I ordered replacements on Ebay, which are a newer design without the snap in connections at the sensor ends IIRC. But I found my old ones just needed cleaning because of the moisture they get when the door is open... Apparently this problem showed up and the Genie company changed the design to avoid the corrosion. Turned out I didn't need the replacements.
And then a few months later the motor started acting up on the drive unit. And then it died. RIP
Replaced with a belt drive Chamberlain.
If I think back from what I remember about my parents' car histories, my dad had a 67 Galaxie convertible then, and I think my mom had a 61 Impala convertible. The Galaxie would be replaced by a Mustang, and the Impala by a Beetle of all things.
A fan base of 2 is something you should be aspiring to.
It was then I noticed that the defroster blower was running. No matter what, it wouldn’t shut off, like all the switches had been disconnected. Somehow, while parked the blower had turned itself on and because the van wasn’t running it drained the battery.
I was worried that if I turned the motor off I’d drain the battery again so I got out the owners manual and pulled all the fuses to the heater system...no good, blower still ran.
Finally, I located the blower motor and disconnected the power to it. Problem solved for now but I hope I don’t need to defrost the windows anytime soon. I suspect since removing fuses had no effect, I must have a short somewhere.
We had a big thunderstorm last Thursday.
Suspect it was due to that, as the sound went out on my TV that night too, but only 1 jmonroe length story per day.
I hadn't opened that garage door in about a month, so it could have been out since the storm.
Garage has 3 150 watt incandescent bulbs to make some heat when it gets really cold out during the winter.
The leftmost cabinet is sagging.
They are builder quality, not a solid wood back panel, and I don't think the original developer thought any of he original owners would still be here after 20 years.
Trying to figure out how am going to get them back to level.
Attempt 1.
Attempt 2.
I'm thinking I should level the left cabinet first, then level the center. Microwave unit is very heavy.
You can't see it from the picture, but there is one screw in the middle of the cabinet at the top.
If the back was more of a more rigid material, everything would be ok.
I know some of those cheap cabinets have something like fiberboard in the back which doesn’t hold well. Maybe you can use washers over the screws to strengthen the connection.
Is there a screw in the horizontal framework at the bottom of the cabinet into the one stud that runs up the middle? I'd give the cabinet a little extra lift and put a screw into the base skeleton either inside the cabinet or exposed under the cabinet. Dab a little of the touch up clay color they sell to match the cabinets if the screw head shows.
Your cabinet size is typical for most kitchens which is why when we were framing the kitchen for
Son # 1's flip house we installed a 2 x 6 between all of the 2 x 4 verticle studs at the point where the cabinet top and bottom horizontal mounting rails are located. A 2x6 is overkill but that size will allow us to change the height of the wall cabinets if we want to since there is no bulkhead above the cabinets. AND, more importantly, we are not limited to finding the 2 x 4 vertical framing studs to screw into. Therefore, we can use more than one screw at the top and bottom cabinet mounting rails even on narrow wall cabinets. I know you can't do this but that is why long heavy duty screws are a must for mounting narrow wall cabinets.
If you can drop by in a couple weeks when we start installing the cabinets, you can see how and why we did it the way we did it. No charge for watching.
Don’t look i our spice cabinet. We have that one, a giant box of Kosher salt and some others.
The box of Kosher salt is probably 1.5 years old at least
Pictures are out again too.
The park facilities are quite impressive. She looked great and she seemed quite relaxed after that long drive in from northern Illinois. The most exhilarating aspect of her move down here (to me) is that she appears to be happy! What more could a father hope for than that? 😀😛😁
Grandchildren would have been nice, too, but it’s too late for that to happen. At least I have 2 grandsons by my son.😋
We do use ones like Explorers to put on our sidewalks in the winter....if I was here.
btw....looks like a commercial grade microwave oven....do you have a restaurant in your home?
Total Miles -- 11,473
Avg MPG -- 35.7
Avg amount trip computer was high on MPG - 6.3%, never less than 3.5%
Days gone -- 35
Got mpg as high as 39.2 and 40.3, both at high elevation (reduced drag). Shades of the kind of driving I used to do in the KW. The Forester was a very capable vehicle in this application.
I'm thinking about a whole new house!
Those are not commercial grade appliances, but they are what my wife wanted.
After my shower today I couldn't even do that and found that a good-sized trickle of hot water would come out no matter what I tried. Well, obviously can't have that. I went downstairs and traced the Pex lines that were installed in 2017. No shutoffs anywhere, dammit. So I turned off the house water at the meter to see what I could do with the shower.
It is a Moen Positemp valve and after some fiddling around I was able to expose it and tried to pull it out. Wouldn't budge. I was afraid I was going to break something inside the wall if I pulled any harder so I stopped. Moen suggests a cartridge removal tool which of course I do not have. But it may have been just as well since if I got it out and couldn't see anything obvious it may have leaked even worse when I tried reinstalling it, so I'm frozen for the moment. I get to call Moen tomorrow and they will send me a free replacement, and I'll try to convince them to include the removal tool too. But that will take a few days to get here so until then I'm using the downstairs bathroom and keeping the house water turned off most of the time. PITA.
If I had been able to get the old one out I was thinking I would just go to HD and buy a replacement cartridge, then return the one Moen sends me to them later in the week. But I discovered that none of the local home centers has the 1222 cartridge listed as available in-store. Bizarre.
Well yes. Kosher salt, table salt and sea salt grinder.
You are rehabbing that house like you are going to live in it, not flip it.
