2022 Mazda CX-5 Lease Deals and Prices
1246718
  • kyfdxkyfdx Moderator Posts: 273,368
    fubar32p said:
    Could I get the numbers for Premium at 30 months/12k miles in zip 14624? Thanks.
    .00117 MF and 66% residual
  • Chrisr79Chrisr79 Member Posts: 8
    Can I please have residual and MF for all trim levels except base for 35/15. Zip 11768
    Pick three trims
    Pick three trims
    2.5 Premium
    2.5 Premium plus
    Turbo
  • MichaellMichaell Moderator Posts: 269,531
    Chrisr79 said:
    Pick three trims
    2.5 Premium
    2.5 Premium plus
    Turbo
    .00117 and 57%
    .00105 and 56%
    .00066 and 55%
  • Vera_kcVera_kc Member Posts: 9
    Can you please share the money factor for Mazda CX-5?
    Mazda CX-5 preferred
    30 mos
    12 k miles
    Zip: 60090
    Thank you!!
    30 mos
    12 k miles
    Zip: 60090
    Thank you!!
    .00204 MF and 70% residual
    Thank you so much!
    Can you pls also share MF and residual fog 2021
    CX-5 preferred. They would set the price at invoice.
    12k miles
    Zip: 60090
    30 or 24 mos
    What lease term has the highest residual for 2021? Thank you!
    Vera_kc said:
    Thank you so much!
    12k miles
    Zip: 60090
    30 or 24 mos
    Please repost into the 2021 CX-5 discussion
  • bartlebeebartlebee Member Posts: 9
    Hi, could I please get the MF and residual for CX-5.
    Zip: 94568
    2.5 S base and for 2.5 S Select
    36/12 and 36/15 if possible.
    Thank you in advance!
    Zip: 94568
    Base - .00204 and 62%
    Select - .00193 and 59%
  • jrickyjricky Member Posts: 11
    cx5 select for 06851.
    36/12 and 36/15
    36/12 and 36/15
    .00193 and 59%
  • drct2dcadrct2dca Member Posts: 5
    May I please have the MF and residual for a 22 CX-5 Premium Plus 36/15 zip is 22305.
    .00142 MF and 56% residual
  • SunburnsSunburns Member Posts: 2
    Can I please get the Residual and MF for a 2022 Mazda CX 5 Premium for 36 months and 10k miles zip code 11742 thanks!
    .00117 MF and 60% residual
  • natto_networksnatto_networks Member Posts: 3
    Can I please get the MF/RV for 2022 Mazda CX-5 2.5 S (AWD), zipcode 92129, and 33/10? Thanks in advance.
    .00204 MF
    73%/70%/65% residual for 30/33/36 mo.
  • WhyyounolovemeWhyyounoloveme Member Posts: 8
    Can I please get the residual and MF for a premium model
    Two terms
    30/10
    Two terms
    30/10
    Zip code 02893
    Two terms
    30/10
    Zip code 02893
    .00117 MF
    66%
    60% RV
    Can I trouble you for the 22 CX-5 Preferred 36/15 rate and residual? Same zip, 22305.
    .00204 MF and 60% residual
  • MaskedRobin56MaskedRobin56 Member Posts: 4
    Can I please have the incentives, MF, and residual for the following 2022 cx-5s 30/12k, 33/12k and 36/12k for zip 11741?
    -2.5 s
    -2.5 select
    -2.5 s
    -2.5 select
    S - .00204 and 73%, 69%, 64%
    Select
    .00193 and 69%
    .00204 and 65%
    .00193 and 61%
  • silverm0623silverm0623 Member Posts: 30
    May I please have the MF, incentive and residual for a '22 CX-5 Premium Plus 36/10 zip is 89084
    .00142 MF and 59% residual
  • rklaubsrklaubs Member Posts: 1
    Can I please get the 2022 February MF & RV for zip code 60622?
    2022 CX-5 S Select
    2022 CX-5 S Preferred
    36 months/10k and 36 months/12k
    2022 CX-5 S Select
    .00204 and 61%
    .00204 and 62%
  • gp4120gp4120 Member Posts: 1
    Can I please have the incentives, MF, and residual for the following 2022 cx-5s 36/10k zip 06901?
    -Carbon
    -2.5 S Preferred
    -Carbon
    -2.5 S Preferred
    .00193 and 63%
    .00204 and 63%
  • Anune056Anune056 Member Posts: 9
    Hi - I am requesting money factor and residuals for:
    2022 Mazda CX 5 Preferred (awd) for 12K Miles , 36 months
    2022 Mazda CX-5 Carbon Edition (awd) 12k and 36 months
    2022 Mazda CX-5 Premium (awd) 12k and 36 months
    2022 Mazda CX-5 Premium Plus (awd) 12K and 36 months
    Zip code is 33132
    Zip code is 33132
    .00204 and 62%
    .00193 and 62%
    .00117 and 59%
    .00105 and 58%
  • davidw94davidw94 Member Posts: 10
    Hi, I am requesting money factor and residuals for
    2022 Mazda CX-5 Preferred (awd) for 33/10 for zip 92110
    .00204 MF and 67% residual
  • Nick091Nick091 Member Posts: 15
    Hello, Can I have the MF, incentive and residual for a 2022 CX-5 Select 36/10k zip is 10308. Thank you!
    .00193 and 62%
    Sorry, forgot to ask. Are you aware of any incentives for 92110?
    No incentives
  • franciscomarcocfranciscomarcoc Member Posts: 5
    Good evening,
    Can I please have the MF and RV for CX-5 S; CX-5 S SELECT; and CX-5 S PREMIUM?
    36 months lease / 10k miles/year
    Zip: 44102
    Good evening,
    Zip: 44102
    .00204 and 65%
    .00193 and 62%
    .00117 and 60%
    Zip code is 11741
    Zip code is 11741
    .00204 MF and 62% residual
    .00193 MF and 62%
    .00117 MF and 59%
    .00105 MF and 58%
  • scooterxscooterx Member Posts: 13
    Can I have the MF, and residual for a 2022 CX-5 Turbo 36/10k & 30/10k zip is 01863. Thank you!
    .00066 MF
    58% 36/10
    64% 30/10
  • 4141Car4141Car Member Posts: 4
    Can I have the MF and residual for the following:
    2022 Mazda CX-5 Premium 36/15 and 36/12
    92545
    92545
    .00117 MF and 57% residual
    what about 36/12?
    May I please have the MF and residual for the 2022 MAZDA CX-5 2.5 S SELECT PACKAGE?
    33/10 zip 92106
