2021 Jeep Grand Cherokee Lease Deals and Prices
1202123252664
  • kyfdxkyfdx Moderator Posts: 272,632
    Hi - Looking for MF, RV and Incentives for GC Limited 4x4 36/10 in 10583. I have an existing lease maturing in April. Unsure if they stack incentives for returning Chrysler Capital lessees. Thank you!
    We don't have the loyalty information, but incentives are likely
    .00008 MF and 55% residual
    $3280 incentive
  • mauricio007mauricio007 Member Posts: 4
    Hi Michaell,
    Could you share the current (March) MF, residuals and incentives for a 2021 Grand Cherokee 4WD Limited, 4WD 80th Aniv, and Trailhawk 6 cylinder, 36/10k and 39/10k in 90403
    My lease for a 2018 Trailhawk is up and I'm trying to decide what to do. The residual value is $27k so it might not be a bad idea to buy it, given the current market.
  • kmarpkmarp Member Posts: 19
    kmarp said:
    kmarp said:
    can I know the mf/rv for a fully loaded limited 4x4? 36mo/12k, and 48mo/ 12k with 75002 zip. thanks
    .00008 and 54%
    $1500 incentives
    Longer terms not supported.
    can I also know the mf/rv for 36mo/12k on a 80th aniv. in the same zip code with msrp $49k? Thanks.
    .00008 and 55%
    $1500 incentives
    If the dealership gives a higher mf, what can I do?
  • MichaellMichaell Moderator Posts: 268,993
    kmarp said:
    kmarp said:
    .00008 and 54%
    $1500 incentives
    .00008 and 55%
    $1500 incentives
    Find out what bank they are using.
    If it is Chrysler Capital, insist on the base rate or shop somewhere else.
    Hi Michaell,
    LTD - .00008 and 55%
    80th - .00008 and 56%
    TRL - .00012 and 55%
    $2000 incentives
    kmarp said:
    .00008 and 54%
    $1500 incentives
    .00008 and 55%
    $1500 incentives
    If the dealership gives an inflated mf, what can I do?
    kmarp said:
    kmarp said:
    .00008 and 54%
    $1500 incentives
    .00008 and 55%
    $1500 incentives
    Insist on the base MF, or shop elsewhere.
  • nolajudenolajude Member Posts: 9
    Good morning! Can I get MF/RV/Incentives for Summit and Limited X 36/10 4X4 in 70124, please?
    LTD/X: .00008 MF and 55% residual. $1500 incentive
    SUM: .00039 MF and 53% residual. $500 incentive
  • kbaker4409kbaker4409 Member Posts: 12
    Hi, Could you share the current (March) MF, residuals and incentives for a 2021 Grand Cherokee 4WD 80th Anniversary 36/12 or whatever is currently top running (Jeep dealer keeps referencing 39m +) ZIP 80210. Also, are the numbers you are typically quoting in this thread Chrysler Capital? Thank you in advance!
    $2000 incentive
    We only have the Chrysler Capital numbers
  • LeasesAreWildLeasesAreWild Member Posts: 12
    Can you please provide the MF, residual, and incentives for a 2021 JGC Laredo 4WD for 36M/10, in 48103?
    No support for the base Laredo trim - only the X and E sub-trims.
  • SpeedingbullittSpeedingbullitt Member Posts: 2
    Hi. Looking for the MF, RV, and incentives for a Laredo X 4x4 and Limited 4x4 36/10 in 83401. Thanks!
    LAR/X: .00054 MF and 56% residual. $3250 incentive
    LTD: .00008 MF and 55% residual. $1500 incentive
  • rbarnum1rbarnum1 Member Posts: 23
    Can I have the MF, RV, and incentives for the Laredo X Altitude 2wd and Limited 2wd 36/15k, 24/15k in 70816? thanks.
    LAR/X: .00054 MF and 52% residual
    LTD: .00014 MF and 51% residual
    $1500 incentive
  • thehankthehank Member Posts: 100
    I am looking for MF and RV for: My zip is 70001
    2021 Jeep Grand Cherokee Altitude 36/12. Both 2WD and AWD please.
    Laredo E or Laredo X?
    I know the Altitude is just the Laredo with an aesthetics package, but what's the difference in the X vs E? Thanks!
    I don't know.. but, no lease support for any other Laredos
  • fischwaterfischwater Member Posts: 28
    Good evening. I would like to obtain the MF and Residual for Limited 36/12k zip code 10466. Any incentives? Thanks
    RWD or AWD?
    AWD
    AWD
    .00008 and 54%
    $3280 incentives
  • lease4everlease4ever Member Posts: 32
    Can I please have the MF, RES, I NC, for 2021 Jeep grand Cherokee Laredo X 4 x 4 36 months/10 K, zip 92543
    $3000 incentive
    2021 Jeep Grand Cherokee Altitude (Laredo X) 36/12. Both 2WD and AWD please.
    2WD: .00054 MF and 54% residual. $1500 incentive
    4WD: .00054 MF and 55% residual. $500 incentive
  • JKP2020JKP2020 Member Posts: 4
    Hi, I am looking for MF and RV for 2021 Jeep Grand Cherokee Laredo 2WD and 4WD (base model). As well as possible incentives zipcode 22150
    There is no lease support for the base Laredo.
    Would you like the Laredo X or Laredo E numbers?
  • xnjtarheelxxnjtarheelx Member Posts: 24
    Can I have to residual/mf/incentives on a Grand Cherokee V6 3y/36k in 28451.
    Limited X 4x2
    High Altitude 4x4
    Limited X 4x2
    High Altitude 4x4
    There is no Limited X - there is a Laredo X. Is that what you meant?
    edited March 2021
    Limited X 4x2
    High Altitude 4x4
    I think you're mistaken. I mean the 2021 Jeep Grand Cherokee Limited X. It absolutely exists.
    https://www.jeep.com/bmo.grand_cherokee.2021.html#/build/exterior/28451/CUJ202103WKTP74D/2TG/APA,PW7,X9,ERC,DFT,DML,Z1K,TKY,WHN,YL,SDZ,UAV,2BG
    Limited X 4x2
    High Altitude 4x4
    It's late. I'm tired. I didn't look closely enough at my data.
    .00014 and 53%; $1500 incentives
    .00018 and 54%; $500 incentives
    edited March 2021
    Can I also please have the residual/mf/incentives for the 80th 3y/12k 28451?
    80th 4x2
    80th 4x4
    80th 4x2
    80th 4x4
    .00012 MF and 54% residual
    $1500 incentive
  • Lease_MasterLease_Master Member Posts: 18
    Hi - Can you please advise rv, mf and incentives on JGC Laredo 4WD and Limited 4WD in 12603? 36/12 and 24/12. Thank you!
    Laredo E or Laredo X? Base Laredo has no lease support
    edited March 2021
    Laredo E
    Laredo E
    Laredo E
    .00058 MF and 64% residual
    .00043 MF and 55% residual
    $3860 incentive
    LTD
    .00011 MF and 63% residual
    .00008 MF and 54% residual
    $3280 incentive
  • tywebb1973tywebb1973 Member Posts: 115
    edited March 2021
    Asking for a friend (LOL, seriously). Buddy is looking at 2021 High Altitude 4WD. 3 years, 10K per year. Zip is 08034. He showed me the deal and the incentives and residual looked really light. Thanks!
    .00018 and 55%
    $1500 incentives
  • livelaughdrivelivelaughdrive Member Posts: 23
    Hello
    May I have the mf/ residual for a 2021 jeep gc limited x. 36 mo 12k zip 15613
  • NightmareNightmare Member Posts: 4
    Hello
    Can I please have the MF, RV, and incentives for the 2021 jeep grand cherokee laredo X 36M/10K zip 11357
    THANKS
    Hello
    RWD or AWD?
    Nightmare said:
    Hello
    THANKS
    RWD or AWD?
    Nightmare said:
    Hello
    THANKS
    RWD or AWD?
    AWD
    Nightmare said:
    Nightmare said:
    Hello
    THANKS
    RWD or AWD?
    AWD
    .00054 and 56%
    $3860 incentives
    Hello
    RWD or AWD?
    Hello
    RWD or AWD?
    AWD please
