Forums Feedback and Suggestions
Whether you’re experiencing technical issues or have a suggestion for our forums, this is the place to share your feedback and ideas. You can also contact our Customer Care team
We always appreciate your help in reporting technical issues or errors on the site you may come across.
When reporting a technical issue, it’s always helpful to have as much information as possible. Be sure to include the device, browser and operating system you’re experiencing the problem on as this can be useful in trying to diagnose the problem.
Be sure to upvote (like) any suggestions from other members
MODERATOR /ADMINISTRATOR
Review your vehicle
Let's see if the one below is or isn't:
Ah ha! It isn't. The reason why is that it lacks the "class="Quote" rel="kyfdx"" text after the blockquote command. Without that, all "blockquote" does is indent.
Quote Settings
This setting determines how many levels of quoted comments you would like to view within a comment. The default is set at 1 level, but you may choose up to 5 levels, or "Don't ever fold quotes."
But no matter how many levels you show, at some point the gray box eventually drops out of the way. One level seems to work for me.
Firefox used to be my main browser, but it DID get flaky and I mostly use Chrome now. I need a new personal laptop so I can get Firefox back on my test list
Gold stars all around!
Earlier this morning I made a post in the Project Cars forum and tried to post a picture. The icon was non-responsive again. I even exited FF entirely and then came back to try again, still no go.
Just now, 1 hour or more later, I made a post in the "I spotted an obscure classic car" forum. Lo and behold, posting a picture now worked there, so I did. Then I went back to the Project Car forum again to try to post the picture I wanted in there. No response, same as before.
Could the problem be specific to only certain discussions I wonder?
I had the brainstorm that I could post the picture I wanted in the classic car spotter forum, copy the resultant code, and paste it in the project car forum. I tried to post the picture again there one last time and it still wouldn't respond, so I did the copy/paste of the line of code from the other forum and it worked.
Still, every bit of information is welcome
In any event, hang in there and we appreciate your patience on this. We just have a few items to be sure about before we change the setting. I'll be posting more about it soon, including a little tutorial about the functions of the new comment box. Basically the same functions plus new and improved emotorcons
IMPORTANT: This will not be a change of anything else in the forums or how you use them. If you're just clicking into the comment box, typing and clicking Post, there's really no change at all. The ONLY things that are going to move around will be the icons/functions and where you'll find them.
TEASER: there are actually TWO ways to add an image in the new editor. One that displays the image in your post just like now, and one that adds a clickable "box" in your posts that displays the image full screen for those big images
Thanks again for your patience and feedback.
But again, stayed tuned.
Thanks! I guess some maybe thankful that I couldn't bore them with the pictures I was going to post, lol.
Coming Attractions - Changes to the Comment Box
But, you have to be careful about the html blockquote tags. I've even messed that up, especially quote something that quoted something else. The new editor keeps you away from the "nuts and bolts" and you can't mess up the html.
It looks a bit cumbersome, but from playing with it in the staging environment, it's not bad at all. Just took a time or two to get used to how to pull a partial quote.
I knew there would be questions, so I tried to make sure I tried everything that I've seen folks use
The feedback and questions are all good!
One other announcement, the plan is to turn on the new editor Friday morning, so don't be surprised when you see it!
We really appreciate all of you poking around the corners and helping us find things we otherwise might have overlooked!
Aside from all of the other issues noted in Cars & Conversations, I am curious about how this new version operates. Over in that other board @henryn made the point yesterday that he was not finding it slower and attributed that to his high-speed connection and computer. I too have a high-speed connection and pretty powerful computer yet there has been considerable lag when typing a post using this editor at times which i never saw before. I attributed to Java or something else running locally that was getting bogged down.
But this AM while composing my response over in C&C I could not post it at all. The "Post Comment" button changed from a bright blue to a faded blue and was totally unresponsive. Then it came back to normal, so I was going to add a sentence about that happening, but before it finished, the entire screen disappeared and the message "The server at Edmunds.com is taking too long to respond" appeared instead. Well, to my knowledge I hadn't asked the server at Edmunds to do anything as I had not hit "Post" that time since I was in the middle of typing a sentence. I tried to get into the Forums using a new browser window but could not and it appeared the entire site was down temporarily, so I gave it a break. Now we're back!
It strikes my that maybe the reason I got that message, and maybe the reason I get lag when using the editor, is that each keystroke is being sent to Edmunds and not the entire post (coming from a local cache) as has been the case? Any insight/rationale on that?
There can be many things outside of the forums causing speed issues. About an hour ago, the forums were timing out and down for me, as well as a handful of other websites I tried to visit. So it sounds like you ran into the same thing. Yet, other forums mods who live in different geographical areas than I do had no problem at all. Had nothing at all to do with the editor.
Sometimes there are internet slowdowns that affect some of us and not others. There's not much to do about those. Things like that COULD affect how some sites operate. I never had the problem with the image icon not working until the day BEFORE we enabled the rich editor. Refreshing the page got it working. So perhaps an internet burp, at just the right moment, was involved. I've had icons in the new editor be unresponsive once or twice, and refreshing or going back and forward has set things right.
I'm on a high speed cable modem, but over the last week or so, even my TV picture will freeze and the sound go out momentarily. So SOMETHING is buggy somewhere along the connection trail. And what's affecting me or you, may or may not affect everyone, as evidence by the "outage" you and I had this morning while other people I work with here and were communicating with me were in the forums just fine while I couldn't even get in. Sometimes a page will hang up because an ad server that displays an ad on the page is slow. Again, an issue outside of the forums that is not completely under our control. I've worked online exclusively since 1994, and these things DO happen.
We are noting all the quirks and (what appear to be) glitches and are looking into solutions. Most of the differences with the new editor are "getting used to" kind of items. Flaky things like where images get inserted or why some get displayed sideways are tech concerns that I expect can be addressed.
(I just double-double spaced out of habit... gotta remember, no need to enter enter)
As always, we appreciate the input and feedback on unexpected behaviors. It helps us find potential issues, and gives us a chance to explain changes
PRO Tip:
Text showing above the quote, occasionally? That happens when you start scrolling down before the quote loads in the comment box.
I had assumed it came from clicking in the comment box, before loading was complete, but it is the scrolling that causes it.
Ah... that may also have something to do with text relative to images, which has been sort of erratic for me. Let me try adding an image and waiting a few seconds before typing, see if it's about image load finishing
Keep letting us know when you run into issues like unresponsive icons and the like. Every bit of information helps!
This is sorta like tracing down why the dome light comes on and the headlights go off when you step on the brake
Noticed that I can no longer post a pic using Safari on the iPad by selecting one from the photo library. It supposedly allows you to use a URL but I did not have one to try. First time I had posting problems on that device.
EDIT: Tried to post a local photo on a PC using both Firefox and Chrome and had the same result. No locally-hosted pics can be uploaded.
It was a bit slow and I almost thought it wasn’t working, but it did. There are some site speed issues we’re looking into, so it may just be a “timing out” thing.
Thanks for reporting
Nope. No response to the icon.
Now trying on Chrome:
Get the "Image URL" text only.
Trying on the iPad:
Get the “Image URL” text only, like Chrome.
Very flaky now.
I honestly don't recall if all of the icons worked on the cached version of the rich editor, I don't think they did, but I couldn't swear to it.
When you navigate around the forums, do you see ads, do the pages seem to load slowly? We're seeing some speed issues right now that seem to be affecting things. When I went to post an image from my ipad earlier it took a long time for the html to appear in the posting box. One of our other moderators had it not work for his ipad, then it did right after. So the slow page loads MAY be timing out things like that. It might even explain why icons are not responsive. If the page load is hung up, that MAY be stopping the editor from loading and thus, the icons are just images. That's just speculation on my part at the moment, but it makes a bit sense in my gut.
I posted this the other day but I'll say it again in case it got overlooked. Prior to the changeover to the rich editor, the problem in Firefox was that the Emotorcon icon and the Image icon would be randomly (but usually) non-responsive. If I wanted to use them I could go to Chrome, or use the iPad. But I discovered that the pulldown for the user menu at the top of the Edmunds banner page was also nonresponsive in Firefox, and that didn't matter if you were in the Forums or not. I found that strange and wondered if the two things were connected, maybe due to some sitewide setting.
I do note that right now that banner pulldown is in fact working in Firefox while the ones in the old editor are responsive but the image one doesn't work correctly, so who knows.
We appreciate your patience while we chase down the gremlin!
