Dodge Dakota Accessories and Modifications
Good Luck
stnick; how is the fold-a-cover installed?
Does it have a "frame"? Do I need to drive holes?
You can e-mail me direct, if you can give me a
good price?
trialsmm@hotmail.com
thanks,
mick
Also have the ARE CH model cap. No problems.
Anyway, my installer only used two rivets and some wicked adhesive to secure the rails.
The cover is GREAT, very versatile..
Oh, and just for kicks, 11.5k miles and no problems on my 01 4.7 4wd auto except it's insatiable thirst for fuel. Good thing the other car gets 45mpg, LOL! (VW TDi)
My 2001 Dakota,2wd, 4.7,auto,SLT,lim-slip,Quad
has 14,100 miles. No problems other than popping
front end/steering colume, side molding is coming
loose, cold starts are becoming a problem (hesitation). I'm making a list then take it to
my dealer in a few months?
Before 3 year warrenty runs out, I'll be looking to extend the warrenty to 7yr/75k miles.
I've been running AmsOil 5w-30 syth. Change the filter (AmsOil) at 5k and the oil at 10k. Will be going synth. in trans/rear end soon. (AmsOil)
I've got Bosch plat-4s in motor.
mm
bpeebles "Dodge Dakota Owners - Maintenance Topic" Jul 14, 2002 10:46pm
Chas
Just saying to check it out before you spend $200+ bucks like I did. BTW - the Catz fog lights are great and really yellow.
Again, maybe the garage I use for inspections is going overboard on its interpretation of the rules. The logical is sound but ...
There are a lot of tips and hints about "plus sizing" including the math involved to maintain the overall diamator within 1 inch.
You may wish to pick up a copy for yourself.
The one example of a sharp-looking 4-wheel type tire conversion (page 209) appears to be erroneous. The caption states that the starting size is a 33x10.5-15LT. The tire diameter doesn't match up with that section width. Anyway, the plus-sized combo looks great and uses a TOYO LT325/60R-18 on a 18x10 wheel and basically maintains the same overall diameter as the original. This 18" combo appears to have enough tire side-wall to handle anything that I would throw at it.
I've tried to cross-check the LT325/60-18's size by going to the TOYO website. They have it listed but don't have its dimensional specs but NITTO's LT325/60-18 has a 33" diameter.
Perhaps if you can determine this 'standard' tire size that matches the 31x10.5-15. You could then work from there.
In any case, unless you constantly carry 100s of lbs of weight in your truck, I would recommend you go with a "P"assenger-rated tire instead of a "LT" (Light Truck) rated one. The LT tires have very stiff sidewall to handle weight but this gives a harsh ride.
The "P" tires will handle the occasional trip with weight in the truck. Just add pressure to the tires and drive easy.
I know I will be going with a "P" rated tire when I replace mine. A softer ride is higher on my priorities than being able to haul a load of gravel 100s of miles.
Ron35
Ron35
Being the safety conscience "weenie" that I am, its nice not having to remember to turn the head lights on or off. I'd hate having this truck wrecked because someone didn't see it coming and pulled out.
Anyway, I wanted the DRL's on my Light Driftwood truck, which at times, blends into the color of the roadway. I know that I more easily see cars with DRL's so I wanted that for myself. No guarantees, just do what you can to improve the odds.
My main concern is 1. better output and 2. (of course) bolting to stock position.
ANYWAY make an impromptu stop at my local truck topper dealer and low and behold.. they have an after market light replacement kit. Made for DODGE air dam OEM replacement (they had RAM too), crystal lens, solid casing - H3 halogen bulb, wire harness and switch ( I have the factory wire and switch so it's lagniappe) and a mounting bracket adapter for the mount. 3.5 or 4 inch round diameter - whatever the OEM size is, I have to go back to be sure since I will be buying it today or tomorrow so i didnt open the box.
Now the best part - $89. They sell PIAA so i will compare quality of construction when I go to examine and buy, Then upgrade to PIAA H3 high output bulbs . Oh yeah they even sell the fog ION Crystal lens for the FOG use.. cant beat that
UPDATE on brakes and anti sway. brakes QUIET and solid.. seating nicely.. rust/dust? not a hint of either and we have had rain every day here. Sharp turns silent and smooth. no popping from the sway mounts..
Speaking about lights - Over the last two years, people have asked about going from the stock 55W headlamp bulb up to a 80W / 100W bulb. Anyone actually try it? What happened? Did the extra wattage / heat melt the headlamp reflector as some postulated?
Glad to hear that there isn't any meltdowns with the higher wattage lights.
Anyway, $105 at pep boys, 65$ install at meinicke. 65$ included extension piece needed as new muff is 23", old muff is 28", clamps.. Took em 18 mins total, then I went home, had 2 beers, and called it a 2 beer job. Ger.
Has anyone else just changed the muffler, say with a Gibson, Borla, etc., and kept on using the OEM tailpipe?
Sooooo surfing a bit over the weekend I made a discovery:
THE SAME lights (PILOT brand by the way) are offered by AutoZone for $57 - special order only tho. I checked the part # on my truck shop receipt with AutoZone - the same:
PILOT PL-119C $57.99
The amber set they had looked of good quality, not factory switch of course but a quite good one - not the typical rocker but a solid enclosed pod for on/off. Mounting is adaptable for DAk mounts. NOTE that these are 4 inch exact replacements that fit the air dam openings.
Anyone looking to replace OEM with better crystal lens/H3 bulbs check it out. Im getting one of each color since I want to switch to fog as needed. Also with the $$ savings I can get 85W H3 bulbs too.
stay tuned..
stay tuned.
p.s. why is it so quiet here?
But the installation was anything but simple.
Highlights: Pilot PL-119C 4 inch replacement lights. came with a mount bracket for DAK frame. after a couple of hours of attempts to find the right angle. I gave up.. The included bracket works but allows for light vibration and somewhat poor alignment in the air dam hole.
SOLUTION: got to looking at the removed OEM setup. GOOD bracket/housing combo with alignment screw etc.. USELESS light/lens. Hmm do i see a way around this? yep - remove the OEM plastic lens, trim the lip around the OEM light casing (remove from bracket first) disassemble the new light. The Pilot glass lens/H3 bulb assy fits almost perfectly in the OEM housing.. Took the pilot plastic housing and trimmed the back out. basically making it a sleeve with the mount holes intact. mate the new lens inside the OEM housing snug but fits. run the new wires out the back of the OEM housing (old bulb removed) slip the new trimmed sleeve over the assembly and screw into place. The screws hold the Pilot hardware together but secures it to the OEM piece very well.. Nice and tight.. LOOKS FACTORY. now the best part = took the 899 (#?) bulb and pulled the terminals out leaving the keyed socket with holes in the middle. Ran the new H3 wires thru the modified socket which mates to the OEM housing making a weather tight seal, used the Pilot gasket to seal the other end. Perfect match!
Now I have a hybrid OEM/Pilot assy now.. reinstall in original place, use original alignment screws to adjust and DONE! exact, and I mean exact match to the air dam hole and looks great!
Dig pix will be posted on my DAK page my Sat showing up close hybrid light assy.
Finished up by installing PILOT 720 projection fog lights. but thats another long post...
Are the Pilot PL-119C 4 inch replacement lights FOG LIGHTS?
Do the Pilot PL-119C 4 inch replacement lights come in YELLOW? (I find YELLOW fog lights are superiouer for driving at night in a snowstorm)
Are you powering the higher-wattage bulbs with the factory wiring? (No relay to provide direct battery power to bulbs?)
1-they are PILOT 4 inch lenses in BOTH clear and AMBER (fog) FOG part number is PL-119B. I installed the clear, which actually arent clea they have the refraction ridges in the inside like the headlights do.. so they look alike.
2- As i said, they offer FOG and driving.. however I got another model FOG projection lights in addition to these. (4 lights in the air dam)
3- I have 55w H3 where PIAA says 55=85. I was not comfortable with 100w since I did in fact use factory wiring/switch. Only the FOGs used the PILOT harness and fuses/switch.
I appreciate your asking and hope I gave you the right info you wanted.. LOL.. as i tend to ramble these days
I'l make an effort to get those pix posted.. close-ups of the before/after lights and basic installation shots..
P.S. it was a 6-pk job with a DRAFT/hotwing reward after
ANyway, its more fun than cost analysis and tastes better too!
