MF and RV for a SR5 Crewmax Sport 4x4 and a double cab SR5 Sport 4x4. Both 5.7. 24/15 and 36/15. Zip is 16214. Trying to decide between the Ram and Tundra.... Thanks for all the help.
Is it always best to lease when the newer model comes out to get the best money factor? Or is it all based on zip and banks used for leasing?
The MF and RV tend to be higher when a new model is released - and, coupled with poor discounting (compared to the outgoing body style), the lease payments will likely be higher.
Tundra crewmax 4x4 sr5/Limited 5.7
24/15 36/15
70816
MSDs discounts
SR5: 76%/70% residual
LTD: 75%/69% residual
I don't see a "Sport" trim for the Tundra.
SR5 Double Cab - 73% / 67%
SR5 Crew Max - 76% / 70%
2015 Subaru Outback 3.6R / 2014 MINI Countryman S ALL4
not sure if it matters but with SR5 upgrade, floor mats and bed liner spray?
Sorry about that - 4x4. Thx Michaell!
.00261 and 72%
Options and packages do not affect the numbers.
.00285 and 72%
Tundra SR5 Off-Road Crewmax
55433
24/12
please and thank you.
Tundra CrewMax SR5 4x4
Tundra CrewMax Limited 4x4
Thanks in advance!
Are the lease rates based on leaser zip or dealer zip?
All of the northwest share the same program.
I don't see an Offroad trim for the Tundra
SR5 - .00261 and 78% / 72%
Thanks in advance.
RV/MF 24/12 36/12
please and thank you!
.00176 and 76% (SR5) or 75% (Limited)
.00261 MF and 72% residual
10K/yr is not offered
Tundra SR5 Crewmax 5.7L 4x4
36/12k
08753
Currently leasing a Toyota Tacoma if there is loyalty and am a veteran and first responder.
May I have the MF/RV + Incentives on a:
2019 Toyota Tundra SR5 4x4 5.7
36/12k (and 36/10k if available)
46375
.00261 and 72%
no 10K from Toyota
1) Limited CrewMax 2WD and 4WD 24/12 36/12
2) Platinum CrewMax 2WD and 4WD 24/12 36/12
3) SR5 Crewmax 2WD and 4WD 24/12 36/12
Thanks in advance.
Please give us your top two or three combinations of trim, term and drivetrain.
thanks again mate, i appreciate what you do.
.00176
4x2 - 71% (Ltd) or 68% (Plat)
4x4 - 75% (Ltd) or 72% (Plat)
.00261 MF
SR5: 73%/72% residual for 4.6/5.7
