That could have been my lazy cousin.
I had to do that job on both my '64 Skylark and later on my '68 Cutlass. Oddly enough, when I took out the failed core on the Skylark, the new one I had bought at the parts store did not fit at all. I took it and the failed one back to the store. They had a catalog from the manufacturer that luckily had dimensions for every type they offered. What fit my car was one from a 1961 full-size Olds. Why, I did not know as everything looked factory original and not hacked together. Perhaps it was early production.
On the Cutlass, it had plastic inner fenders and apparently the factory suggested just cutting an access flap in that at a certain spot to get at the otherwise inaccessible nuts, but I did not want to do that, so I took it out entirely. My '78 Delta 88 had a similar problem with one nut that could not be reached, but a previous owner had helpfully broken off the fiberglass or plastic case at that spot and just used silicone to seal that area when reinstalling, so I followed his lead.
There are more lazy folks in this world than I thought.
Vorsteiner aero program with roof carrier. Is the front any less awful? I don’t think so…
Is that really the grill or a photo-shopped thingy?
Real
https://vorsteinerwheels.myshopify.com/collections/carbon-fiber-1/products/bmw-g8x-vrs-aero-program-abs-front-grill
But who knows what they do.
Real
So, they make it look like an older Charger?
You know what they say about a pig and lipstick!!!!!!
Ain’t that the truth.
I think car manufacturers should have mandatory drug testing for their designers.
It’s none of our business what MSRP is but we’re dying to know what the market adjustment is.
I already told you guys my Son found a Philly Kia dealer that wanted 18 grand as market adjustment for a new Telluride and an Atlanta dealer that wanted 8 grand for his for the same car.
Even better, he charged $100 less than told me on the phone. Probably adjusted because of the smaller bed size. But I’m not complaining. So ended up cheaper than factory job. And no holes in the gas tank. And if I have any issues, got a place to take it (lifetime warranty).
@stickguy, too bad all customer service today is not like that.
There are still local shops with real people. You can even go in and talk to them in person!
I wonder if the difference in the upper finishing of the liner (I think you said they put it on the top lip?) will have any effect on the fitment of the tonneau cover.
I did ask about if the liner would interfere with the gasket, and he said no, that it would stick fine (across the top edge by the cap, you run a strip of weatherseal that the front of the cover fits over to make it watertight).
Probably not a huge deal if it does not stick perfectly, because it is under the front edge of the cover which will hold it in place, and it is just there to help keep water out.
Should be fine. There is a Ford dealer in Kansas that started a youtube channel, and they are a huge player in the Maverick world (their internet guy who does the videos figured out how to play this game early on). He gives a lot of advice, including what options to drop to get built. One big one is the spray in liner, and he mentioned a few times how they do it in house (better than at the factory) and one of the upgrades they do is the top of the bed under the window. They would not do it if it messed up the covers. I hope!
On one of my F150's, I had a drop in bed liner that leaked even with the gasket due to it going over the cab end of the bed.
I'm sure yours will be fine.
So I decide to start looking. I texted my broker to see how bad a Highlander Limited Hybrid would lease at MSRP. It ain't pretty. My next stop is going to be to try and find a '21 Grand Cherokee L Limited. I can use my affiliate discount code, plus some conquest cash (he said $2,000) is available.
It looks like my 2021 Wrangler 4xe is lost in limbo. Broker says his contact at the dealership is getting ZERO communication from Stellantis or the holding lot to see what's going on with my Jeep. Good news, my 2022 4xe got in well before the price hike. It should be here sometime in late March.
Not sure about the current Highlander Hybrid. It utilizes the same 2.5 liter four banger hybrid setup as the Camry, Avalon, RAV4, Venza, Sienna, and some Lexus models. I've heard it's underpowered in the larger and heavier vehicles, such as the Highlander. I'd probably go for a used previous-generation Highlander Hybrid with the V6 engine, or a current model non-hybrid with the V6. I thought your kids' sports equipment wouldn't fit as well in a Highlander?
@nyccarguy , remind me why you are even wanting the ‘21 Wrangler anymore?
There is a GPS reset procedure.
Saw a new generation TLX right next to mine as I pulled into the service bay, and it looked sharp from every angle.
I don’t suspect he’s looking for that kind of solution. Hush.
Batteries can really be hit or miss. My theory is the newer cars have a higher current draw when “off” which degrades the batteries faster.
My 04 Grand Marquis went nearly 12 years on the OEM Motorcraft battery. The battery never fully went but after a few very slow cranking mornings in the winter I knew it was time.
So, your battery basically lasted 3 lifetimes. Nice.
@nyccarguy - I’ve only sat in a new Grand Cherokee L but was very impressed with the much improved interior, and I’ve always enjoyed driving them anyway, so I’ve gotta think this new one would be a great option.
I’d suggest the Palisade, but if memory serves, you’re not all that keen on them. I don’t know why, but the Hyundai seems easier to find and buy than the Kia.
The affiliate program is back for 2022 4xxxxxxxxxxe
I'm not interested in purchasing a used highlander. I drove a V6 rental and liked it. It doesn't fit as well, but the hockey bag fits. Right now, leasing one for $700 per month keeps it out of the running. The idea of the Hybrid appeals to me because my wife does do a lot of "city" driving in between patients' homes. Right now the trip computer says she averages 20ish mpg which I think is closer to 17.5 - 18. I'll have to check at the next fill up.
I looked at some Toyota leases aside from the trucks they are all dreadful. $800 a month for an Avalon… May as well buy it at that point.
For almost a year now Pallisade and Telluride have been selling over MSRP like @explorerx4 mentioned.
Honestly unless the more informed here know something I don’t, I can’t think of a single three row SUV right now that is worth it to lease.
My neighbor just replaced a prior gen highlander with a new mdx. Very sharp.
Yeah new MDX is a nice package. Heck I always liked the old one. Back when we got the XC it was a hell of a deal. If it was completely up to me that is what we
would have and I’d be banking $100 a month.
Tires and batteries? You can replace those?
Who knew……
So, so, so glad I'm not in the market. Even though I wanna be, at times. Still under 50K on the Outback, which turns 7 at the end of next month.
Late night browsing of local inventory last night…my local BMW/MINI dealer just took in a 2002 530i. Premium, sport and manual transmission. 87k miles. $9,700. Toledo Blue over black.
If it is in the condition you’d hope for with those miles, that’s very tempting. At that seemingly reasonable price, it could be a mess.
Even in normal market conditions I would be fine $ wise going forward.
