Visitor Agreement.
have had 2 sets of rotors warp and rear drums.
I only have 20K on the truck and I am very disgusted with so called 5 star dealer. They tell me the problems are my fault that I drive the truck to hard, and in the same breath they tell me my pads and shoes are like brand new, I say this should show that I am not hard on my truck. They respond with I must have changed the parts. Also the drums are warped because I apply the emergency brake when parking
the truck. Apparently you are not supposed to use your emergency brake. I spent months arguing with damit-crimesler and got nowhere. I have ordered and received Power Stop high performance rotors and pads for the front and had drums turned. We will see if this fixes the brake problems. It is sad that dealers will not admit to the problem.
Even sadder is the fact that damit-crimesler does not upgrade the brake parts or specs, this will come back to bite them just like
the Firestone tire issue. This is my first and last DODGE it is too bad that the treatment you get will prevent you from buying another Dodge car/truck/van.
Sorry to hear about they problems that you are having. I know from reading this board that I will someday soon have to purchase aftermaket rotors due to the poor quality of the OEM units. Fortunetly, I knew about this before purchasing and decided that it was a small price for an otherwise great truck.
Let us know how the new units perform and if it helps... your not alone.
blue
I know my 97 rotors (OEM) did okay. At 40K did a brake job and replaced one because it got a bit too grooved from the rivits in the pads. (Went a few too many miles before taking it in). So I guess the newer ones are worse.
I know when the time comes up for brakes I will be looking for high quality rotors, pads and calipers. One thing I have noticed on all my mopars from 87 on is that everytime I need a brake job the calipers get replaced too. This should not be happening if they were of decent quality.
I agree that the manufacturers need to listen to the customer. In industry it is known as Voice of the Customer (VOC). I just received my initial survey from Chrysler for my 01. There will be a detailed attachment going with it. The truck and sale went well but as usual, the dealer prep was nonexistant. They even left labels on that should have been removed (especially the "Suspect parts" tag that was on the headliner) and even the tires were grossly overinflated (48 lbs mounted and 52 lbs on the spare)
I say that we, the customers and clearly from these forums, the most vocal that we use the dodge website to relay our feelings. perhaps send them links to our postings so they see the stories and see it from what the customer and potential customers see.
My professional experience is in QA so it frustrates me when I see companies that seem to fail to act on customer input. Sure they started to add "style" but lets get the substance straightened out. I for one am a mopar man. I would hate to have to look elsewhere the next time I need to get a vehicle.
I just found out that there are fuses on my Dak that can only be bought at a Dodge dealer. So if I have my trailer brakes go out or my AC on a weekend, I am out of luck. The price is fair, but the limited access sucks. The fuses are in the power center under the hood.
BTW, if you have a tendancy to blow fuses than you have a problem somewhere that should be traced down and corrected. Fuses blow for good reasons.
Electrical problems are a pain in the neck by themselves, let alone what they could do to the PCM.
BTW, my truck just started showing signs of stalling at cold accellerate. I'd hoped I was free and clear, havent had the auto tranny "learning problem" (at least not yet, 5000mi.)
Any reccommendations for rotors and other brake parts for when my truck decides to do the "brake shimmy"?
scottie
I currently own a 2000 3.9l 4x4.
Here's my question. 1. When I make a sharp turn there is a loud popping noise on the passenger side floor board. The noise sounds like metal against metal. My dealer is telling me it is normal. (Maybe they think they can fool me because I am a women)Does anyone else have this problem and if so, what could it possibly be.
2. While I am driving, there is a low rattling coming from somewhere under the truck. I asked the dealership to take a look at the exhaust manifold to see if it was loose. They told me it was fine and they could not duplicate the noise I was describing. Could this noise be the catylitic convertor?
Bookitty
scottie
Bookitty
On the fuses, I will probably get a few to keep on hand, added to the box of the other style fuses and misc necessities. I have found that when you are working on an electrical problem, you can sometimes blow several fuses before you trace the fault. Since this is on the trailer brakes, I would not like to get caught where I could not get parts when I am 50+ miles from home. I think the original fuse was bad because when I went to hook up the controller, it was dead from the beginning and no problem after replacement.
Truck will be empty save for me, suitcase, fishing poles and Iron City beer (still in the case of course) for a friend that actually likes the stuff.
Total mileage from door to door is 443 miles 95% hiway. It will be cool so I don't anticipate using the AC unless to defog the interior.
First hiway trip with the K&N filter.
Last trip in winter to Detroit to visit the factory (and try to get a new truck, not successful) I got 16.55.
Actually went to HF museum for a tour. Lots of fun, recommend it to any car nut.
Probably won't be back for a week so no one start crying okay? Ha Ha.
Long Live Mother Mopar!
beachbunny - don't you love those "normal" pops and rattles. Wouldn't it be great if car dealers went to the doctor and they were told that their chest angina, heart murmur, and hip dysplasia were... normal..! I always suspect the suspension and steering when you hear pops on sharp turns. I had some rattling going on, only to find out that my spare tire was alittle loose, you might want to check that out too.
It will be a while before I catch up on the 15 Dakota forums I follow here at Edmunds.(not to mention MoparChat, DejaVu and all of the others)
Can I resume my role as the "resident technical advisor" for this forum?
Congrats.
bpeebles: Welcome home! You say you went fishing, but nothing about what was caught?
I'm gearing up to do some channel cat fishing this summer. And you can bet I'll be bragging about the catch....I hope. :-)
KarenS
Owner's Clubs
Bookitty
This is the second time my Dakota engine light has been on.... Some of the EEC (Evaporative Emissions Controls) hoses were nibbled clear through in both cases. Also one of my steering-rack boots was all tore up.
Who is this culprit that loves to nibble? I am told that the Porcupine can taste the leftover salt from the winter driving. He comes out at night and nibbles on all kinds of stuff.
I wonder if the warantee covers this...Perhaps I should have orderd the anti-nibbler option ;-)
KarenS
Owner's Clubs
I did a little investigating and found some suggestions to keep the critters away while wilderness camping. Placing mothballs around and under the vehicle "might" work. Encircling the vehicle with chicken wire, held down with logs or rocks, is probably a better solution. This prevents porcupines from crawling underneath the vehicle.
KarenS
Owner's Clubs
Bookitty
Heading down the mountain, sure enough, was a porcupine stumbling along the road like he was drunk and his hair was wet and matted down under his chin. It would seem that porc's indeed like salty things and chewed right through the brake line to drink the deliciously toxic concoction. Since it was night, I could drive OK because it was late with no trafffic and only minimal stopping was needed, but I did feel real bad for the porcupine, who probably didn't live long.
Drive Safe,
Joe
thanks!
mike
(I have had some vehicle frames rust so bad that they fail state inspection. One could "grab a handful" of rust from the frame and pull it right out from underneath the car.) No wonder it was starting to "sag" in the middle ;-)
The research by (KarenS HOST) may work too. I wonder if there is a "spray" like "OFF" for insects that may work to keep the critters away.?
Is the paint peeling from the hood? Con you hear the coolant boiling after shutting it off?
Were you running the AC compressor? Do you have automatic xmission? Under what conditions do you observe the "running on the warm side"?
There are a lot of reasons an engine may run hot... we must first determine if you are seeing somthing abnormal before getting too worked up about this.
Considering the age of the truck I would suggest a complete radiator servicing. A good flush and inspection to see if the raditaor may need to be rodded. Hopefully a good flush and fill with proper amounts of coolant and maybe a new thermostat as they do stick with time will prevent any real problems.
With an overhaeting engine this is how I usually proceed. Being that you see steam:
Change out the thermostat first, then recheck if the engine still overheats.
If that doesn't do it, then swap out the radiator.
Water pump if necessary.
Bob
I do not have my BOB right in front of me but I seem to recall that there is some kind of "feedback" from this fan relay to the computer which will trigger the check engine lamp if a problem is detected. (ie... fan should be on but is not running.) Certainly pulling the relay MAY trigger this fault.
Changd the oil to MOBIL1 5W30, and had to endure carpal tunnel getting the oil filter off after a gorilla at the dealer decided tight just wasn't tight enough. Tighter was better in his mind.
Saved the old filter and plan to have a conversation with the tech and the manager on why the "turn 3/4 to 1 full turn after gasket contacts base" instructions were not adhered to.
Now I am running without that relay, but the AC works, and the light still on. The QC is going in first thing Tue..
Thanks for the help!
In the process of getting mine off, I broke a plastic cap style wrench (from Wally World), stripped the hole in my dads METAL wrench where the ratchet extension goes, and bent his Plews oil filter wrench all to heck.
Finally I got really p.o.'d and stuck a screwdriver thru the thing and twisted it off that way.
biglucy you should have seen the gasket on the Mopar filter; it was mashed down big time. Wonder it didn't leak like a sieve!
Oh then there's the drain plug itself but I won't go into that. All I will say is the three beers afterwards sure tasted good!
A trip to Preston Dodge will take place this tuesday and guess what I will talk about (besides my brake drums)?
DBQUAD>>>>you should have an insert in your truck literature (a separate piece of paper) that specifically deals with the correct tire pressure for your truck. Yes, mine also shows the incorrect tire pressures for the tires I have on my truck 31X10.5X15
For my 2001 DAK QC it says 30 PSI for all tires...I run 33 as I feel 30 PSI is too low and will not give as good MPG.
The door sticker is for the minimum tire size the DAK can have
My dealer followed that info and had the tires at 41 PSI.
robert
Agree about increase of MPG as well
As for your question about fuses... Basic electricity knowledge teaches that fueses DO NOT protect from meltdown under all conditions.
Consider this... a 100Watt light bulb does not "blow" a fuse but will certainly get hot enough to melt things or start a fire. This is due to the RESISTANCE of the light bulb.
What happened to your Fuseblock was a POOR CONNECTION or RESISTANCE in an unwanted place. Fuses cannot protect from this type of problem which can easilly cause enough heat to melt things.
Those of you that have followed these forums for years will recall that when I first bought my Dakota, I whent through and snugged up ALL electrical connections. I also solderd all crimp-on ground connections. (Does anyone remember the infamous "ticking sound" of the early Dakotas with the 4.7LV8 Hemi?)
