2022 BMW M3 Lease Deals and Prices
13
  • MichaellMichaell Moderator Posts: 269,468
    Bmwm333 said:
    Hi everyone,
    2022 BMW M3 competition
    36 months
    12k miles a year
    I would like to know what the money factor is for a lease?
    Credit is 820.
    Dealer offered 0.00216 which seems pretty high.
    Please advise.
    .00176 base rate
    Dealer can mark it up 40 basis points.
  • new2popnew2pop Member Posts: 24
    need help on MF and Incentive for 2022 M3C, zip code 92618, 36 mths / 10k miles.
    Thank you in advance.
    .00176 MF and 57% residual
  • sashah60sashah60 Member Posts: 58
    What are the May 2022 residuals (36/10k and 36/12k) and MF for 2022 M3 Comp xdrive? Any incentives and loyalty? zip 10506. thank you.
    .00190 MF and 55% RV
    $1000 loyalty
  • kyfdxkyfdx Moderator Posts: 273,291
    Be aware that the residuals for the Competition model are lower than the regular M3
  • 2009gtr2009gtr Member Posts: 34
    Can I get the May residuals and MF for 36/10 for a 2022 manual base m3. Thanks
    .00190 and 57%
    Hi. What are the June 2022 residuals (36/10k and 36/12k) and MF for 2022 M3 Comp xdrive? Any incentives and loyalty? zip 10506. thank you.
    .00190 and 55%
    $1000 loyalty
  • MFactorMFactor Member Posts: 13
    What are the MF and incentives for Colorado zip 80027 on a BMW M3 Base stick shift? Is it different for 7,500 mi vs 10,000 mi?
    Is there a state(s) that has the lowest money factor where it's best to order a lease?
    .00190 MF and 56% RV
    Add 1% for 7500 miles
    BMW numbers are national
    Does anyone know if every BMW dealer typically adds the 0.00040 to the 0.00190? That is the max the BMW allows the dealers to add to the MF and I've talked to two dealers now who max it out at the 0.00230. I'm doing an order so can use any dealer. I just want to find one that sells at MSRP and also doesn't max out the MF to .00230. Thanks!
    Not sure about "every", but I wouldn't be suprised if the answer was "most".
    Keep calling around; it only takes one dealer to give you the base MF.
    Alright, I'm calling every dealer in the state and every dealer in cities where I travel for work. We'll see who can strike a deal..
    Hi. What are the July 2022 residuals (36/10k and 36/12k) and MF for 2022 M3 Comp xdrive? Any incentives and loyalty? zip 10506. thank you.
    .00190 MF and 56% residual
    $1000 loyalty
  • barad55barad55 Member Posts: 18
    edited July 2022
    Hello, can I get the MF and RV for
    2022 m3 xdrive.
    Loyalty $?
    College grad$?
    Zip: 95020
    2022 m3 xdrive.
    Loyalty $?
    College grad$?
    Zip: 95020
    $1000 loyalty
    $1000 grad
    2022 m3 xdrive.
    Loyalty $?
    College grad$?
    Zip: 95020
    $1000 loyalty
    $1000 grad
    Many Thanks!
    My dealer is saying that loyalty may have gone up to 1k on other models but not
    on m3's, not too sure if this is accurate. Please advise?
    thank you.
    @barad55 said:
    Many Thanks!
    thank you.
    I'm hearing that loyalty went up from $500 to $750 for the M3. College grad is $1,000 but they said they are getting a lot of people denied after applying.
    If you have a long wait time, consider joining BMW CCA for a $500 rebate. You are eligible or $500 rebate after 6 months of membership I believe.
    barad55 said:
    2022 m3 xdrive.
    Loyalty $?
    College grad$?
    Zip: 95020
    $1000 loyalty
    $1000 grad
    Many Thanks!
    thank you.
    Our information is accurate.
    No reason for the dealer to deny the incentive to you; it comes from the factory.
    Is it possible that the incentives are different for different BMW models?
    It is, but I confirm $1000 loyalty on the M3, this month.
  • toothdoc92toothdoc92 Member Posts: 6
    Hi, may I please have the residual, MF and incentives for the 2022 M3 Competition?
    36/12k, zip code 46410.
    .00190 and 56%
  • Franklin1978Franklin1978 Member Posts: 3
    edited July 2022
    Hi, I have a 2023 M3 competition that should arrive next month. What would be the residual at 12k miles and MF? Thanks! Zip code is 95111
    Please repost in our new 2023 M3 discussion
  • amukamuk Member Posts: 8
    Hi can I please get the residual, MF and incentives for the base 2022 M3 on a 36/7.5k lease? Zip is 60148
    .00190 MF and 58% residual
    I happen to be eligible for the student, military, and loyalty incentive. Do they let you stack those on a 2023 M3 Base purchase? Thanks!
    Loyalty will likely be compatible with either of the other two (Grad and Military...nothing for student), but those two (Grad and Military) are incompatible with each other
    edited July 2022
    Thanks kyfdx. I meant grad.. didn't know about that, good to know ahead of time. I also got the BMW CCA membership so trying to squeeze every discount I can put on the purchase. I also got an OL code from an event but those were questionable before the shortage so it will probably be worthless now..
    The OL code may be incompatible with Grad or Military, in any case. BMW CCA is a rebate, after that fact, so that should still be available.
    Hi. What are the August 2022 residuals (36/10k and 36/12k) and MF for 2022 M3 Comp xdrive? Any incentives and loyalty? zip 10506. thank you.
    .00200 MF and 55% residual
    $1000 loyalty
  • NPersonNPerson Member Posts: 17
    Hello:
    Looking for some advice.
    Car: 2022 BMW M3: Competition Package: xDrive
    Facts: 2 year Lease / 10k mileage allowance
    Zipcode: 92612
    Advice:
    August 2022 Residual?
    Money Factor?
    Incentives for my Zipcode/Southern California?
    NPerson said:
    Hello:
    Zipcode: 92612
    Advice:
    Money Factor?
    .00200 MF and 60% residual
    36 month is much better with a 56% residual
    Can you pls confirm
    rebates zip 95020/Southern California?
    Loyalty rebate is $?
    and
    College Grad $?
    Can you pls confirm
    and
    College Grad $?
    $1000 loyalty
    $1000 grad
    Thank you for your previous help.
    New Question:
    Car: 2023 BMW M3: Competition Package: xDrive
    Zipcode: 92612
    Advice:
    Money Factor?
    New Question:
    Zipcode: 92612
    Advice:
    Money Factor?
    Please repost into the 2023 M3 discussion
  • culbyg7culbyg7 Member Posts: 71
    Can I get mf and residual for 2022 X drive M4 comp 36/7.5, 36/10, and 36/12 in 92064? Any loyalty or other incentives?
    .00200 MF and 54% residual
    $500 loyalty
    Is the mf the same for all 3 since you only answered for 1
    Yes, the MF is the same
    Are the residuals the same as well?
    +1% for 10K/yr, +2% for 7.5K/yr
