@qbrozen - killing us with truth...
2025 BMW i5 - 2017 911 C4S - 2024 VW GTI - 2026 MB GLE450 - 2024 Genesis GV60 - 2019 Cayman
I don't think the Q7 has a good excuse for the weak battery other than typical OEM mediocrity on consumable parts. It will not be an OEM battery that goes in there to replace the original, that much is for sure!
couldn't have been that common, since they sell a bazillion of them and you don't hear much about it.
I do like leasing when 1) the residual is artificially inflated (and you don’t buy it out) and/or 2) there are significant incentives specific to leasing only.
I’d say lease it and buy it out somewhere along the way (if you want to purchase it).
https://www.royaleasing.com/details-2014-chevrolet-malibu-4dr_sedan_lt_w_1lt-used-1g11c5sl5ef286733.html
When I tried to start on Tuesday morning, after it sat for 7.5 days, it was not "dead," but it only cranked the engine two times before it was done. After a week of sitting, that engine needs about 7-8 cranks to fire (rather consistently, at that).
If you let it go and go, eventually it will get to the point that multiple short trips in a single day can sometimes leave you stranded at the end because the juice needed to start the vehicle is more than the charge it gets from point to point.
Setting aside regulator and wiring failures in the car, life span on a battery depends most on the driving conditions under which it gets used. For example, if you only drive the car 5-6 miles per trip, you are much less likely to get a lot of life out of it compared to trips at 10+ miles per go. Extremely hot climates can lead to early failure as well, but usually that is only a side effect of improper maintenance. Even "Maintenance Free" lead acid batteries require additional electrolyte (albeit infrequently) from time to time, and very few people bother to do this. When the electrolyte gets low, the battery is going to fail prematurely. In this case, if the anode plates warp, they actually can quit rather abruptly.
My dad has had good luck with his, but I can't recommend the Battery Tender brand. I think I'm on my third warranty replacement. Ten year warranty, but you're out $10 or so to mail it back, each time. One of the times mine died, it released its magic smoke, and my garage smelled like burnt electrolyte for a month.
Also, a dead license plate bulb on the Tahoe. I replaced both bulbs with regular bulbs when I bought it two years ago. I ordered a pair of Sylvania LEDs to replace.
