2021 Porsche Macan Lease Numbers
13
  • MichaellMichaell Moderator Posts: 266,361
    edited August 2021
    Umberto98 said:
    Hello Everyone, Can I please get MF, Residual and Incentives for both Macan S and GTS.
    36/15k and 48/15k.
    Located in 90290
    Thank you so much!
    .00183 and 58% / 57% for GTS / S
  • Umberto98Umberto98 Member Posts: 16
    edited August 2021
    36/15k and 48/15k.
    Located in 90290
    Thank you so much!
    Do you have 48/15?
  • kyfdxkyfdx Moderator Posts: 269,386
    edited August 2021
    Umberto98 said:
    36/15k and 48/15k.
    Located in 90290
    Thank you so much!
    Do you have 48/15?
    48/15
    .00220 MF
    46%/45% residual for GTS/S
    You don't want to go any longer than 42 months
    42/15
    .00183 MF and 54%/53%
    Umberto98 said:
    36/15k and 48/15k.
    Located in 90290
    Thank you so much!
    Do you have 48/15?
    48/15
    .00220 MF
    42/15
    thank you!!
  • fncimpexfncimpex Member Posts: 38
    Hi, may I please have MF and residual for a base Macan and Macan S please
    36 months/10K miles in 91724 (CA). Thank you!
    .00183 MF
    60% residual
    Either trim
  • rock80rock80 Member Posts: 2
    Can I please get the latest residual and MF for Macan Base located in 19085?
    36/10, 36/12, 39/10, 39/12
    Thanks in advance!
    Thanks in advance!
    .00183 MF
    59%/57% residual for 36/39 mo, 12K/yr
  • IndigoreefIndigoreef Member Posts: 23
    Hi, Macan S, 06902
    36m 7500m
    36m 10,000,
    edited September 2021
    Hi, Macan S, 06902
    36m 7500m
    36m 10,000,
    .00200 MF and 60% residual
    Hi, Macan S, 06902
    36m 7500m
    36m 10,000,
    thanks, does porsche do 36/7500?
    Hi, Macan S, 06902
    36m 7500m
    36m 10,000,
    +1%
  • stingray23stingray23 Member Posts: 84
    Hello. Anything regarding the 2022 Macan GTS? 36/10k. 10541. Thanks.
    2022 model discussion
  • PPCPPC Member Posts: 2
    Hello Everyone, Can I please get MF, Residual and Incentives for Cayenne base.
    39/10k.
    Located in 07020
    Thank you so much!
    39/10k.
    Located in 07020
    Thank you so much!
    Please re-post here
  • payam123456payam123456 Member Posts: 2
    Hello everyone,
    I was wondering what the 2021 Base Macan MF and Residual are for zip code 20152?
    Hello everyone,
    Forgot to add 42/10k
    Hello everyone,
    .00200 MF and 56% residual
  • gunflintflygunflintfly Member Posts: 1
    Hello!
    What's the current MF, residual for 36/12K Macan base zip 10028?
    Thank you so much!
    Hello!
    Thank you so much!
    .00200 MF and 57% residual
  • mk_CAmk_CA Member Posts: 9
    May I please get September's RV/MF/Incentives on the following lease variation in zip 95008:
    2021 Porsche Macan S 36/12
    MSRP ~72K. Looking to lease a new one, currently have the 2018 Macan S.
    .00200 MF and 59% residual
    No info on loyalty
    .00200 and 60%
    Either trim
  • mlg1mlgmlg1mlg Member Posts: 4
    Hello - interested in MF/Residual for a Macan Base, 36/10, zip code 45226.
  • jagman12345jagman12345 Member Posts: 18
    Can I please get the latest residual and MF for Macan S located in 08852?
    36/10, 36/12, 24/10, 24/12
    Thanks in advance!
    Thanks in advance!
    .00200 MF
    66%/59% residual for 24/36 mo, 12K/yr
    Thanks - how about for 10,000 miles? 36/10?
    Thanks in advance!
    .00200 MF
    Thanks in advance!
    .00200 MF
    Add 1% to residual for 10K
  • skothapallyskothapally Member Posts: 4
    Hello ,
    Can I please request the MF and residual for 2021 Macan for zip -75093
    Santosh K
    Hello ,
    Santosh K
    Thanks Michael. How about the numbers for 36/12 and 36/10
    Plus 2% / 3%, respectively
  • belfattobelfatto Member Posts: 49
    Hi could I have the MF and RV for a 2021 Macan S 36/10k and 36/12k
    14220 NY
    14220 NY
  • Max__Max__ Member Posts: 18
    Hello, looking for MF and RV for 2022 Macan S, 36/10, 90401 zip code. Thank you!
    2022 Porsche discussion
  • jstein1221jstein1221 Member Posts: 71
    Good morning: is this the correct forum for 2022 Macan base? Looking for numbers on 24 and 36 month 10k lease in 33446.
    Please re-post here
    Can I get November MF and RV for 2021 Macan form 30000/36 months in zip 75039.
  • rewtri1rewtri1 Member Posts: 8
    Hi there, have MF and RV for 2021 Macan GTS zip 37215
    10k/12k 30 mos
    10k/12k 36 mos
    10k/12k 30 mos
    10k/12k 36 mos
    .00200 MF
    63%/60% residual for 30/36 mo, 12K/yr
  • icing2380icing2380 Member Posts: 2
    Hi there, can I have MF and RV for 2021 Macan base trim for zip 94022?
    10k/12k 36 mons
    10k/12k 36 mons
    .00200 and 59%
    Hi there, can I have MF and RV for 2021 Macan base trim for zip 75209?
    10k/12k 36 mons
    10k/12k 36 mons
    Hi can I have the MF and RV for 2021 Macan S for zip 91724?
    36/10 please thank you
