Audi R8 Lease Questions
1246
  • kyfdxkyfdx Moderator Posts: 264,165
    echpp said:
    What would Mf and res numbers for 2018 r8 rws be?
    92618
    7500 miles 24 months
    .00261 MF and 75% residual
  • Culby4122Culby4122 Member Posts: 25
    What would the current mf and residuals be for 36/10, 36/7.5 and 48/10 and 48/7.5 for both the 2018 base V10 coupe and the RWS in 92064. Any new incentives for February? Loyalty?
    .00248 MF
    66%/59% residual for RWS/Coupe
    48/10
    .00268 MF
    59%/52% residual for RWS/Coupe
    Add 2% for 7.5K/yr
    No incentives
  • fammedfammed Member Posts: 8
    Can I please get MF and residual values for 2018 Audi R8 spyder plus for 7.5k/year (24 mo lease)? Also, for 5k?
    Thanks so much
    Zip code is 27613
  • MichaellMichaell Moderator Posts: 261,354
    Thanks so much
    fammed said:
    Zip code is 27613
    .00248 and 67%
  • formula1fan5formula1fan5 Member Posts: 50
    Hello, can I get the MF and residual on an R8 V10 Plus convertible for 24 months with 7.5k and 10k per year in zip 11942. Thanks so much!
    24/10
    .00248 and 60%
    Thank you so much. Based on the prior info you provided 7.5k would be 62%?
    61%
    61%
    @formula1fan5 is correct. 2% spread between 10K and 7.5K for the R8.
    62% for 24/7.5K
    Thanks for the info! Just wanted to share my deal.
    I leased a 2018 V10 Plus convertible on a 24 month one pay lease with 10k miles per year for $74,000.
    The one pay option reduced the money factor to .00198 and the deal was done at 35k off the MSRP of $220,500.
    Thanks again!
    Thanks again!
    Congrats on the new R8.
    I'll guess that's an amazing drive... ;)
  • mflofrancomflofranco Member Posts: 19
    What is the current residual and MF for a 2018 R8 V10 - 36/10, 36/7.5 and 48/10 and 48/7.5 and 2019 R8 V10 & V10 plus - 36/10, 36/7.5 and 48/10 and 48/7.5 in 77379 & 75209.
    M
    M
    2018 V10
    36/10 - .00232 and 59%
    48/10 - .00252 and 52%
    No 2019 R8 numbers available this month
    M
    2018 V10
    Thank you so much!
    I'm not sure there is a 2019 R8. The 2020 model is due out soon.
    M
    2018 V10
    Are there lease incentives this month?
    M
    2018 V10
    No incentives
  • rara009rara009 Member Posts: 2
    94062
    10000 miles 36 months
    94062
    .00232 MF and 66% residual
  • BenjaminEliasBenjaminElias Member Posts: 1
    @kyfdx, could you let me know residual and MF for 24mo, 10k MPY on an RWS for April? Thank you in advance
    What is your ZIP code?
  • OmiddadarOmiddadar Member Posts: 2
    My payment ended up being $1700 with !10k down due at signing for 5k miles per year. $154k msrp.
    That is spectacular! Congrats, and thanks for sharing the details.
  • carguy1985carguy1985 Member Posts: 73
    Can you please provide...
    24/10 and 36/10 residual and money factor for a 2018 r8 spyder and the 2018 r8
    90078 zip
    please give residual for both spyders regular and plus in addition to the regular hard top r8
    thank you
    .00221 MF
    Coupe: 66%/59% residual for 24/36 mo
    Coupe Plus: 61%/54% residual
    Spyder: Subtract 1% from Coupe numbers
    edited May 2019
    Is there still lease support for the 2018 r8?
    of so mf and 24/10 and 36/10 for the r8 spyder regular and plus
    Any incentives?
    90078
    Thanks as always!
    edited May 2019
    Any incentives?
    90078
    Thanks as always!
    .00216 and 65% / 58% (Spyder) or 60% / 53% (Spyder+)
    $750 loyalty is the only incentive I see
  • vnevne Member Posts: 2
    Hello, can you provide lease info for 2018 R8 RWS 36/48mo 5/10k miles as well as MF? 91739
    Thank You
    Thank You
    36/5 - .00193 and 70%
    48/5 - .00213 and 63%
  • SD_m3SD_m3 Member Posts: 5
    edited July 2019
    May I please get MF, residual, and any incentives on a 2018 R8 coupe (non-plus), for 24mo/5k, 24/7.5k, and then 36mo/5k, 36/7.5k
    92029
    92029
    .00193 and 70% (24/5) or 63% (36/5)
    No info on incentives
    edited July 2019
    Thank you! Do they change for 7500 miles for each (24 and 36)?
    Also, please forgive my ignorance, but should these figures apply at any dealership? I.e. if they are giving me worse figures (given proper credit), are these figures standard from Audi?
    $7500 Audi-to-dealer incentive
    7.5K/yr residuals are 2% lower
    Thanks for that info! I saw the $7500 Audi to dealer incentive with my CU also, but dealer claims ignorance to it ... :/
    What does MF go to at 7.5k/yr?
    It is an Audi to dealer incentive, so they don't have to disclose it.
    Money factor does not change with mileage allowance
    Thank you for the responses!
  • donna91761donna91761 Member Posts: 19
    Any current lease support for 2020 Audi R8 coupe on both base & performance model. If so what is currently the best residual, length & mileage deal for your money? Would appreciate any help 👍🏻
    What is your location?
    @Michaell located in California, lease term looking for 24/36 with 2500/5k miles. If they have special lease promotions going on would like to hear about it as well Appreciate the response
    .00193 MF
    Base - 67% (24/5) or 60% (36/5)
    Subtract 3% for Performance trim
    No lease incentives - c'mon, it's an R8! :wink:
  • Prichards516Prichards516 Member Posts: 4
    Hi
    Can I get the MF and residual for a RWD R8 please.
    NY- 11510
    36/5k or 24/2.5k
    edited July 2019
    2020 or 2019 ^ :)
    Hi
    NY- 11510
    36/5k or 24/2.5k
    2020 or 2019 ^ :)
    Which model?
    Coupe or Spyder?
    ^ coupe please.
    Hi
    NY- 11510
    36/5k or 24/2.5k
    2020 or 2019 ^ :)
    ^ coupe please.
    There is no 2019 R8
    2020 - .00193 and 60%
    2018 - .00193 and 63%
