Visitor Agreement.
Looks like "the guy" may have screwed up. It's such a joy to pay someone to do it wrong when you could have done it yourself in your own garage for the cost of the oil and filter (plus the copper [or whatever] gasket).
Nothing really that we didn’t expect. 2.0T power train (less HP but more TQ than the 3.5L V6 is replaces). A-Spec stays, S-Type is added with 3.0T twin scroll turbo. Double wishbone suspension returns. Longer, wider, lower. RDX interior redone to fit in the new TLX. Will hit showrooms around November. S-Type won’t be here for another year, give or take.
MSRP
-about $35K for the base model
-$40K for midrange model (Tech, SH-AWD)
-Probably low $40K for A-Spec
-$50K for S-Type
-I would imagine adding $2K more for SH-AWD to any model (standard on S-Type)
I can’t imagine I’ll be interested in the 2.0T. If the S-Type comes in with significantly more HP and TQ than my Stinger, I would probably be interested, especially if the Stinger is pulled from the market.
For c.$35k the new TLX seems like it will be a great car for the money, and that would actually be a price cut of about 2k compared to the previous base V-6. And the TLX will still be about 10k less than a comparable BMW 3-series, but the TLX will have a bit more power than the base 3-series now.
pros
+new double wishbone front suspension
+electro servo brake system from the NSX
+style
+power
+interior
+even more safety (new airbag design and improved body structure)
+255 performance tires even on base model (!?)
cons
-The car grows 3 inches in length and 2 in width, and yet because it's lower has about the same room inside as the current car. My current TLX's size already feels just right, and it fits into my garage. I'm not sure the new one would fit in my garage. I think for length I might be ok, but for width no so much.
-all wheel steering is gone. I like PAWS a lot.
I also like the 8-speed dual clutch transmission, and the fact that I can get in the high 30s for highway mpg. Add the turbo and those 255 tires and mpg seems likely to go down a bit compared to the 2.4. Overall, I'm planning to take the buy out on my current TLX, but since that's a year from now I'll probably take the new one for a test drive just for the heck of it.
Acura's official info on the 2021 TLX:
https://acuranews.com/en-US/releases/all-new-2021-tlx-elevates-acura-sedan-performance-with-turbo-power-dedicated-platform-and-expressive-styling
Kind of surprised they didn't drop the V6-electric motor hybrid into the TLX now that the RLX is going away. That's a good bit of tech and R&D that seems under utilized.....maybe too much money to manufacture?
The engine choices now mirror what's offered in the European offerings and IMO the styling is really sharp and distinctive. I find the current A spec very attractive and it seems to me they sort of used that as a starting point for the new model (understanding they still have an A spec).
The new proportions may not add additional practical space, but that's not really what sells these cars - the lower, wider, longer look will bring buyers into the showroom...well, maybe into a virtual showroom where you can work out all the details remotely and then have the car delivered to your door by someone who never laid their actual fingers on the steering wheel.
2025 BMW i5 - 2017 911 C4S - 2024 VW GTI - 2026 MB GLE450 - 2024 Genesis GV60 - 2019 Cayman
Not that there will be much suspense - I'm sure it will follow closely the styling cues of this TLX and the RDX, which is a good thing.
And so it's basically brake by wire?
From the Acura press release....
"The 2021 TLX is a sport sedan at its core, built on a new dedicated Acura sedan platform designed for Type S-levels of performance. The new chassis heralds the return of double-wishbone front suspension to Acura's top-selling sedan, offering more precise handling and cornering grip, as well as greater mechanical compliance for improved ride quality. In addition, the TLX chassis incorporates multiple new performance-focused engineering upgrades, including a variable-ratio steering system, electro-servo brake-by-wire technology applied from the NSX and an available driver selectable Adaptive Damper System.
The TLX's all-new chassis is anchored to an advanced new body structure — NSX aside, the most rigid ever offered on an Acura vehicle— delivering a 50 percent increase in global torsional stiffness and up to a 100 percent improvement in localized rigidity where the suspension is mounted to the body. The new structure uses 56 percent (by weight) advanced, lightweight materials, including aluminum and press-hardened steel, more than any previous Acura sedan.
An ultra-rigid new center tunnel serves as the backbone of the TLX's higher structural rigidity, complimented by triangulated front shock tower bars, front and rear underfloor braces, a one-piece rear bulkhead stiffener and new cast-aluminum front shock tower mounts. Front-to-rear weight balance is also improved by an extensive use of aluminum, including the front bumper, hood, front fenders and front damper mounts, in addition to locating the 12-volt battery in the trunk.
NSX Electro-Servo Brakes
First developed for the second-generation NSX, the new TLX utilizes a highly sophisticated electric-servo brake system. This system allowed Acura engineers to finely tune the brake pedal force and electronically control the brake pressure to optimize the vehicle's performance driving characteristics.
For the TLX Type S, multiple hardware upgrades will improve braking performance, including larger discs and four-piston Brembo® front calipers complemented by performance-focused tuning of the entire braking system."
I’d have to have an earlier one with the full touchscreen setup.
https://forums.edmunds.com/discussion/61474/subaru/forester/hit-or-miss-with-a-2014-subaru-forester#latest
That’s why I get my hoopties when they’re about 18-20 years old before anybody else wants them. Of course the cars that I like might not be collectible no matter how old they get.
I do like that V60.
Maybe the accident on auto check is hurting the price
https://www.cargurus.com/Cars/m-Automotive-Avenues-sp282518#listing=258335097
I may take the BlueDriver scan tool over there over the weekend and see whether it picks up anything.
Sounds expensive.
standard hybrid, 33 MPG combined rating. And has a 1st class recliner seat option (with ottoman) and you can get a built in fridge. And the interior looks great. But that maw!
https://pressroom.toyota.com/toyota-launches-all-new-2021-sienna-to-suit-a-variety-of-lifestyles/
