2020 Porsche Lease Deals and Prices (All models)
145679
  • mbnj2123mbnj2123 Member Posts: 92
    Sorry, forgot to add 24 and 36 months at 7,500 miles. RWD Carrera S convertible. Thanks!
    .00200 MF
    60%/53% residual
  • surf2day2surf2day2 Member Posts: 75
    Hi, can you advise on MY20 Taycan 4S MF/Residual for:
    24/7.5K
    24/10K
    36/7.5K
    Not sure if Zip matters for Porsche Financial, but 33483 just in case. And are Porsche lease programs quarterly or monthly?
    Thank you! 🙂
  • carguruguycarguruguy Member Posts: 29
    Hello may I please have the MF, RV, and incentives for a Macan base in ZIP 92886? 36/10k and 36/12k please. Thank you!
  • MichaellMichaell Moderator Posts: 268,609
    24/7.5K
    24/10K
    36/7.5K
    Thank you! 🙂
    .00124 and 59% / 52% for 24/36 months and 7.5K
    Numbers are national, and they are updated quarterly.
    .00200 and 52%
    No incentives
  • The_0zmanThe_0zman Member Posts: 16
    Can I have the money factor and residual and any incentives for 2020 taycan turbo s, zip 20705. 36/12 please thank you!
    The $7500 federal rebate also applies to the 2020 model?
    .00164 MF and 42% residual
    No info on the Federal tax credit, or if PFS is passing it along to the lessee in the form of a rebate.
    Hi sorry for any confusion on my previous ask on the MY20 Taycan 4S..please confirm residual and MF for
    24/7.5K (think this was 59% and .00124)
    24/10K
    Thank you again 🙂
    24/10K
    Thank you again 🙂
    Consider it confirmed.
  • carguy1985carguy1985 Member Posts: 73
    edited February 2021
    Is it true the 24 is .00124 and 36 month is .00148? I am told it is tiered by length.
    This is in reference to a MY20 Taycan 4s
    Thanks as per usual...
    That is correct.
    MY2020 Taycan Turbo
    90211
    36/7500
    39/7500
    Residual and MF
    MY2020 Taycan Turbo
    90211
    36/7500
    39/7500
    Residual and MF
    .00164 and 47% / 45%
  • cslc15cslc15 Member Posts: 25
    90049 MY20 Taycan 4S Residual & MF for 36, 39, 42 months 7,500 miles per year.
    .00148 MF
    52%, 50%, 48% residual
    Hello
    Can I have the money factor and residual for zip 20705, in a ‘21 Taycan turbo S, please.
    36 month 12k and any incentive please.
    The_0zman said:
    Hello
    2021 model discussion
  • small_lizardsmall_lizard Member Posts: 37
    Hi looking for MF and Residual on 2020 Taycan 4S
    36, 39 and 42m with 10k miles. Zip 10019. TIA
    .00148 and 51% / 49% / 47%
  • 2004for2004for Member Posts: 52
    Can you share residual and MF for a 2020 Taycan turbo; zip code 95014. And are there any incentives?
    24mth/12K
    24mth/10K
    36mth/12K
    36mth/10K
    24mth/12K
    24mth/10K
    36mth/12K
    36mth/10K
    24/12: .00147 MF and 52% residual
    36/12: .00164 MF and 45% residual
    24mth/12K
    24mth/10K
    36mth/12K
    36mth/10K
    Can you share the same but for a 2020 Taycan 4S? Thanks!
    2004for said:
    24mth/12K
    24mth/10K
    36mth/12K
    36mth/10K
    .00124 MF and 57% residual
    .00148 MF and 50% residual
  • devtekdevtek Member Posts: 30
    Could you please confirm rate for 2020 Taycan 4S, zip code 98005? I have following for 36/7500, 52% residual, .00148 MF. Dealer claims MF is .00200
    .00148 MF and 52% residual
    .00200 is the base rate for 2021 model
  • lalalandplalalandp Member Posts: 8
    Can you provide the rate/residual for 2020 Taycan 4s for zip code 91604?
    .00148 and 48%
    what about on a 42/10?
    47% residual
    Any idea on what the 2020 rates will be next month?
    No, but Porsche usually only adjusts the programs quarterly, so likely they'll stay the same as this month
  • twmtwm Member Posts: 68
    Could I get the MF, RV, and incentives on a 2020 Porsche Panamera Base and 4 for a 24 month/10,000 mile per year lease? ZIP code is 33410. Thank you very much.
    .00100 and 61%
    Either trim
  • cvballacvballa Member Posts: 9
    Can I get a Residual and MF on a 2021 Taycan 4s 36/12 zip 92651?
  • rfmhtx87rfmhtx87 Member Posts: 4
    What's the residual and MF on a 2020 Panamera base and 4s E-Hybrid. 36 months/12,000 miles. Zip is 77096. thanks!
  • mkim90kmkim90k Member Posts: 5
    edited March 2021
    Hello looking for the following (4):
    2020 Macan s/gts cayenne and coupe base
    36/7.5k residual and mf.
    Base: .00132 MF and 53% residual
    I don't see a 4S E-Hybrid
    Check your nomenclature. Plenty of Hybrid models, but nothing matches that exactly
    Please list the models you want individually.
    Can't quite sort that out
    2020 Macan s
    2020 Macan gts
    2020 cayenne suv base
    2020 cayenne coupe base
    All 36/7.5k
    mkim90k said:
    2020 Macan s
    2020 Macan gts
    All 36/7.5k
    .00200 MF
    52% residual
    53% residual
    49% residual
    49% residual
  • srz948srz948 Member Posts: 76
    Can you please explain how the "Welcome to Porsche" Conquest credit on the last 3 months of my existing competitive lease is applied? The last 3 months of my current lease totals $3150.00. Will I receive a credit on my Porsche lease statement in that amount or will it be a monthly credit of $87.50 for 36 months?
    I believe it's the former - the 3 remaining payments are waived when you start your new lease.
    Just a fancy name for a standard pull ahead program.
    Thanks very much, you're right.
    Could you let me know what a 2020 Panamera 4S would be in 77096 (36/12)
    Also, a Taycan 4s
    thanks!
    Also, a Taycan 4s
    thanks!
    Panamera 4S - .00114 and 52%
    Taycan 4S - .00148 and 50%
    Appreciate the helpfulness. Please provide the following MF and residuals:
    2020 cayenne suv S
    2020 cayenne coupe S
    All 36/7.5k
    2020 cayenne suv S
    All 36/7.5k
    .00200 MF
    45% residual
    Either body style
    Sorry, I guess I wasn't clear. The pull ahead is for current Porsche lessees getting another Porsche. Just trying to confirm what I've been told by a salesman. The "Welcome to Porsche" Conquest is not a payoff for your existing lease. It's just a "credit" to a new Porsche lease equal to the last 3 months of my existing Range Rover lease and is handled differently. I will still be liable to RR for the those 3 payments which total $3150. Whether I turn the Range Rover in early or not is up to me. I will then receive a credit on my new Porsche lease statement in that amount. I just wanted to know if it's a $3150.00 credit or $87.50 per month for 36 months.
    And, we don't have that information. Sorry.
