1258225832585258725883236
  • sdasda Member Posts: 7,816
    edited December 2021
    @xwesx Between you and @andres3 your mechanical issues with the Audis is not giving me the warm and fuzzies about long term ownership of our Q5 or VW. I hope it isn’t a serious problem. Bah humbug!
    The VW Tiguan has been stellar up to 19K miles now, and the TTS continues to rack them up and is fine nearing 54K miles.
    The S4 is catastrophic engine failure of course.
    Metal and junk and shavings everywhere. They tried to clean the oil housing and oil cooler but they are beyond saving; just uncleanable. Don't want to introduce old engine metal to the new engine, so ordering an aftermarket housing to save some money on plastic as German plastic is expensive, and went OEM oil cooler as that has metal components and it was only $100 more than aftermarket.
    Latest message from the shop:
    Looks like we had to disassemble the supercharger as well. There’s a bunch of crap inside it along with metal shavings as well. I’m hoping we can get most of it out and cleaned out from behind the intercoolers so we don’t have to replace them.
    The water jacket in the block broke causing coolant and oil to mix everywhere.
    It probably is easier to replace than "fix" things.
    Looks like a 2022 finish on this repair job.
    Wow, I cringe just reading about the extensive damage done by the water jacket failing, it pains me.
    I still wonder if Audi would have offered some good will on this.
  • qbrozenqbrozen Member Posts: 33,894
    I’m thinking about farming out my Coronet work. I was out there today and everything I started getting my hands in needed some fab work. For example, the new power brake booster needs new holes drilled in the firewall, not a big deal, but also a larger center hole, so I guess I’d need a specific size hole saw that I don’t own. Alright, onto the next… headers. Oh, hmmm… that will require cutting off the ends of the old pipes and welding new ends on. Not my forte, and would be almost required to have a lift. Maybe I should put the heads back on. Uhhh… water jacket is pretty nasty after sitting, so that should be flushed out but my hoses are shut off for the winter and I really don’t want rusty water all over my garage floor. Sigh
    mjfloyd1 said:
    @tifighter said:
    Most OG M2's around here are in the $55-58K range with lower miles. Comps start around $62K and climb pretty fast. The linked one is the wrong color and spec, but even then, it's one of the better deals I've seen given the miles and history.
    I agree on the miles and price for sure, but I’m also sure that @roadburner would prefer a 2019 or newer M2 Competition with a manual transmission. I don’t see any documentation of the M service at 1200 miles on that 2017, which is important to M aficionados.
    @andres3 perhaps should zip up to Seattle and pick up the 2017 M2 DCT?? $20k for new motor in S4 vs $49k for M2 including motor??
    It's actually closer then that.... Sell S4 without motor for $10K, get M2 for $39K more. Anyways, too late now, but could sell the S4 for $30-33K easy I think in this market.
    Biggest problem I'd have with a 2017 M2 is that I'd have another expensive car not under warranty. Deathly afraid of that right now.
  • oldfarmer50oldfarmer50 Member Posts: 24,815
    Am I getting this right, the engine block actually failed? That would seem to be a manufacturing defect. Should Audi stand behind something like that? Blocks don’t usually crack, at least not internally.
  • fintailfintail Member Posts: 59,045
    I drove in from the coast Monday morning. At that time, I was surprised that I5 at least south of Tacoma was barely better than the state highways or county roads - one lane kind of clear, but the rest were iffy, and I saw snow and ice patches in all lanes even near Seatac. State highways out near the coast were compact snow and ice the entire way, even near the beach many areas got 6" or more. 167 was bad in that way too, as I made a detour to Puyallup for a few minutes and headed north, it was stop and go for maybe 10 miles due to a couple cars in the median and everyone rubbernecking. Traffic volumes weren't huge, but it was a bad mix of timid Tommy or Tabitha in a Corolla wearing chains going 25, and Bob the boor in his lifted truck with bald all seasons going 70. I picked the right rental car.
    In case anyone is keeping track, we’re 4 days post snow event and the only cleared road in my area is I-5. Seattle really cannot do snow.
    As for me, I’m tired of being cooped up so I got my ice driving confidence back after an hour in a church parking lot. Now it’s just dodging everyone else.
    Age over mileage may be the problem with the water jacket.
    https://www.ebay.com/itm/264910010750
    Even less miles than mine but a year older.
    $1500 for a blown engine? I must not be Audi material.
    Funny, a generation ago I used to think E-Bay was a good place to find bargains.
    I thought the asking price high too. He tries to make it seem like it just needs a new rod.
  • roadburnerroadburner Member Posts: 18,703
  • 28firefighter28firefighter Member Posts: 9,971
    That CS must have something horribly wrong with it to be priced so low.
    I believe they're a nearly straight wholesaler, but yeah....how that ended up there vs. a BMW dealer is questionable...
  • tifightertifighter Member Posts: 3,875
    You can see the carfax on the site. Spoiler alert ---- well, you already knew there must be an issue, didn't you? But what's a little moderate damage between friends?
  • MichaellMichaell Moderator Posts: 270,427
    Wow. Disabling damage and vehicle towed.
    Black one had minor damage
    Sounds like a perfect job for “the guy”.
  • stickguystickguy Member Posts: 54,676
    I think the one I am getting now is going up about $900.. Can only help on resale!
    speaking of which I am supposed to go pick it up Friday morning. Probably a good deal for this market at least. About $1,900 below MSRP, and only adding on NJ tax and DMV and the standard dealer doc fee ($299 or $399 I think). Nothing else tacked on.
    financing for 3 years at 0%. Hard to say No to free money! payment is going to give me heart palpitations but its really the just keeping money in the checking account seeing as what that pays in interest.
    out of curiosity, I asked for a lease quote too. Sticker is a tick under $30K ($29,755 maybe). 1st payment only DAS, $429/mo for 36/10,500. Not terrible for this market, even though the terms aren't great (3.6% interest rate, 58% residual). Doing the math, would cost a lot more to lease and buy out of course.
    hopefully whenever I feel like flipping out of it the market cooperates. Just need to get close to the discounted sales price to make it a wash.
    Farmer, order a Maverick XL. Poverty spec. Just add AWD and the 4K tow package. Still in the lower 20s, but get a warranty and no pre-existing rust. Will do everything a beater Ranger would. Heck, trade in the Soul on it. I bet it would be easy access for you wife too.
    kill two birds with one stone.
    This is starting to sound like a project that should be packaged up and sold to the next guy that feels like working on it. So do the math and figure out if you spend the fairly large $ amount to have it finished, will it net you more than unloading it now?
    Isn't the answer to that always .... "never"?
    Aren't most restorations lucky to get 50 cents returned on every dollar invested?
    Starting to sound like Edd Chyna Wheeler Dealer math.
    the math can work if your labor is free. Once you are paying $100/hr for "the guy" it is going south fast.
    If his wife rides in it instead of the Kia, the XLT might be better otherwise he might get a thump on the head. Best to spoil her.
    Another try for @roadburner
    M3 Sakhir orange, 3 pedal , clean carfax
    https://www.dpat.com/used/BMW/2016-BMW-M3-3e8d97c00a0e09a863ce5adb153ad5b4.htm
    M4 white, 3 pedals, appears slick top, clean carfax, looks like CPO on carfax
    https://www.dpat.com/used/BMW/2018-BMW-M4-63e388cf0a0e09af7e331ff8979ea72a.htm
    I'm thinking it will pay off in this instance. Mostly because I already have all the parts and I've done the disassembly work and SOME reassembly. I'm thinking I'm looking at $3k-$5k. Let's say, just for sake of argument, it will be a $25k car. As it sits in pieces? I can't imagine anyone paying more than $15k, and that seems like a stretch. Because it is a mystery to anybody else. I know what's left in the puzzle, they don't, and I know how I'd feel about picking up somebody else's puzzle and what mysteries it may reveal.
    go for it. at least it will get it running so you can either finally use it, or unload it.
    Just have to find a "guy" that is good with taking on the parts and roadmap!
  • ab348ab348 Member Posts: 20,915
    Well, it's that time of year again... the best of 2021's Nurburgring mishaps. More of BMW drivers being... well, BMW drivers. :D Though Porscheophiles have nothing to brag about here either.
    My favorite of all was the bone-stock appearing Mini that shut down the track.
    https://youtu.be/Xc9Gph96hXs
    Exactly what I was thinking. Also thinking the term “catastrophic failure” is an apt description. Personally, I’d try to find out what the scrap value would be for it. Have to be decent money to part it out.
    Refresh my memory….what has Audi said?
  • corvettecorvette Member Posts: 11,882
    well, I did want an old truck to tide me over...
  • tjc78tjc78 Member Posts: 17,742
    Wonder if he will take $10,900
    S4 - he would not take it to Audi because he bought it used from a BMW dealer and it was close to two years out of warranty (but approx 46k miles IIRC).
    I would have taken it to Audi to see if they would give some good will. Now that looks like it would have been an excellent idea with an internally cracked block and downstream parts damaged by metal in oil and coolant.
    I guess you live and learn. :)
    Audi said it was highly unlikely help could be provided in my case. They said a "buyback claim" was my best bet, but in CA lemon law doesn't apply to used cars nor old cars, nor cars over 18,000 miles I believe. Seemed like a lost cause in talking to several knowledgeable sources.
    Perhaps a media campaign would have done the trick, but I want to get the car fixed sooner rather than "later." For 11 months and 12K+ miles the car was running just fine. It's fully loaded, prestige model, with a good record (no collisions) and is clean. With used car prices right now, made sense to fix it.
    I’m going to guess with a cracked block it wasn’t running as well as one might think for as long as one might hope.
    BMW tire pressure was probably 1.5 psi low :)
    The 1970 'ring video that has made the rounds for awhile still takes the cake.
    I'd estimate I had about 10-20 seconds of 85 MPH to 40 MPH "Power" once the black smoke and dummy lights started. Then from 40 to 0 MPH it was all just momentum.
  • jmonroe1jmonroe1 Member Posts: 10,029
    Kinda reminds me of when Mrs. j has me doing laps around the dining room table. She’s good on the straight aways but I shine in the turns. Why do you think I’ve taken out all the leafs from the table?
  • Sandman6472Sandman6472 Member Posts: 7,383
    Picked up the Audi this morning. Turned out it was a plastic part that was needed & the local Audi store had it in their parts department. Dropped off the wife and all is fine now. He wanted to do the oil/filter change as she's due soon but she decided to wait. Thought that was dumb since he's already got it in his shop but hey, her vehicle so she decides when to have things done. If it were my Golf, I would've had it done. Haven't seen the bill yet since I let her handle it so will look when she gets home tonight. She went into her part time gig since she was supposed to go yesterday but refused to drive the Golf. Maybe that's a good thing though.
    The a/c folks came yesterday and it needs a part to fix it. Again, we lucked out since they have it in their parts warehouse. It'll be fixed tomorrow morning as it's in the 80's here all week. Got down to 68 last night so not that bad. They put more freon in yesterday and said we could use it but be careful. So far, with our ceiling fans, isn't that bad so we're just dealing with it. Home today but going out for the afternoon and then off to work tomorrow. Was asked to work Sunday so said sure, why not.
    Yes, the preponderance of rear-engine Fiats, swing-axle VWs and Renaults made for much more impressive lower-speed crashes, especially since they all tended to shed all their glass in a rollover and eject their occupants via the window openings or opening doors thanks to their flexible construction. Amazing the number of people who got out of those vehicles while still moving or shortly after stopping.
    Yep, German plastic parts are expensive as we just found out!
    You'd see more Cadillacs, but the Nürburgring doesn't allow drivers over 80 years of age and also prohibits cars with permanently activated left turn signals.
    You seem to be blinded by the red mist that seems to permanently afflict many BMW drivers. This was a crash video, not a fast laps video. If you look up one of those you will find lots of very fast Caddys being expertly driven and successfully navigating the course.
    I found an M240i xDrive in Illinois. It has everything I want, but two things I don't- AWD and a hole in the roof...
    Don't all BMW drivers leave the fog lights on permanently? :stuck_out_tongue:
    What’s the difference between a (insert car brand) and a porcupine? A porcupine has the pricks on the outside :)
    Hoovie bought a Shelby GT500. I think I’ve found what I’d flip the ZHP for given unlimited funds.
    By the way, I seem to have broken the Jeep out of fuel and oil refresh mode. Got it up to operating temp long enough (about an hour in 20 degree weather).
    I had read 30 min drive at operating temp would do it. It has been warm here so it has been working on electric. Who knows though, I had also read it will stay on ICE if cold outside (baby it’s cold outside :) )
    “Hold my beer”. “Watch this”
  • xwesxxwesx Member Posts: 18,184
    05:40 was a moment for @fintail to be proud. :D
    That’s good. I’ve noticed my Prius seems to take a very long time to reach full operating temperature—much longer than a conventional ICE vehicle. But it produces heat from the HVAC fairly quickly.
