As I wrote before, the Bronco got a batch of 2.7's instead of them going into F150's. There just happened to be some bed engines in the batch.
The article said, “Ford identified the root cause as the valve 'keepers' not holding the retainer in place allowing the valve spring to detach from the valve resulting in interference between the valve and piston”.
How can you screw up “valve keepers” other than to cheapen the steel they’re made of or the machining of them? Granted there are 2 of them used for every valve in every engine but they’re so small if they hit you in the face you’d barely wince. Any car manufacturer who cuts cost on these deserves the engine failures that result.
QUESTION
I am hoping that you can assist me with a problem that I am having with my GM dealership. I purchased my vehicle in March 2021. The truck now has just over 36000 miles on it. The engine started to misfire about three weeks ago and it got progressively worse so I took it into the dealership. They, at that time, told me that the truck’s engine was still under warranty. I received a call two days later and they told me that they wanted to see invoices from where I had changed the oil. My problem is that I changed the oil myself so I do not have any invoices saying that the oil was changed either at a dealership or at a lube place. I cannot produce any invoices so I am told that the warranty is void. Nowhere in the owner’s manual does it say that you cannot change the oil yourself or that you have to show invoices of oil changes. It just tells you that the oil should be changed at regular intervals, which I have done. The dealer tells me that the camshaft is worn out on two lobes and it was because of dirty oil. I do a lot of driving on country gravel roads so that may account for the dirty oil. Anything that you could do to help would be appreciated.
Don
ANSWER
I called the dealership for you and it is not so much that you do not have any oil or oil filter invoices but it is the fact that the oil filter, that is still on the truck, appears to be the original oil filter. When they questioned you about the oil filter, you told them that you use fully synthetic oil, which does not require one to change the filter. I do not know from where you received that information but that is not correct. Synthetic oil is a better lubricator but it still gets dirty and needs a good filter to filter out unwanted particles. With 36000 miles on the odometer; no oil change invoices and what appears to be the original oil filter still on the truck, I do not know of any automotive manufacturer that would warranty a failed lubricated part in their vehicle. I am sorry but I cannot do anything for you.
That is what I call "False Economizing". Thinking you can save money by not letting the "Guy" do it.
Anyway, like @laurasdada, she’s a die hard Jag lover. She finally got the insurance check.
New cars are hard to come by, as we all know. New Jags that she may like, are even harder to come by. SUVs are off the table for her.
So, this entire week we’ve been searching. Found this gem Thursday. 2017….One owner, Jag certified, all records complete, 38,000 miles. I drove it before I showed it to her. Strong runner, well kept. But, we MUST get rid of the aftermarket tint. She picked it up last night.
Nice car!
2023 Mercedes EQE 350 4Matic / 2022 Ram 1500 Bighorn, Built to Serve
I’ve always loved those. Never drove one, though.
2018 VW Passat SE w/tech, 2016 Audi Q5 Premium Plus w/tech, 2006 Acura TL w/nav
Wow!
Beautiful! I love the interior especially.
If that guy followed Edmunds he would have learned from the experience of one of out posters that you have to keep proper records.
That said, I bet that truck had the GM cylinder deactivation system which is known to chew up camshafts. The damage would have happened sooner or later, the poor maintenance just caused it to happen sooner.
....how could the guy possibly think you shouldn't change the oil filter?
It may even be more important to change it if using synthetic oil....who knows - it may take more contaminates out.
Love the XJ, big beast, though. Will put a much bigger dent in CVS...
Pace with grace.
@sda said:
It does look nice.
I’d ditch the window tint since she already ran into a CVS presumably with untinted windows. Any extra visibility should be a good thing…🤣😂
Could also switch to a ceramic very light tint that would still help with heat.
If I had a $ for every pillow she has already, I'd have a new Boxster...
Between two homes we could cushion the fall from a Hummer dropped off the Empire State Building.
Don't get me started on pillows. Can't find the couch or the bed due to all the pillows. Pillows on the kitchen table chairs and not to mention all the pillows for the patio furniture that I have to store away every fall and haul out every spring. Oh and did I mention the pillow she has to have in the car?
When my wife passes away I'll open a pillow store.
It's not your sister's fault it was CVS' fault. If they didn't put a store there she wouldn't have hit it.
There you go your first round for the fodder.
I remember them being in a brown tub.
Moving some stuff in the garage around, I spot a brown tub.
I say to myself, that stuff was in a brown tub just like that.
There was a box of bike rack and cargo box stuff sitting in the tub.
Hmmm, that box doesn't look like it goes to the bottom of the tub, maybe I should check to see if there is anything underneath it.
DOH! There it all was, several hundred dollars worth of stuff.
QUESTION
Don
ANSWER
Warning long post coming up. Scroll now if you want to.
Since this seems to be your favorite subject let me TRY to explain it to you. Hopefully, for the last time.
I DID NOT, repeat, I DID NOT do my own oil changes to save a buck. I did them and other repairs because I wanted the work done right.
This is what happened to me when I took my first Genny for its first oil change:
I took the afternoon off to get a follow up check after my first cataract surgery. After that I thought this would be a good time to get the Genny it’s first oil change. I bought it in March of ‘09 and now it’s close to the end of July of ‘09. I was going to Myrtle Beach the first week of August. So this was the perfect time to do it. I go to the dealer unannounced but they’re busy. So the best they can do is squeeze me in at the end of the day. I can’t wait that long (it’s about 2 PM) and Mrs. j just happens to be working that day. So being picked up is not going to work. The SA told me that I could go to their lube center about 3 miles away. He was pretty sure they could take me right away if he called them. I told him to call. As I’m walking out, the thought came to me that since the Genny was a newly introduced car they might not have the filter. So I go back to the desk and he calls them again. Sure enough, the lube center doesn’t have the filter so I got one at the dealership and took it with me.
When I got to the lube center they were ready for me but before he writes me up I tell him I want to watch the oil change being done. Plus, I just wanted to nose around under the car while I was there since the car was new and I’d never climbed under it before. He promptly told me because of insurance reasons I couldn’t do that. I thanked him, picked up my filter that I put on the counter and was about to leave to do the oil change myself when I got home. All of a sudden he’ll now let me watch. After what transpired, I should have done it myself.
As I’m walking down into the pit the kid tells me I can’t come down there. I told him the guy at the desk said it was OK but he could check if he wanted to. He didn’t want to so I continued on my way to the bottom of the pit. To make conversation I asked the kid how many oil changes he’s done on a Genesis since it was a new car. In a bothersome tone he said, “ENOUGH”. I took that as a blow-off answer but how could I argue?
He now tries to remove the screws holding the access panels on but he doesn’t have the right socket. So much for ENOUGH. Strike 1.
He returns with the right socket and removes all the panel screws. Gets a wrench and removes the oil drain plug. The oil barely stops draining and he’s about to reinstall the drain plug. I told him I wanted more oil to drain before the plug is put back in and he should take the filter out and let it drain while he’s doing that (that’s the way I was taught but I guess he had a different teacher or forgot about his training). Strike 2.
He reluctantly starts to change the filter, like I suggested. However, he grabs a band style filter wrench with teeth, that is pretty long, and because of that he can’t get it on because of the angle. But that doesn’t discourage him and of course it slips off but not before he put some pretty good gouges in the heavy duty plastic filter housing. I get a little closer and I can see a large hex cast into the bottom of the filter housing and it is very accessible. I said, “there, it looks like the housing is design to be removed with a socket wrench”. He gets a little closer too and says, “yeah, I guess”. Guess what? He doesn’t have that socket either. He climbs out of the pit again to get it. Comes back with it and believe it or not, I didn’t have to remind him to reinstall the drain plug. That surprised the hell out of me. It’s a damn good thing the filter housing was over designed or there’s no telling what would have happened other than having some gouges in it that weren’t there when the car was built. He screwed up enough with this step to earn another strike. Strike 3. This kid should be out of the game but I still need the oil installed. Oh well.
OK, we’re now out of the pit and he removes the oil filler cap. He goes over and grabs the overhead hose marked 10W-30 and starts toward my car. I said, “WHOA”. He’s clearly annoyed with me by now and says, “what now”? I told him the car is designed for 5W-20 just like the cap says and I want synthetic not standard oil”. He goes to the car looks at the cap and says “OH, but it doesn’t say anything about synthetic”. I told him to look at the work order. He does and says, “OH, OK.” He comes back with the right oil but he only has 5 quarts. My car takes 6.8 quarts. I didn’t say anything about this yet, wanted to have some fun, I guess. He pours in the 5 quarts, closes the hood and proceeds to get into my car. I asked him what he was doing and he said, “I’m going to get you out of here, finally”. I warned him not to start my car because it needs more oil. He asked, “how much more”. I told him to read the manual that was in the glove box. He said he had another way to find out and proceeds to get more oil. He comes back with 2 more quarts of oil then asks, “how am I supposed to put in 0.8 quarts of oil ?” Being the wise guy that I am and not liking blow-off answers, I said, “just like you did it on the other Genesis oil changes you’ve done”. I then showed him how to do it by putting some in, checking the dipstick and adding more as needed. Is it legal to give someone more than 3 Strikes?
I got the message that my post is too long. I’ll post the rest in the next post.
If you think I’m the only one who has gotten a dud to do an oil change on his car you’re kidding yourself. Until you watch your Benz dealer doing oil changes, or any work on your car, you have absolutely NO IDEA how they do it. You’re just trusting that they know what they’re doing.
And people wonder why I check all 20 lug nuts when my wheels have been removed after having state inspections done or any work that required the removal of the wheels.
END
Went over the Sagamore bridge for lunch in Sandwich (MA) on the Cape Cod canal; shopping in the village (yes, pillows...) and then on to Mashpee Commons to shop some more. No pillows were purchased, but she saw a mirror at Pottery Barn and now is obsessing over a wooden whale at a local pop up store. She bought the mirror, but from Wayfair and at 1/3 the price. Good girl! Wonder if she'll go back to Mashpee tomorrow for the whale (it's sales tax-free weekend in MA, so if she's gonna go whaling, I encourage this weekend!).
And, surprise, I parked at a Tesla L2 charger and in what I believe to be about 90 minutes of shopping, got a full tank of neutrons! Didn't know Tesla made L2 with the J-1772 connector. Thanks, Elon!
And, as I posted elsewhere, saw a Range Rover Evoque convertible.
You have to trust someone at some point. Mistakes can happen, I really haven't heard of an MB dealer blowing an oil change, or any work really.
Now if I got my oil changed at Iffy Lube, then I would try to check it over before going very far.
And you wondered why the kid wanted you out of there? 😤 I will admit, however, that your words of wisdom stuck with me. When I did a fast oil change on my son’s car at the Quicky Lube I checked the dipstick and the drain plug when I got home.
I don’t buy what you’re selling. The dealer I go to touts all the training his techs have to. They have a wall plastered with training plaques.
If you checked for a proper oil change how would you do that? From what I’ve heard from you about your mechanical prowess, your in trouble. Talk is cheap and doers do.
In my opinion, when you get home it could be too late. My across the street neighbor did that a few years ago and found he was down almost 3 quarts. The dealer wanted him to come back right away but he refused and demanded they send a tow truck. They did and he rode back with the car. Turns out the nitwit didn’t remove the old filter gasket. Said he thought it came off with the old filter. That’s an almost full proof way to have a leak. No excuse for not being sure.
Fast forward to this past January when I took the Genny in for the ABS recall notice. While it was there I had them do an oil change. This time one of their experienced techs did it since he’s the one that had to do the recall work.
When the car was parked outside before I even started it as I was in the process of removing the dip stick, the SA comes running out asking if I had a problem. I told him I was just checking a few things in their driveway before I got home and had more time to check a few more things. He just smiled and said, “OK, now I remember. You like to check things”.
But I thought “the guy” ALWAYS knew more than the vehicle owner.
I’m SHOCKED!!! At least he didn't write the oil capacity on the engine cover with a Sharpie- that happened to a poor soul who brought his Stinger to a Kia dealer for "professional service."
And I’ve mentioned the oil change I performed on a older friend’s E83 X3; the previous “technician” had screwed up in almost every possible way.
Mine: 1995 318ti Club Sport; 2020 C43; 2021 Sahara 4xe 1996 Speed Triple Challenge Cup Replica Wife's: 2015 X1 xDrive28i Son's: 2009 328i; 2018 330i xDrive
The fiendishly complex oil filler cap
Smoke(ATF?) and mirrors
Writing the oil capacity might not be a bad idea. My cars range from 4.2 qt. To 8 qt. To be honest, I had to look it up myself.
Damn, I guess I’m not the only one who’s gotten a nitwit to do an oil change on their car at a dealership. Who woulda guessed that was possible at a Benz dealership too? I guess our poster buddy will claim, “not in Canada”. Yeah, right.
I was born at night (really, I was) but not last night.
Let the spin begin. I know it’s coming.
You’re welcome anytime but it won’t be quick. I’m never in a hurry and I double check myself as I do something. I’d hate like hell to find a mistake later. So far so good.
I have to think a lot of mistakes at dealerships and service places are the result of being in a hurry because the boss says something like, “come on, let’s get that car out of here. I’ve got 3 cars waiting to get in here before quitting time”.
@jmonroe
I have to say that I’m sure that dealers/oil change places/independent garages all make mistakes. I do however, think it’s not the norm.
I haven’t done my own oil change since the late 90s when I had my 79 Continental. Luckily (touch wood) I’ve never had an issues with dealers or the independent garage I used. Did they use the right oil? Well I’d never know, but didn’t have any engines blow up either.
I know a lot of dealer and indie shops are short staffed- and that inevitably affects the quality of service. My dealer has been excellent overall but I’ve had a couple of “be backs” in the past two years- both involving the correct oil. I only caught them because I checked the part numbers on my receipts.
2023 Hyundai Kona Limited AWD (wife) / 2015 Golf TSI (me) / 2019 Chevrolet Cruze Premier RS (daughter #1) / 2020 Hyundai Accent SE (daughter #2) / 2023 Subaru Impreza Base (son)
I see the Flying Monkeys are adding their "Likes". That's funny, that means they are jealous.
It seems some people think they are genius's because they can do an oil change. Anyone could do it if they learned...watched Youtube, or tried it. I get no satisfaction doing something like changing oil when I could be playing tennis, or pickleball, or reading the newspaper or a book, or meeting friends. Big deal, you could probably teach a monkey how to do an oil change.
I have never had a problem with any oil change I have had performed in almost 60 years, why would I want to check on the job done...I would have wasted hours of my life. If something goes wrong the dealer will pay for it..........it doesn't make sense to re-check everything unless you are OCD (obsessive-compulsive disorder).
If you enjoy doing oil changes then knock yourself out, I have better things to do.
