Visitor Agreement.
part of the problem was that she drove 5 cars in 3 hours, all of which were very nice, so tough competition. If we had just gone to see any one of them to make sure she liked it and to make a deal, she would have been happy.
I must have done a fine job putting the short list together, since she said that she thought yesterday's visits would make it easier, but in fact, might have made it harder to decide!
I also did a lot of research last night to confirm one thing the salesman said. The RDX is actually fine with regular gas. That will help with covering the new payment!
I will also get a lease quote for the heck of it. Could do that, flip the old one to Carvana, and invest the $$ in the depressed market, and hopefully have enough to buy something nice for cash when the lease runs out!
You really can’t go wrong with any of them. All fantastic choices. For me I would be torn between the Volvo and Acura.
I still think we need the Enclave sized SUV for the next one otherwise I would have pretty much the same short list.
Still up on the air what I’m doing with the Enclave anyway. Had a great interview for a 50/50 WFH and travel position but it sounds like more flying than driving so if this one pans out may still be able to lease both and swap out with the wife as necessary to balance miles.
Also made it to the next step with another company that would only be a 17 mile each way commute right over the bridge so that’s promising as well.
We open the campground first week of April. Fingers crossed I have an offer by then.
https://acurazine.com/forums/third-generation-rdx-2019-454/request-those-put-regular-gas-your-rdx-gasp-976228/
"01-08-2019, 02:44 PM #5 zroger73
1. The only Acura that currently requires premium gasoline is the NSX. It is recommended in all others.
2. In order to achieve the peak advertised horsepower and torque ratings, you must use premium gasoline.
3. The peak horsepower and torque ratings are achieved only at wide-open throttle.
Turbocharged Honda engines use a torque-based engine control system. This means that pressing the accelerator pedal requests a specific amount of torque from the engine. The ECU determines the best way to produce the desired amount of torque in real time using valve lift and timing, ignition timing, fuel flow, throttle blade opening, and turbocharger boost. If pressing the accelerator pedal halfway requests 150 lb-ft of torque, the engine will do what it needs to do to produce this amount of torque whether you're using regular or premium gasoline. Using regular gasoline will simply limits the maximum amount of torque the engine can produce. In short, there won't be any difference in performance in "normal" driving, but the maximum amount of torque will be reduced by a relatively small amount. Very few drivers regularly push their accelerator pedals to the floor.
Because of the adjustments the engine must make to operate on regular instead of premium, fuel economy will decrease a bit which will offset some of the savings of using regular gasoline instead of premium. Also, premium gasoline tends to contain even more detergents than what is required by law or to meet Top Tier standards which can help keep your fuel system cleaner.
The vast majority of RDX drivers won't notice a difference between regular and premium gasoline. In fact, about the only time you may notice is if you take two identical RDX's to the drag strip - one filled with regular gasoline and one filled with premium gasoline. The race will be close, but the one running premium will win.
With that said, when I spend the money for a "premium" vehicle that recommends premium gasoline, I run premium gasoline. I DO use wide-open throttle regularly and want the best possible performance under this condition."
Premium is more "needed" in the TLX 2.4, because once in a while you need every one of the 2.4's 206 horses on premium for this 3,500 lb car. Losing 20 hp without the premium will sacrifice performance sometimes.
But since the RDX has some extra power with the R-type engine (Alex on Autos timed the RDX at less than 6 seconds 0-60, which is about as fast as a standard BMW 3-series), using regular gas should still leave plenty of power left, and will no doubt save money. Going from 272 horsepower to c. 252 horsepower still leaves enough horses and torque.
Same HP rating with RUG.
Ford does this too, among others I'm sure.
My truck is rated at 375 HP and 470 Torque on RUG.
A top of the line Expedition with the same engine, rated with PUG is listed at 400/480.
it is the same engine pretty much as the Accord. I researched this with our current RDX. same engine code as the Pilot (or odyssey, one of them) and exactly the same specs (compression ratio included). There was absolutely nothing to explain why the Acura would need PUG. I think that basically the Pilot could get a little bump from PUG, but is designed for RUG, and in the Acura they admit it!
reminds me, I just read the latest issue of Road and Track this week. Had a great article about the fallacy of 0-60. Basically explained why the magazine #s are bogus, in terms of you would never be able to clock them, and why it is also somewhat meaningless to compare.
nickle version, they all factor in 1' of rollout so in effect car has a running start. and of course, the abuse the snot out of them. Author said that the best "street" test comparison is actually the 5-60 one that C&D started doing a while back. That takes the abuse aspect out of play, and approximates how a car performs in real world driving. they had examples where stuff like an Odyssey would dust a WRX STi. Largely due to turbo lag and delays getting spooled up in some cars. Gearing, how quick the trans responds, stuff like that all came into play.
he said that the 5-60 is roughly what you get if you start the clock after the rollout. Not quite sure I followed that, but it is how they calculate. In any case, more important to me since I am never going to brake torque or clutch dump my own car. Let it get moving off the line, then floor it is more likely.
Cash or third party finance is zero incentive, just like the 0.90% APR
https://forums.edmunds.com/discussions/unanswered
WAGs not really helpful..
The size and utility of the Enclave is what we need as a family vehicle (especially now with the campground home) but I’m just not a fan of driving it.
How about "I Don't Like Sedans - Why Do You ?"
I'll give you $2,000 for it.
In some ways I prefer the alert (with no steering assist) in the Buick to the full on corrective action the Volvo takes.
I do like blind spot warnings, though. I also have that on the GTI.
