I hope you enjoy the weather, Steve!
Left the Miata at home today. RWD + summer tires = LOL.
Could you send some of the snow and ice our way?
42 C (108 F) here yesterday. My pumpkins curled up their leaves but seem to have recovered.
At this temperature, tarmac melts.
Cheers
Graham
Cheers Pat.
Worse still, it is 46 C (115 F) in Sydney now, an all time record. Sydney is usually more humid than here so peak temperatures are rarely as high as Melbourne.
Send us some snow!
Cheers
Graham
Actually hot enough for car window glass to shatter
http://www.abc.net.au/news/2013-01-18/heatwave-smashes-australia-shaped-hole-in-- abc-car/4471652
There is something prosaic about this one smashing in the shape of Australia
I can hear a cold beer calling me.
Cheers
Graham
Being an insurance adjuster, is that something you're involved in Graham?
Bob
The bushfires are a real problem. A large one near my home town has caused major problems. Two groups of friends had to evacuate in the middle of the night, although only about ten homes have been burnt. The shift in wind has now sent it deep into the Australian Alps where it could potentially burn for weeks, as we have a sustained dry spell forecast. It is country I know well from walking and ski-ing, but is very, very rugged. The only thing that puts out these sort of fires is sustained rain. We need about 10-25 points to douse the fires.
Last time this happened in this area in 2003, there were 2,000,000 hectares (20,000km2) burned. These fires are normal for the Australian bush, with a lot of the plants relying on periodic fire for germination (there are some seeds which need intense heat, or soaking in smoky water to germinate). The countryside is glorious, with soaring trees, deeply folded gullies and sub-tropical forests.
However, where you get people living in these beautiful areas, there is a real problem. I am currently involved in several major law-suits about bushfires from 2009. Also dealing with some of the current claims. My wife always claims that Loss Adjusters are like Undertakers, revelling in the misfortune of others.
Cheers
Graham
It makes access better if you remove the air box on the passenger side, and I was changing the air filter anyway (it was dirty).
For the driver's side I removed the battery, also for better access.
The good news is now the plugs angle up so it is much easier than before (98 model).
The plugs were clean and could have gone twice as long. ATF clean, actually all the fluids were.
Can you believe just 30k miles in 5 years?
I also replaced headlights, cleaned the air filter, and did a few other misc. things in addition to the oil change. I need to make sure I replace the brake fluid next summer... have you done that yet on yours?
The brake fluid was clear, I will rotate the tires soon, and maybe bleed the system when I do.
I also had to remove wheel locks from the Miata, without the key! Bang on a 19mm socket, remove, use a punch to get it out, repeat 3 times.
Dealer never gave me he key and still hasn't returned my email.
These instructions were useful and accurate:
http://youtu.be/1iInTi7Apgk
On a vehicle note, the Monster truck has been doing weired things shutting down all electricals when the ignition gets turned off and doing nothing when you try to restart , only to revive spontaneoulsy at some later time. Battery was brand new and fully charged. NO Fault Found after 3 days at the dealer. They did replace the battery connectors which they said were a little corroded. Will see if it works. DW refuses to drive it for fear of being stranded somewhere in our balmy sub-zero temps. Do not want to replace it - hard to find low mileage three quarter tons and they are $$$$ when you do. Plus the new ones have less cargo and towing capacity than ours - they eliminated the 8.1 engine with the new body style.
On another note ... the Sunday Auto section of the local paper had a very nice feature write-up on the 2014 Forester. I was almost drooling at the specs of the turbocharged XT ... 250 hp 2.0 dohc with automatic SI-drive ... I can almost see myself in one.
Bob
I'm not sure I'd be brave enough to even try!
Yup, blizzards ... hurricanes ... floods ... I'm usually in the GT or Outback while the sane people are at home!
Cheers pat.
http://youtu.be/yNvyFMlvumk
Overall Lexus was 1st, then Subaru and Mazda tied for 2nd.
Yeah ... kinda forgot about the hail, although I do think about THAT day when I wax it. There are still a couple dents in different places. I'll say one thing, I do absolutely love that car! And miss it.
I'm driving a 2012 Ford Fusion for a rental. Not a bad car, really. The interior is sort of plastic-ey and the dashboard looks sort of cheap. I hate where the temperature control knob is - I have to reach out and lean over to get to it.
I do miss the 'beauty of all-wheel drive', especially today driving in/out of a snow storm to work. FWD is not the same. Hate the feeling of the steering wheel twitching every time a tire breaks loose. And I don't have heated seats ... heated mirrors ... heated windshield wipers ... 250hp turbo ...
Part of the problem is I do so much aftermarket stuff to them it is like letting part of myself go. Like in the Mazda3 I have now I just recently put a complete Katzkin leather interior in it, including the door panels. Installed it all myself. When I bought the car I didn't like the factory leather so I held off on that. You can bet this car won't be going anywhere soon, It puts a smile on my face everytime I get into it.
Cheers Pat.
Pat.
Cheers Pat.
He thinks he wants the Samsung Note. I want the Samsung Galaxy IIS - or whatever they come out with by the time he decides to actually buy them!
I pay $10 every 4 months ( Page Plus Cellular ) and have a $128.69 (~1286 minutes) balance built up after almost 6 years.
I'm thinking about this for my daughter:
http://www.republicwireless.com/
The $29 option with the $99 smart phone.
She'll be the last 8th grader in Potomac to get a phone BTW. :sick:
All she really wants is to text and personally, I'd keep a 14 YO off a smart phone.
A 2nd line adds about $45-50 a month, then the 3rd one wold be cheap but we don't need it yet.
http://www.pagepluscellular.com/plans/
You can use any Verizon branded phone except for ones that are specifically sold for Verizon prepaid. Ask family, friends, co-workers if they still have their pre-upgrade Verizon phone laying around.
Which network do they use? Verizon's?
Funny, they're based in Ohio. All this time I thought they were an Oregon company.
....you're stuck!
Good "problem" to have, I suppose.
This past Saturday I sat in the audience as a proud parent as my daughter's team of 4 kids represented our H.S. at the county level competition of World Quest. They placed 4th of 12.
They gave the audience sheets so that we could play along, and after 4 hours and 100 questions, my head hurt!
http://www.worldaffairscouncils.org/2011/main/home.cfm?database=programs&Categor- y=AcademicWorldQuest&Section=Academic%20WorldQuest%202012%202013
If your wife has her own plan, you can make it a family plan for $10 and add unlimited plan texting for about $10.
Trust me, once a kid gets a phone and starts to text that's the easiest way to reach them. Our family communicates via text constantly and my wife and I both use texting for work. Last month usage was me - 819, wife - 350, my MIL - 12 and my 10th grade son - 4390!! We will be adding my 7th grade daughter and that'll probably add another 1000 a month.
Another choice is a prepaid T Mobile plan. That's what we have my daughter on and each text costs her a dime. After a while she started to become aware of her usage.
Are you sure? Last time I asked them the cost jumped up a lot more than that, but I think it's because I'm including a data plan for a smart phone.
We have invested much in time, talent and treasure over the years for my oldest, the athlete, and my 2 youngest, the musicians.
Kids and parents alike reap those rewards.
