Ross
1) Pushing a trailer up a 45 degree incline in reverse gear both my trooper and my rodeo came to a stop when pushing my 3500lb boat trailer in reverse up a very steep incline. I attribute this to the reverse gearing, not the 4wd system.
2) Pulling a heavy dock out of the water a few weeks ago with the trooper in reverse. Same problem, it cam to a halt. I think this was due to the reverse gearing as well, cause I flipped it around and didn't have a problem. Tried again in 4wd lo in reverse and didn't have a problem there.
Other than those 2 situations which involved reverse, I've never needed to use 4wd lo on either of my trucks. The few times I got stuck in snow with them, 4wd lo did nothing to help the situation.
-mike
Off-road adventure(s) - I would love another opportunity in a M113 to tackle places like the Rubicon, but a one-horse-power 4wd kind would do just fine.
I would not put it number one on my priority list, though. A 5 speed automatic would definitely come first, as would a more powerful engine.
-juice
-mike
-Frank P.
But never mind all that - I would like to see better towing capacity, not just class I. So give us a 5 speed auto with a tranny cooler and beefy brakes, for class II towing.
A low range would then be gravy!
-juice
PS I'll miss the chat tomorrow night - we're going to Disney World!
Why 4000? That would make it Class III, and would then require the larger (beefier), Class III tow hitch receiver, like the one I have on my Explorer.
Bob
-juice
Bob
If paisan's web page was working, I would post a link to off-roading RS's and me. Mike, if I went down that steep hill in the Pine Barrens a lo-range would've come in handy (the one where you, me and the All-Trac went up). OTOH like Frank and Ross mentioned, an auto is probably better in situations like that. So for manuals, a lo-range would be helpful.
Here are some off-roading OB's:
http://www.toad.net/~rrubel/outaction.html
Dennis
-mike
-Frank P.
A higher first gear would be good for steep hills/dunes, whether you're going up or down. Better approach/departure angles would come in handy for these situations too.
Subie owners do tow. Lots of people come and ask if Outbacks can tow their trailers that are just a tad over the current limits. I tow, Bob tows, Hutch tows, and the photo above shows an Outback at the beach with a trailer (behind his dual-range Aussie model). I think it would be even more common if the limits were higher.
Bottom line is the AWD system is so capable, that people wish the rest of the vehicle (clearances, approach and departure angles, break over angle, and gearing) were as well suited to the rough stuff.
-juice
I'm with juice. Give me a 6-speed manual tranny with a tad lower 1st gear and I'm all set.
Ken
Ok, I'm with juice too. Bring over the 6-speeds, build some 5EAT's and don't forget the sport-shifter!
Dennis
It's not the 2.5l boxer engine nor the tranny that is the reason for such a low towing capacity. It's the brakes, and chassis.
-mike
-mike
My Australian spec 99 OB has a Dual Range transmission. Low ratio is only about 20% below normal but this provides significant extra grunt for pulling trailer away from a dead stop. I tend to use it mostly for towing. Probably used less than 1% of the time.
It probably got its heaviest workout this last weekend in entirely mundane suburban setting, believe it or not at the four year old's kindergarten. One guy turned up with a large trailer which was filled to brim with logs to go to the tip (probably dump to you guys)
His wife went into labour half way through leaving me to haul the trailer home to his house a kilometre away. It had to be manouevered onto his lawn over kerbs and past trees. I have no idea of the weight but it was seriously heavy and I would not want to tow it at highway speed. The dual range and self levelling rear end really came into their own though as I had no problem hauling it or backing it.
Realistically, the Outback is a very good road car with light off road capability. What you interpret as light off road is very much a personal perception. I grew up in the bush and think of light off road as "Car does not fall down ravine" and you can wade through the mud without a hovercraft. For others, the same phrase means "Bitumen is cracked". I can recall amusing responses when explaining that my Toyota Corolla Twin Cam almost floated away on river crossings on our honeymoon. For us, that seemed normal. In urban England, the presumption was that I was subjecting my wife to horrendous danger.
The dual range is useful for my sort of driving and very good for anyone towing a serious load. It is used in most non-US markets but guess it is just not fitted in the US for cos reasons. Beats me why given the tooling cost has to have been well amortized and mraginal cost of manufacture has to be minimal.
Cheers
Graham
IMO, our best chance of getting it will be in the ST-X.
Thanks for the info and story Graham.
Dennis
-mike
Bob
The hitch itself bolts on with 7 very sturdy bolts, right to the frame. Some non-OE hitches use as few as four bolts.
So it seems the frame and brakes, at least on the S model, are ready for more.
The next Forester will inevitably gain weight, so I could imagine a 3500 lb trailer would be about the upper limit for it.
-juice
-Frank P.
"The Outback and Outback Limited are powered by a 2.5-litre engine that produces 115kW of power at 5600rpm and 223Nm of torque at 3600rpm. .. The dual-range five-speed manual has a choice of high or low ratios. For everyday the high ratio will suffice, but when the going gets tough you can switch to the low range"
Dennis
Yes, my Outback is a 2.5l with dual Range. i can't see that a six speed would actually do that much given that the Subaru engine is so flexible. They only really work with engines with narrow power bands.
Now an off topic query. My 4 yo (the future tech-head) has changed some setting in Internet Explorer so that every window after the first one opens minimized. I am not sure whether to be impressed or irritated. Does anyone know how I can get the subsidiary windows to open at normal size?
Cheers
Graham
Works for me at work... but that's Windows NT... wierd within itself!
Cheers!
Paul
...at 6-7pm Pacific/9-10 pm Eastern. Hope to see you there!
http://www.edmunds.com/chat/subaruchat.html
Drew
bit
Cheers, Tom
The car that saved a life
On Monday, May 14, my daughter was involved in a horrific crash on her way home from work when a car traveling north in the south-bound lane of Route 128 slammed into her Subaru head-on.
Scott Scimeni of Subaru of Wakefield had promised us a safe, reliable, and sturdy vehicle when we purchased that car and it certainly lived up 110 percent to that promise. Her seat belt with shoulder strap, functional air bag, and the fact that the Subaru Legacy was able to stand up under a crushing high speed impact without collapsing into the interior of the vehicle allowed her to survive. Thank you Scott and Subaru of Wakefield for your honesty, integrity, and quality of product.
Sincerely,
Bob MacDougall
Not that the dealer does much about the quality, but I guess you can compliment them on having the sense to sell a great car.
Kevin
PS I don't think I'll be able to make it to chat tonight. hope to sit in again next week.
They were headed to Disney World, and were taking the same plane that my family members were getting off of.
Thought I was in the Twilight Zone for a while there...
Bob
-Greg
my personal record is getting from Orlando to Philly in 1 day (loooong drive though)
Cheers!
Paul
Drew
bit
he will tell you the part number and the price. you could then punch the part number into subaruparts.com's online pn lookup and price compare-- I've done this myself. I bought more parts from Ryan though.
(he probably won't reply until next week, natch.)
-Colin
bit
Currently I'm in Ann Arbor, MI. Made it out from Allentown, PA to Ann Arbor in 8hrs flat. We watched office space, and 4 episodes of the sopranos on the way out! Then today drove out to grand rapids michigan and back.
I like the 70mph speed limit. I cruised at 82mph the whole day. And coming across PA did one stretch @ 90+ with the cruise control on. Ohio though is full of cops so no more than 10mph over the limit there.
-mike
