Visitor Agreement.
Or, at least, about as cleaned up as I'm gonna get it!
Oh, and the garage is coming along. Here's a couple pics...
Does it have the fender skirts, or are those MIA?
They might have held a record for heaviest unit body car as well. Or if not, they were definitely in the running. Overall length though, I don't think was all that overblown. I think around 227" overall. Although, they definitely had a presence about them. And while 227" wasn't a hard number to beat, by the 70's, by then it was mostly thanks to the protruding 5 mph bumpers.
I wonder, if Lincoln used the same roof for the hardtop coupe and hardtop sedan in those years? That formal roof shape looks like it could have lent itself to either style. If so, I'd imagine it made for one of the roomiest 2-doors around at the time.
These must have looked old pretty quick when the 61 Continental debuted.
Speaking of obscure cars, when I visited a local shop to see about them taking on the fintail, a guy pulled up in a 94-95 E320 cabrio, that's a good sign. Also saw a BMW E21.
Remove and replace broken bolts for the RH exhaust manifold.
Springs and shocks all the way around.
Removed fuel tank to have it cleaned and reinstall.
Removed the radiator and sent it out to be recored.
Replaced all of the rubber fuel lines.
Rebuild the carburetor.
Replace the distributor cap, rotor, points, condenser, the plugs and wires.
Added oil to the cylinders and rotated the engine by hand. Have to do that a couple more times before starting this.
Change the oil and filter, which BTW I forgot to link that I did a short video tip about the filter.
Replace the belts.
Rebuilt the starter, machined the commutator bars, new armature bushings and brushes.
Brakes all the way around including rebuild the wheel cylinders.
Replace the master cylinder with a dual piston upgrade.
Install a proportioning valve, and replace lines as required.
Replace the tires.
Then I'll see what else it needs.
Here is the oil filter removal tip.
I had to laugh a bit when this was dropped off. It would have taken me a while to get the hood open if I hadn't asked the owner to open it up.
@thecardoc3
Are you documenting the progress anywhere like YouTube or another forum? Sounds like a great project.
He has some other comparisons, too. Host seems low key and pretty knowledgeable.
That Marquis reminds me that although this is very minor, Ford products then seemed to have short (height-wise) center armrests in the middle of the rear seat.
I posting it because the invoice sticker he has is fascinating, at least to me.
Plus it's from CT.
And on the way up there, this finally happened...
(in my best Al Bundy voice) "This baby's only got 29 miles on 'er!"
I meant to try and take a pic of it at 99999 and then at 00000, but it totally slipped my mind.
Oh, and here's a few pics I took of the garage progress today...
Aaaand, the obligatory view from the pool...
It's amazing, how fast these guys work...and how well they work together. Say what you want about Millennials, but these guys are working their butts off. It's almost enough to give me hope for the future of mankind.
That's a heck of a roof! Are you getting a a generous storage area out of that attic?
Pretty sure the highlighted 55 didn’t show up until MY 1980 or even 81.
That part of the law was passed late 1979.
I know my 79 Continental didn’t have it, but both my 89 LTC and Grand Marquis still did.
Oh, there was an Arrow at the Mopar show, that had been turned into a drag car. I had run out of storage on my phone by the time we saw it, but I think Lemko took a picture of it.
I calculated the New Yorker's fuel economy on this trip, and it came out to a rather piggish ~14.7 mpg. However, that wasn't pure highway driving. I got about 269 miles between fill ups. However, the first ~17 were local driving, plus time at the mechanic, before the trip. And when I drove up to Carlisle, the line to get in was so long and traffic was bad enough that the last three miles took about 30 minutes! I'm sure that helped sink its economy. Plus, I'll confess I pegged the 85 mph speedometer a few times, just to see if it could still do it! It still feels like it has plenty of guts at that point, but then handling starts getting a bit squirrely, and then the realization that this thing won't stop as fast or predictably as a modern car should the need arise kicks in, stuff like that...
So, maybe all things considered, 14.7 isn't TOO horrible?
15x60? Two words.. MAN CAVE!!
My 79 Continental wouldn’t hit 14.7 downhill with the engine off….
As for Lemko, I think he said the reason he stopped posting here is that he has troubles logging in nowadays. Something about when the Edmund's forums went to one of the newer formats, he started having problems.
Yes; I want to know if driving his current sled is still better than sex with his girlfriend.
https://my1968oldsmobilecutlass.wordpress.com/2021/07/13/my-1968-olds-cutlass-is-for-sale/
