Dodge Dakota Accessories and Modifications
The accesories glossy proganda folder from Dodge does not include a price or part number. I saw one on a truck at the dealer a couple of weeks ago and the price was about $150 on the window sticker.
Do like the way these lights look. When off, they look like that combination of mottled yellow and purple you see on "aged" chromed motorcycle exhaust pipes. When on, the 55W bulbs blaze.
I have the Mopar sill guards on my Quad also,part #50(same catalog)they look and fit great.List for$31.00 for the Quad.Very easy to install.
Hope this helps.
Allen-
Do have to have an angled screw driver / nut driver device unless you take off the wheels.
Sill guard installation instructions read harder than it really is. Both the mud flaps and sill guards are worth the money.
I've read over tjump, jones27, teckno, and myersed's discussion but I desire more info on a rack system that I'll be able to carry either two canoes side by side or one canoe and one kayak. I'm concerned with putting two aluminum canoes (80# each) on the roof sheet metal siting on four little feet. Also concerned with the effect of the clips on the door's weather striping. I want to make sure what I do is right since some solutions require drilling holes in the roof to mount a rail. Finally, I don't want a "wimpy" system that moves around or worst yet fails and results in damage to the truck and/or allows the canoes to "take off" causing an accident.
I've looked in the MOPAR accessory book, I've looked at the Thule and Yakima catalogs / websites, even called Thule once. Still don't feel like I can make that painful $200-$350 decision. Advice / Experience Please.
For big canoes, you have a few choices.
1.You can do the Yakimas and trust the literature.
2. You can put on a shell/cap/topper, mount artificial raingutters to that, and do either Yakima or Thule (or any other) simple rack which attaches to raingutters. This is what I use for either many surfboards, 2 sea kayaks, up to 5 river kayaks, one biiiig lake canoe, lumber/plywood (be sane) etc. This is the 4th truck I've used like this and have never had a roof/rack/equipment failure, plus you get a dry space for your stuff or your dog. You can remove the racks for better MPG when you're not using them.
3. The Mirage rack is very nice if you don't want a shell or a permanent rack. Looks like a over-bed rack, but fold up or removes when not in use. Check www.cabelas.com
4. For serious carrying, there is really nothing better than a lumber rack. A steel tube, permanently mounted rack will have an over-cab section to protect your truck, can easily carry loads up to 20 feet long, and is probably rated up to 400 lb or so. The drawbacks are permanent mounting and wind resistance. Price is comparable to Yakima or Thule. They make these for trucks with or without camper shells. I put them on my work trucks and sometimes have them out on the weekends (don't tell the IRS). They also buy you the benefit of the doubt if you have to double-park...
Good luck and happy boating
Ben
steve234 - rather than me trying to find your old posting and the ladder rack company, could you just post it again?
Powder coated steel topper (black)
'Split' down the middle (left/right sides)
Opens like a gullwing for access to either side
Lockable
Holds weight on top very well
The trick parts:
Opens in the middle like upward swinging bar doors
And folds upwards to create 'sides' for tall stuff to fit between (in the bed)
Works as a double (two) canoe or kayak holder
Works as a ladder or other... holder
Says it holds up quite well - should for $600-700
Anyone familiar with this thing? Is it workable?
thanks in advance for any advice.
only complaint is that the lock mechanism is defective on mine in that i have found it unlatched twice in the first week even the safety latches worked themselves loose. i called the manusfacturer today and they are sending me replacements for the latch and the safety latches both. will let you know if this fixes the problem.
www.4ARE.com
heres the good link................sorry!
renegade69
Tire and Handling, Wheel Flares, Tinted
Windows, SLT & SLT plus, 2WD.
I installed an A.R.E. LSII Cover: Boltless-
install design. HD latching system, excellent
warranty. I ordered it with thier spoiler.
Looks Tuff, get lots of looks. If your truck
has the small wheels I'd think twice about
the wing though.
Check out: www.http//4ARE.com
There is a $20.00 coupon you can print out
and a dealer index to find a dealer closest
to you.
And I'm sure your curious about $$$$$
Cover Patriot Blue delivered and installed $670.00
The wing was an additional $300.00
If anyone is interested in looking at a photo
send me an E-mail and I'll send you a photo.
renegade@networksplus.net
renegade69 sorry so long....................
My guess is that he can get fender flares, just not already painted in the color you want. You can find the two tone paint code on the driver door. On the bottom right corner of the sticker is TRM and then some 3 letter code. This is the paint code you need when you order your fender flares.
You might try calling another dealer to see if they are more willing to order parts for you. Seems there was a post a long time ago about ordering the fender flares off the net below dealer cost. Someone who is better at searching the forum might be able to find it for you.
Can the tailgate open without unlocking the gulwing?
How much modification/sealing is needed to stop most/all water from entering?
I can not decide between a LeBra or the Total Access roll up cover.
What is this "gullwing" thing you all are talking about?? I thought I was up on covers and accessories for my QC, but this has escaped my attention!!!
recommend you look at the LSII. Boltless
design. 5 minutes and its off! The tailgate
cannot be lowered. The locking mechanism
is 2 heavy duty rods not a piece of wire.
Warranty rocks, lifetime on paint. Well
built too. I saw a guy lay his cover on the
ground and drive his truck on it! It did
not crack or break it. Lot of other great
features too.
Of course, to each his own......goodluck.
renegade69
bobyt876 - Mine won't. You'll need to 'pop' the rear lock loose to get the tailgate down. It's part of the security deal you get with this type of cover. As for water 'proofing': I'd suggest using side rail (sit on top) protectors available from lots of sources (most have been discussed here at some point) first. That's assuming you're using the factory (or similar like the Penda) bed liner. These are under rail except at the front of the bed and the tailgate - both of these areas are somewhat covered by a thick vinyl overlap. Add the side rail protectors (up on top) and you've got a (more) level surface to install a cover. That'll help a bunch. Or just get an over-the-rail liner (which I'm not sure anyone's shipping - yet). Then (in the daylight hours) just crawl in the bed with the cover on and look for light (gaps) that will let water in. Use silicone caulk or something easy to remove (but water proof) later on and you're all set. Caveat: don't pull the cover down (just have a helper handy) if the tailgate's up (locked) or you might be locked in.
That'd be stinky. %-)=
And in response to renegade69's comments: The main thing I like best about the one piece lids - especially the A.R.E. products - is that they LOOK the best (in my opinion) of anything you can put next to the really glossy finishes of the Quad. They don't have wrinkle or line one, and their struts are much better (again, IMO) than the OEM lid. They should be anyway, as they have a larger surface area and weight to lift. Only reason to avoid the glossy look is if you have nerfs, grill guards, etc. that are 'flat' finished and would look more balanced with a regular tonneau, fold - a - cover or roll - type with a flat finish. But then again you could paint the A.R.E. with a flat black. Hmmm... now I'M getting interested in one.
victx - Manik is a fabulous product. So is WAAG - but I think more expensive than Manik or Westin.
Oh, and BTW - if you want to use a tonneau, lid or other cover over a SPRAYED IN liner, you won't have the weird top fit issues I described above; you're already 'flush.' ;-)
netdocs
Looks like a standard DIN and 1/2 won't fit anymore without a face plate.
I'm going to do the same with the Quad, but now I have to wait until a face plate is available, which is too bad, especially since the 2000 dash would have taken a standard unit so easily.
best fitting and least obvious hitch for Quad. Reese, Hidden Hitch, Draw Tite, or other.
Also, I have 2001. Anyone know if any changes to
rear hitch area? Will 2000 hitch fit 2001? I would assume they are the same.
Badassbob-(Chad) has one and swears by it.
Allen-
Part # is 82205258. Relatively easy to install if you have the torgue driver for the screws.
I ordered my fender flares from the dealer parts. Took about 10 days to arrive. They are black plastic on the underside and painted Light Driftwood on the topside. You can see the overspray on the back side. Ordered the fender flares first week of July. I have an '00.
You picked yours up 8/18. Well I got mine on 8/16. The only reason I mentioned it is that yours is the same color as mine. Perhaps they have the white or white/silver combos being built at the same time. I ordered my 4x4 SLT+ on 7/10/00. Did you order or purchase off the lot? I'm in Atlanta, GA area. Hopefully, we'll be far enough apart that we'll still have unique trucks for our area. No matter and I agree with you: this truck is gorgeous. It'll probably even look great after an off-road mud bath. Keep on trucking!!
their Dakota? Big job? Not so bad? Any comments would be appreciated. Thanks...
robert
Bookitty
I am not a long-term truck person (yet), but when I bought my QC the dealer had already put a Manik guard on the front (which was okay as I had wanted the front guard anyway). I ended up paying dealer-invoice-for-the-mopar-guard, for the Manik, so I was happy there. I've found a local shop that carries Manik (in Austin TX) and their un-installed price was about $460. I have not yet done something "serious" with the guard (pushed a vehicle, tried to pull something with it, etc.) but it appears very sturdy and well mounted to the frame of the truck. The guard fits very well and looks good on the truck (check it out here: http://www.tertius.com/TheJumps/tjump/dakota.html).
-Ted
$359.95 is a good price. I placed the order after viewing your photos, and installation will take place on Tuesday the 29th. Thanks again Ted.
Bookitty
Good Luck jaalfs
