our ducting runs through the crawl space or the attic. When the AC was added we simply lifted the furnace a bit in the garage to accommodate the coil box and placed the compressor on the other side of the garage wall.
Tell that to Dorothy and Toto.
Tidal flooding has been happening for eons. Just a matter of how close we choose to build. Most of the areas where this happens are about 3 ft above MSL.
Yes, of course it has, but that isn't quite the point. The flooding is happening both faster and more severely than historical and geological records show from the past. So what you have is normal phenomenon accelerating at an abnormal and less predictable rate, with greater extremes.
"They" say humans don't project well past 3-5 years. After that, it doesn't seem to concern them.
Sometimes they built houses that used a wooden stove, or even electricity, they didn't need ducts at the time, so when they add an a/c unit, it might be easier to put it on the roof, and the air can be vented or ducts could be added in an attic area. Homes with a basement and a furnace have the ducts already in place if you add an a/c unit.
Our warehouse in Canada had a cement floor, and they used gave us gas heaters that hung from the ceiling. When we wanted to add an a/c unit - which we paid for, we put it on the roof.....not much ductwork, it just blew air straight down.
Who knows? It may be that future wars will be fought over things like clean water.
Even better: ausfart. Yep, it’s pronounced like you think it is. My colleagues can’t understand why I keep laughing to myself while we drive along the autobahn.
But the building and infrastructure in China is incredible. I mean, how do you govern 1.4 billion people? Saw the Terra Cotta Soldiers, Great Wall, pandas, Shanghai and Beijing on that trip.
I wonder what he would think of Buick being one of the best selling cars in China today!
Another of mine blower in light of China’s 1.4+ B people, fully 300 M (21%) are in the middle class. This miracle growth in the middle class has happened largely during the last three decades. Isn’t it wonderful what can be done with American money, education, know-how, technology & markets?
It’s almost easy to see why China’s car market @ 20 M? beats USA’s @ 17.5 M.
What is concerning is that people continue to build and re-build in flood areas, and when they flood they say they didn't realize that all that water would be so wet.
Isn't it wonderful what one can do without cares in terms of social and environmental matters, corruption (look at west coast real estate, which is directly impacted by this same region), IP regulations, etc.
