They did. They came back at $52k on the wrangler. By my calculation my payout is $42k but don’t have an online account to confirm yet.
So, what's it called? I have no idea.
Great. I have no idea how the lines beyond the plugs could have gone foul during the project, but clearly something is amiss. I thought I would see if I could just turn the system off since it is such a useless, unnecessary thing (and not mandated, for a wonder!). The internet says I can. I went into the VAG-COM system and did the programming... nope. Real life says it doesn't work on this year of this model. It did turn the bright red "BRAKE" light off, but the yellow pad warning light remains.
I guess my next project is to hunt down this new gremlin so that I don't slowly lose the rest of my mind over this. Honestly, I don't have much left to lose.
I agree... like $42.3k, I think. Would be a little higher in my state due to the way they charge up-front taxes. Still... your quote makes me want to grab one even more. I forget exactly, but I think I figured I’d have about a $46k-$47k buyout, given a lower discount and the tax. Even a $50k offer would be a quick few grand.
Wonder why they can’t seem to give me a quote on my ‘maro
It obviously should be nitro fill.
So about these dummy plugs, do you mean you just did the same as if you spliced the wires together? Does the light need to be reset after new sensors are normally installed?
I wonder if the OEM sensors use some sort of a resistor so that any change in that resistance, either positive or negative, triggers the light.
EDIT: I read further and I saw slipped ribs. That’s a new one on me but it sounds painful.
Yes, you can. It’s subject to inspection but they honored it on the Outback (not that I took it).
Interesting. What kind of inspection is involved? Do they slap a code reader on it or go around with a paint meter? I’ve heard the inspection is rather cursory but I’d hate to have them show up and start pulling wheels off.
@qbrozen - get well soon.
I’m in an Uber right now on my way to work. Dropped off the Pilot at the Mechanic. I will update you guys on the progress. Even Uber rides have gone up. Usually my ride to work from the mechanic is $13 - $14 ish plus tip. Today it is $20.53 plus tip. Sheesh!
How are your prices on plumbing supplies at the wholesale level? Are you seeing the same inflation as with lumber?
Both of them have the irritating "laptop on the dashboard" look interior. The TLX is much less intrusive.
It's enough that I'm going to wait to see what the 2022's look like although I don't expect it to change. I wonder why some manufacturers have problems with that. Or maybe it's just me.
That's such a pretty Wrangler. Too bad you'll only have it for a month.
+1
No way he's going to walk away from $10K.
Back in '09 when I had open-heart surgery they had to split the sternum to access it, and when it was done they wired the sternum closed to heal. After 6 weeks or so I went back into hospital because of complications and was there for 2 weeks more, with lots of procedures and jockeying me around for tests. It seemed that in the course of all that, some of the wires snapped and my sternum never healed properly. When I got back home I had bouts of unpredictable searing pain when I moved in certain ways. They wanted to install a titanium plate to stabilize it. Being in Canada this took 6 months to get close to being done and by then the pain had gone away and they said I had developed soft/scar tissue that seemed to stabilize it, so I passed on another procedure.
I lived with it having no real issue until the end of February when one morning I woke up and felt a different kind of pain right at the center of the sternum. My own diagnosis later confirmed by the docs was that the soft tissue holding it together had torn and it was unstable again. This time the pain was different than what it was - it was as if both of my shoulders had been sprained or dislocated. I couldn't lift my arms up beyond parallel with the ground. The doctors were sort of all looking at each other wondering what to do if anything and who would be responsible, while I was suffering. I was massaging both shoulders, rubbing various products on them, and taking pills in attempts to live with it. Three months along I have days when they are fine and other days when they really hurt. Oddly enough the one time they are guaranteed to not hurt is when I am taking a hot shower. Still waiting for some direction from the docs on a long-term fix. It is incredibly limiting and discouraging. Ask me again about our wondrous Canadian health care system.
The issue is I can’t order locally anymore because my dealer contact left and now they are not discounting. I need a car, I like this one, my wife is happy, and the price is right.
So yes, for right now, I’m walking away from 10k.
I decided I'd do the same with the Outback, just to see where I'm at with it.
Recap - 2015 Outback Limited, 3.6R engine, just under 43,000 miles, 75 months old. I've spent a total of $1449 on service and maintenance, and half of that was new tires. To be fair, there have been three separate recalls done, and I had the windshield replaced ($0 cost to me, as I have insurance).
I pulled out the book that says what needs to be done, and when, and it turns out I'm a bit tardy on some of my maintenance. So, I'm collecting quotes from my dealer and a local independent shop to get them caught up. Things like brake fluid replacement, spark plug replacement (60K or 60 months), air filter, fuel filter, etc. Probably get these done sometime in June.
The last time we were at a major milestone like this, we traded the car in and got the Subaru. Not likely to happen this time, as the Outback is paid off.
Getting the tires rotated tomorrow afternoon.
The air filter & cabin filter are very simple DIY. If you can make toast, you are fully capable of changing these items.
I suppose some might say that my $4,500 profit on the 2018 F150 was a better deal, seeing as how I did get the use of the truck for almost 3 years. But cash is king, and $4,500 is less then $10,000.
When I decided to flip the 2016 T&C for the 2019 Pacifica, I made the deal for the new one before accepting the online offer for the old one. You might want to go down (just for grins and giggles) and see what the price would be for leasing another Wrangler. All you have to lose is a little of your time.
What you’re talking about here sounds one heck of a lot worse, and I do sympathize. Living with chronic pain is bad news.
I burn toast. :laughing:
Logically what you say makes sense, Q. But I just don’t want to deal with it. Flat out.
I think the sternum/shoulder issue is relatively easy to fix, but the trick is getting them lined up to do it. Right now I still haven't been able to talk to a surgeon about it, between our perpetually constipated system and COVID backing things up..
@ab348 - same...that sounds very frustrating and painful.
Short review is...I'm really loving it.
Performance-wise, it's a shift in mindset for me. It handles and accelerates as well, and probably better, than pretty much anything I've owned before. But it does it with very little drama - the acceleration is brisk, but very smooth and obviously quiet. The car is very flat in turns and cornering, but without any drama from the rear end (like the Supra), for better or worse. For many of you who have much better driving skills than I do, I imagine it would be less engaging. I'm finding it suits my driving style very well and is a nice blend of performance and luxury.
Functionally, I really like the packaging. The rear seat is small, but usable, and the hatchback naturally is convenient for throwing in my tennis equipment and a chair for baseball games. Since both of my boys are now driving, gone are the days when I need the space for two huge baseball bags, a cooler, etc.
Though the Polestar 2 is about a foot longer, I kinda view it as a EV version of a GTI. Definitely a premium hot hatch.
I like the chase. But this is a terrible time to be chasing and I’m happy to have landed a unicorn on a car I like. Even for someone with wandering eyes like myself, this feels like a good time to lay low.
Sorry you have to deal with that.
- Ray
In my 70s now and [knock wood] doing well, physically...
Like @stickguy said, you will still have positive equity in the Jeep in 6 or more months. Even before this shortage, the resale on Wranglers was ridiculous.
I don't think there is anything to prevent that from working, as the actual sensors are the same thing except that the wire loops down through a little connector that sits in the pads.... When they wear to the point that the brake rotor severs the wire, the dash warning light illuminates. There's no resistor in the circuit or anything. As such, I think the issue is an open loop at one or more wheels.
A couple years ago, I had one of the wires get ripped loose by ice. I went in and just twisted the pieces of wire together, which shut the light off, until I could get and install a new run.
