Dodge Dakota: Problems & Solutions
robert
Although the idle problem are addressed in this flash of the ECU.. there is also a 4 degree retard of the ignition timing too. (To reduce pinging under load that some people have experienced)
This retard of timing will ABSOLUTELY reduce the peak horsepower of your engine. The advertised HP when you bought it will no longer be. Expect 5-20 HP loss.
My 4x4 Quad Sport has developed a loud squeaking(not popping) noise that seems to be coming from the front suspension. I can even stand on the step bars and make the truck make the noise. It normally occurs when going over bumps and it is loud enough to hear over the engine noise, particularly at low speeds. I have 33,000+ mostly road miles on the truck that was delivered March,2000. I've enjoyed the truck so far but I'm starting to get a little nervous. I will be calling the dealer next week to set up an appointment, but I would appreciate hearing from any of you who have had similar problems. Were they corrected satisfactorily?
I read all the posts in this folder and used bpeeples' links (thank you) to the NHTSA site that contained the TSBs and Recalls but I wasn't sure if any applied. Number 130100 might apply. Should I mention this to the dealer? I would appreciate any help.
I too have had problems with the brakes developing a pulsating feeling when the pedal is applied. I will ask the dealer about this but I realize that the truck is nearly out of the 36,000 mile warranty and they will probably do nothing.
I bought the truck at a dealer that is about 100 miles from here so taking it in means taking off work for a day. I would like to be prepared when I get there and would like to be well armed when I hear "Oh, that just a normal sound for this model." In other words I don't want to have to make several trips. There are other Dodge dealers nearby but I assume they would be reluctant to work on the truck if I didn't buy it from them. It this a good assumption? The dealer I bought if from prides itself on its service department. I guess I'll see.
Any input would be appreciated.
Mailman
The brakes are technically only waranteed for 12 months!!!
(not the 3 years as the rest of the vehicle is)
Bookitty
http://www.nhtsa.dot.gov/cars/problems/tsb/servicemmy1.cfm
BTW, at the NHTSA site the vehicle make is "Dodge Truck". Entering "Dodge" only will give you the listings for cars.
JimH
I am not aware of the timing being retarded 4 degrees. I notice no loss of power or gas mileage. THen again, I never had pinging problems and I never use cut rate gas. Keep this in mind: Just because it says Sunoco, Exxon, or whatever, is NO guarantee that you are getting branded gas there. I saw a cut rate tanker once fill up and AMOCO station back in Indiana, where I grew up. I called Amoco and was told that each station was independently owned and operated and therefore free to use whatever bulk gas supplier to provide gas that "meets" the specifications of the parent company.
Bottom line, you may not always be getting what you are paying for. Problem is, how do we prove that? What exactly differentiates Exxon Amoco, Sunoco, or Gulf gas from cut rate gas?
As far as gas, I agree fully. I have had NO pinging, and use only Chevron or Citgo (known home stations) 87 octane, except for a tank or 2 of 89 to deal with my idle issue.
I will post results of the TSB PCM issue once i can educate my service manager on how to research his own bulletins :-) based o my education from this forum.
Thanks again for the info.. Please let me (us) know if anything changes with your idle now that you have had it changed for a while... i hate recurrences.
Bill
www.fast4x4.net/fuelpumpkill.zip
Let me know if anyone has any questions or wants to build one.
Bookity
TSB # 212099
NHTSA Item # SB6089792
Bulletin Sequence # 608
Date of TSB: 9911
TSB is applicable to the 46RE Auto Transmission
I have the 45RFE, my pop had an Intrepid, I once had two INtrepids and all those vehicles made the same noise.
SInce then I have upgraded the lousy stock air filter with a K&N filter. I now get one more MPG in town, and two more MPG on highway (around 19 MPG at 70 mpg with AC on).
Again, I would advise you literally ride with the service manager, get the truck up to operating temperature and go thru town and see if it will stall out. Bet you a million bucks if he rides with you he will see what you are talking about.
Bulletin Sequence Number: 608
Date of Bulletin: 9911
NHTSA Item Number: SB6089792
Make: DODGE TRUCK
Model: DAKOTA
Year: 2000
Component: POWER TRAIN:TRANSMISSION:UNKNOWN TYPE
Summary: SUBJECT REGARDING 46RE TRANSMISSION SHIFT QUALITY IMPROVEMENT FOR A DRIVE - REV -
DRIVE SHIFT MANEUVER. *TT ******this only applies to the 2000 yr dakota.*********
All seemed well until this past December, when after a couple rainy days there was 2-3 inches of water, this time on the passenger side. The carpet pad is soaked and I'm sure it's getting wet every time it rains, but it might not be showing through unless it really rains. The dealer doesn't want to fix it, claiming my after market front speakers caused the problem (installed during the time between the first leak and the carpet being replaced). The installer put in the rain guards just like the originals, and I had the truck back to them after the dealer blamed them so they could test it out themselves. Physically, there is no way the water can come in through the speakers as the dealer claims. Also, the speakers are mounted on MDF, and if you know what MDF is, you know it swells to twice its size and falls apart if you get a drop of water on it. Well, no sign of ever being wet. That totally shoots the dealers theory down. They are just looking for a way to blow me off. Unfortunately, the dealer will no longer attempt to fix the leak, since they are blaming it on the stereo guys. Anyone have any ideas or other experiences similar to this?
Drive Safe,
Joe
Have no idea where the drain tube is on a Dak but I know that the AC on my '00 runs all of the time and the I hear the sizzle of condensate dripping on to the exhaust when I park it - mostly summer when higher level of moisture in air. You would have higher moisture in air during your rain storms. Just an alternate idea.
just had some put on and it looks horrible...
Only use Mopar type 7176 ATF+ as the fluid in your trans. Even if its a pint low or something, DRIVE 20 minutes to you dealer or another Dodge dealer and get the proper fluid. DO NOT use Dexron fluid of any kind (ITs spelled Dexron not Dextron)
Why? Dexron fluid is a "grabbier" fluid. It will cause the clutches to tighten up severely and then the trans controller will back off the pressure. The fluid will then make the clutch packs grab and then the cycle will repeat itself over and over and over. WHat you will feel is a shudder on upshift or down shift, either of which is BAD news. Don't trust the local yokels to use the right fluid. I've seen for myself some of these places use whatever is "in the can" with no regard as to what really belongs in your transmission.
Don't fall into the mindset "Its all the same stuff, it don't matter." I know way back on the 727, 904 and baby 904 you could use Dexron (not Dextron) and it was fine. But that was then and this is now.
Proof positive: Neighbor had a full size Ram 1500 with the 46RFE trans. Did his own fluid and filter change. 3,000 miles later, he is bitching up a storm that his tranny doesn't shift right and it won't shift into lockup. Brings it over to me. I tramp down to my local mopar dealer, get the 7176 ATF+ fluid, a filter. Go back, dump the old stuff, run the new, proper fluid in it.
That was two years ago, my neighbor still has the truck, trans shifts fine and no more will he go to Wal Mart to get "whatever" looks like trans fluid.
Part two: Same situation but Uncle had a minivan. Took it to the 19.95 grease lube station in town. The put Dexron (not DEXTRON) in the trans. 1200 miles later, time for a new tranny.
DOn't let ANYONE [non-permissible content removed] you on this. I am dead serious. For more information and more technical stuff, go to ALLPAR.COM and head for the transmission section. Read the other stories there. Then commit it to memory: Use 7176 ATF+ fluid in your mopar trans and it will go thousands of miles for you.
Do you agree with that statement for the multispeed mated to the 4.7?
srn
The fact that you are getting lights on either side from activating the lever indicates that there is some contact there. Check the "flasher can" by using another if you have a spare, or try the can from the four ways. The wiper problem could be the motor, which can be checked out by applying current directly. If you don't know how, find someone who does. Good luck.
Bookitty
I have a 2000 qc 4.7 4wd and my mileage is about the same as yours, suburban driving. My truck has the full time 4wd option. From what I have gathered from this forum, that has some significant effect on your mileage. I don't know if your truck has this "feature", but I don't think that mileage is too far out of the norm for what type of drivetrain I'm operating. Perhaps some wiser ( or at least more wizened ) heads could chime in.
I HOPE my truck isn't too abnormal ;-)
drive safely!
scottie
Best Wishes.
so far my dealer and my DC rep has been fantastic. they even asked me if i was going to try and do a buy back and i decided not to. i love the truck, dont want to pay the difference because of milage and they have handled and have promised to continue to handle any issue. yippieeeeee!!!!!!!!!
ill update all after new rear is in, good luck all.
Robert
I CANT believe i have to go thru this much trouble for an idle problem, but I am getting tired of this annoying and embarrassing condition... you know.. wife or friends in the rig.. SMOOTH acceleration... awesome highway performance. then.. I slow to a stop and rumble\rumble\chug\rumble\ etc.. away goes the smile :-(
Question 2; On the TSB, I will dig out my old work order on that or if I cannot find it, then I will contact my service rep at Preston Dodge and ask them for it and send it on to you on this board. For the life of me, I cannot remember what the number was, but will find it.
When you get the TSB, go into your dealer and if need be, just be a total pain in the [non-permissible content removed] until the service manager plops down in front of his computer and looks it up. I am shocked and disappointed that your dealer has no knowledge of this. Sounds to me like they are playing your fiddle in the hope you will go away.
Just thought of something, where do you live? I live in PA and perhaps it is a cold climate thing. If you are down south somewhere, perhaps Chrysler never thought that this would affect warm climate drivers? Just a thought.
This is something I hope to clairfy. Like you, I have no problems now that the AIS motor was replaced and the PCM flashed. Prior to that, my problems were exaclty like that of what ashasher described.
Perhaps your sources were refering to the cutting of the injectors during decelleration. This function was implemented for several reasons
- Reduces raw fuel getting into the catalyst.
- Improved engine-braking
- Better MPG
- Reduced backfiring (Backfiring is burning fuel in the exhaust manifold)
The injectors are turned back on around 1000 RPM. This can be felt under some conditions as one decellerates and the RPMs fall below 1000.
