2022 Toyota Tundra Lease Deals and Prices
1235711
    MichaellMichaell Moderator Posts: 241,337
    joshor said:
    .00235 MF and 72% residual
    Either trim
    Through 04/04
    Don't have the one-pay info
    No info on the Hybrid models
    Much appreciated. Could I also get the numbers for the limited? Didn't realize option packages would get me what I want. ( 5.5' CrewMax 4x4, 36mo/12k for 97302)
    Do those numbers normally change once a month?
    Thanks again!
    74% RV for the LTD trim.
    Current programs run through 4/4.
    2015 Subaru Outback 3.6R / 2014 MINI Countryman S ALL4
    Mr_Ralph_91Mr_Ralph_91 Member Posts: 2
    Can some one help with MF and RV on a 2022 Tundra Limited CrewMax 4x4 for 94578
    36/12k
    36/15k
    48/12K
    4815k
    36/12k
    36/15k
    48/12K
    4815k
    .00235 and 72%
    Longer terms not supported
    Hollis16Hollis16 Member Posts: 1
    Hello! Looking for MF and RV for 2022 tundra crewmax, limited, 6.5’, 4x4, 44236.
    30/15k
    36/15k
    30/15k
    36/15k
    .00235 MF
    78%
    72% RV
    BabayagaBabayaga Member Posts: 9
    MF, RV on a Tundra 4dr SR5 Crewmax 4x2 36/10 33414 Thanks!
    kyfdxkyfdx Moderator Posts: 237,266
    .00175 MF and 73% residual
    edited March 2022
    MF, RV on a Tundra 4dr SR5 Crewmax 4x4 36/12 33414 Thanks in advance!
    .00175 MF and 75% RV
    Chuck253Chuck253 Member Posts: 5
    May I have the MF and Residual for the following in 98499.
    2022 Toyota Tundra Limited CrewMax with 6.5ft 4x4 - 36/12k, 36/10k
    .00235 MF and 74% residual
    callaweiicallaweii Member Posts: 9
    Can you please provide the MF and RV for a 2022 Toyota Tundra SR5 CrewMax with 5.5ft 4x4 and Limited Crewmax with 5:5 4x4?
    11355
    11355
    .00235 MF
    76%
    82% residual
    IncisionIndIncisionInd Member Posts: 20
    Can I please get the MF and residual value for the following:
    TOYOTA TUNDRA SR5 CREWMAX 4x2
    36 / 12
    76063
    36 / 12
    76063
    .00235 and 75%
    tlstyle1tlstyle1 Member Posts: 13
    Could you provide the residual and MF for a 2022 Tundra Limited crewmax 4x4- zip code 27215
    1794 crewmax 4x4
    1794 crewmax 4x4
    .00175 MF
    71% LTD
    67% 1794
    I believe the MF rates were good till 4/4 (tomorrow). Can you provide the new MF rate or should I inquire on 4/5?
    Correct. Ask on Tuesday
    urnzway1urnzway1 Member Posts: 25
    Can I please get the April residual and mf for 2022 Tundra Limited crewmax 4x4 & Platinum crewmax - zip code 28031? Looking at 36/12K term. Thanks!
    2022 Toyota Tundra Limited CrewMax with 6.5ft 4x4 - 36/12k.
    .00175 MF
    71%/67% residual for LTD/Plat
    lstewielstewie Member Posts: 63
    Please
    Limited CrewMax 5.5 4X4
    lstewie said:
    Please
    .00235 and 75%
    sneedo24sneedo24 Member Posts: 7
    Hello, could you please provide Res and MF for 4x4 Platinum 5.5 bed crewmax?
    37312 zip
    Thank you in advance!
    37312 zip
    .00235 MF and 73% residual
    lstewie said:
    Please
    .00235 and 75%
    Does TFS do a 39/10k? If so what would it be for same truck?
    lstewie said:
    lstewie said:
    Please
    .00235 and 75%
    39 month term not supported
    nrm91nrm91 Member Posts: 5
    Hello, could you please provide Res and MF for 4x4 Platinum 5.5 bed CrewMax?
    98107 zip
    Appreciate the help!
    98107 zip
    98107 zip
    If the dealer is quoting me at .00345 for MF, what can I do? He says they have no control over that. I have excellent credit
    nrm91 said:
    98107 zip
    You can shop other dealers, or you can walk and try a different brand.
    Dealers have the upper hand at the moment, in this tight market.
    finns2000finns2000 Member Posts: 8
    Hey guys, can I please get the RV & MF for 36/12 on a 2022 Tundra SR5 4x4 CrewMax in 27592?
    TIA!
    TIA!
    DrahtDraht Member Posts: 1
    MF and residual for a 22’ Tundra 1794 crew max 4X4, 6.5’, iforce max. 17331 zip, 36/10 and 48/10
    We don't have the 48 month terms
    Adriek0491Adriek0491 Member Posts: 6
    Can I get MF an RV for a 1794 and limited 5.5 36/10 36/12 zipcode: 13603? Thanks
    2WD or 4WD?
    whiteHackwhiteHack Member Posts: 37
    Can I get MF an RV for a 4WD 1794 and limited Dual Cab 36/10 36/12 zipcode: 27617. what's the best residual value in terms of month/miles
    36/12 (36 month is the only supported term for the SouthEast Toyota region)
    .00175 MF
    71% LTD
    67% 1794
    .00175 MF
    71% LTD
    67% 1794
    what about 4X4 1794, Limited, SR5 in CREWMAX 36/12 && 39/10 for zipcode: 27617
    .00175 MF
    71% LTD
    67% 1794
    .00175 MF
    67%, 71%, 74% residual
    Correction to previous answer
    Double Cab
    Limited: .00175 MF and 67% residual
    There is no 1794 double cab
    .00175 MF
    71% LTD
    67% 1794
    .00175 MF
    Double Cab
    thanks, could you please tell me for which trim and model and lease term 4X4 would have the highest residual value? if not, it's fine. I will do more readings.
    am0290am0290 Member Posts: 11
    2022 Toyota Tundra 4WD SR5 Double Cab 6.5' Bed 3.5L
    Please and thank you
    whiteHack said:
    .00175 MF
    71% LTD
    67% 1794
    .00175 MF
    Double Cab
    SR Crewmax: 84% residual
    SR5 Crewmax: 74% residual
    whiteHack said:
    .00175 MF
    71% LTD
    67% 1794
    .00175 MF
    Double Cab
    is there any differences between SR5 Crewmax and SR% LB Crewmax in terms of residual value? 74% is for 36/12 right?
    .00235 MF
    70% residual
    whiteHack said:
    whiteHack said:
    .00175 MF
    71% LTD
    67% 1794
    .00175 MF
    Double Cab
    74% is for 36/12 on SR5 Crewmax 4x4 shortbed
    For the longbed, the RV is 75%
    .00235 MF
    70% residual
    Can I get the 36/12 as well please
