1818819821823824854
  • kyfdxkyfdx Moderator Posts: 270,901
    We unplugged our landline
  • tjc78tjc78 Member Posts: 17,370
    We apparently pay for one, but it’s never been activated. Contract up in October and going to redo all the packages I have with Comcast.
    With mine your cost actually goes up without a landline because it is part of a bundle that supposedly gets you a discount.
    Same
    Yes that is the way it was for me too. I’m thinking of cutting things back far enough it may actually make sense not to have it any longer.
    We pay for so much stuff we don’t use.
  • xwesxxwesx Member Posts: 17,928
    Comcast is one of the worst. I think they actually sell your number to these guys the moment they set it up! We have a company in Ohio that is a sub of Comcast, and my wife would never answer the phone when I called because of that. So, we set up a call screening thing on the phone that does a surprisingly effective job of filtering the junk calls. Of course, it probably filters about half of the calls that we want to get, but you gotta take your wins where you can get them! :D
  • gsemikegsemike Member Posts: 2,452
    On the same page as that Studebaker there looks to be the bargain of the century.
    https://www.facebook.com/marketplace/item/3463686520543944/?ref=product_details&referral_code=marketplace_top_picks&referral_story_type=top_picks
    No mileage listed which means it probably has a million.
    Gotta be a scam
    I don't know how most any of these scams actually work but it seems to be a growth industry, from the number of faked text messages and automated voice mails I get that are telling me companies I've never done business with want to send me money if only I press 1 or click here. The robocalls are so bad I have essentially stopped answering the landline.
    I'd imagine they will pressure you to send a deposit by venmo to hold it because so many people are interested.
    Small victories.
    Radiator on Mustang has been leaking more and more lately, although not a lot.
    It's supposed to transported to OH in the next few days, so I thought I'd try to patch it up by putting some more stop leak in it. Did that a few years ago.
    Told the transport company that it had a small coolant leak so don't put it above other cars, just in case.
    The overflow bottle was full but it would get hot the more I drove it.
    Put in some Bars Stop Leak with some pellets and water pump lube in it.
    Bottle did say to refresh once a year. Maybe the old stuff just wore out.
    Drove it for half an hour after dumping it the Bars.
    Didn't seem to get hot as fast, but needle was still higher than I was comfortable with.
    When I got home I heard a bunch of gurgling and after it cooled off I checked the radiator.
    It was noticeably down. Thinking the thermostat has been stuck and opened up.
    This morning I added more coolant and drove it again. No leaks noted.
    Removed the radiator cap cleaned up that area and noticed overflow hole was completely closed with corrosion.
    Took a zip tie and cleaned out the hole and hose, then sprayed some canned compressed air in it.
    A bit later put a paper towel over the hole for the overflow and stuck the straw for the compressed air through it. Pressure blew off the hose from the radiator.
    Topped off the radiator and drove it again. No leaks.
    Temp was pretty normal and overflow bottle started working.
    Topped it off again and I'll drive it tomorrow.
  • oldfarmer50oldfarmer50 Member Posts: 24,529
    Small victories.
    Overheating and low coolant says head gasket to me but it could also be a clogged radiator from the stop leak. I had a leaky radiator on an old clunker van which I fixed with Bars. I half expected it to clog things up but it didn’t. Got lucky I guess.
    @oldfarmer50,
    No overheating just warmer than normal. I think it was due to a stuck thermostat.
    Coolant couldn't get back to the radiator.
    Thank god it's iron block and heads.
    What did the tab end up being on the transport?
  • sdasda Member Posts: 7,710
    @oldfarmer50,
    Perhaps once you get situated at the new house, time to flush the system of all that goo, replace the thermostat and determine and fix what is leaking. Your Mustang sounds like it is too nice of a car to just band aid and hope for the best.
    @sda,
    The car could get picked up as early as tomorrow for transport to OH, so I don't want to go too crazy.
    Just needs to get on the hauler and back off.
    Would feel bad if it leaked on some other vehicles while being transported.
    Will continue fixing it up some time after we move.
    Out not long after sunrise this morning - with a forecast high of 103 today and 105 tomorrow, this is not an afternoon car. Started smoothly this morning after being idle for 6 days, and started almost a little too quickly once warmed up - I "ground" the starter a couple times as I am used to it taking a few cycles to get going when warm. Enjoying it now, as winter is always on the horizon:
    Interesting story about Cougar 1.
    https://www.youtube.com/watch?v=Cc-QzB6LCoc
    The Cougar guy spins a good yarn, but he lost me right off the top with the story about Iacocca being in Moncton for the opening of a deep sea port. Moncton is on a shallow, silty river and that’s about it. The nearest seaport is Saint John, NB but I can find no reference to any Ford facility there.
    Interesting but not necessarily true. :)
  • benjaminhbenjaminh Member Posts: 6,747
    I like that Mercury....
    I like that Prelude a good deal. They've all rusted away to nothing here. That would be worth double here
    Love both red Ford trucks and the black Bronco.
    That interior fabric in the 98 Dodge reminds me of what they put into the Neon
    76 T-Bird is very equipped. Almost like a Mark
    What is 0-60 on the 66 Diesel Benz? 30 seconds?
    Probably around that on the diesel automatic fintail. Top speed in a car like that might be 80 on a good day, maybe closer to 70.
    Any classics on Long Island Nothing really old showing up today
    Like these Rivs so much more than the boattails I bet that heater core is involved
    This GTA shows well when wet Could be a decent driver
    Given the current state of things, this 4runner could be decent
    AlfaSpider A little paint, a new top, hhhmmmmmmm
    Here's another Spider in better shape
    300 ZX 3 pedals an T-tops but not turbo
    1990 F150 Looks good but all pics are from a distance. Rear main seal will be work
    Have you cross shopped used cars on craigslist with other websites/apps? What would you say is the ratio of people that post their car on 2 or more sites/locations vs. going exclusive?
    Will you find Facebook cars on Craigslist and vice versa?
    I see some CL cars on Marketplace. CL charges and Marketplace is free, so it is kind of the new CL.
    Along those lines, CL started charging to ward off scammers, now the scammers are on Marketplace, and there appears to be little control.
    Marketplace is so awful. And what kills me is that I was not allowed to advertise a wheelchair. Some kind of rule against that. Scams are OK, but a "medical device" is right out.
    When Craig's started charging, it killed it around here (Long Island). Just used car lots on there now
    That 90’ F-150 is just like my 85’ longbed that I bought in 1997 for $1500. I don’t recognize that engine. It isn’t the straight 6 or the old 5.0 that my truck had.
    I’ve sold several cars on Craigslist. I don’t use Facebook for anything. Does a $5 ad charge really chase private sellers away? I’ve heard many horror stories about Marketplace.
    The engine in that F150 is the 5.8(351). You can just read it, if you magnify it, on top of the intake manifold.
    Might be a sign of insanity, I saw this on a "auto archaeology" page, a Charger 500 that has been sitting outisde for decades, pics taken 20 years apart. I thought "and tell me more about the Tempo" (which I am sure was crushed ages ago):
    Wow, thats a shame. I guess when it was parked, it was just an old car
    I am sure by the second gas crunch, those could be had for three figures in good condition.
    That Mustang mileage may be legit. Those interiors did not hold up well and that looks really good
    Buuuuuttttt, what's with the exhaust? Missign tips make the rear valence look awful
    Agree on the Lumina Euro. If you're looking for a nice car, this aint it. That's classic :D
    I’d take the Super Coupe. Price is fair
    I think so too. 3 pedal examples have to be pretty rare these days
    edited August 2022
    The Mustang has been wrecked in the front.
    Regarding Candor, it can be funny. :D
    What are you seeing on the Mustang? Alignment of the front wheels in the wells?
    @gsemkie,
    There are several missing pieces in the engine bay(fan shroud being the most obvious) and the fenders don't have the factory vin stickers.
    @tjc78 sa
    Did the Supercharged 3.8 suffer from head gasket failure like the standard 3.8?
    @sda said:
    @tjc78 sa
    Yep.
    edited August 2022
    For that price you could probably get a 1993 Mark VIII with the 4.6L 4 valve. 75 more horsepower and no blown head gaskets.
    True, but lots of complicated systems to fail on that too.
    On that '79 Olds, he spelled "Gutless" wrong :p That's an Olds 260.
    Based on what Ive read the 260 was weak, smooth, fairly economical and long lasting. The 231 V6, about the same performance but not as long lasting.
    I know I've told this story before, but a friend off mine once had an '82 Cutlass Supreme sedan with the 260. I never drove it, but had ridden in it a few times. At the time, I had my Mom's old '86 Monte Carlo 305. One night, we did a little drag race out on the highway and, while the Monte was naturally faster, the Cutlass kept up better than I thought it would.
    It seemed okay for most normal, everyday driving, but I imagine after getting used to newer and faster cars, it would seem like a torture chamber by today's standards! The one 0-60 time I've seen quoted for a downsized Cutlass was by Consumer Guide, around 1981 or so, and they had it at something like 18.0 seconds. Funny thing, Consumer Reports had tested a Colonade '77 Cutlass sedan with the 260, and got something like 21.6 seconds. I'd think that losing close to 1000 lb would improve the time more than that. But, they most likely hobbled the downsized cars by giving them a taller economy axle ratio.
    Biggest failure point was the air ride. Any survivors would probably have had the air shocks converted. Other than that you’d face various part failures like any old car.
    I do recall the 3.8s having a real reputation for being here today gone tomorrow. More than 1 person would tell me that it was running completely fine and just blew.
    My understanding of the 231 is that it had a lot of narrow oil passages with right angles, that were easily clogged. It was also a very lightweight block, so it was fragile. It was also a "deep skirt" design, where the walls of the block extend well below the centerline of the crankshaft. Normally that's considered a bonus, as it would make the block stronger, but despite that, the block was still a bit thin and fragile. An added bonus was that nylon mesh timing gear, or whatever they called it, although I think that was an issue with a lot of GM engines at the time, and not unique to the 231.
    When the turbo version came out in the late 70's, it used a stiffer, sturdier block. For 1985, the 231 got a major overhaul, where they used the turbo block for all applications, and I believe they improved the lubrication/oil passages as well. When people talk about the "3800" being one of GM's best engines ever, they really mean the 1985 and newer versions. Or, perhaps one of the revisions after 1985, as I'm sure it got improved more in later years, although that plastic intake manifold was a step backward.
    The 1975-84 versions are pretty much junk, although I'm sure you can still find an occasional example out there that was well maintained. One thing I never could figure out though, is that the Buick 350 was a good, sturdy engine. Its main problem is that it didn't adapt well to emissions controls, so power was down pretty severely in later years, compared to similar-displacement engines. And, it was still too dirty for California, so they banned it in '77. But, both the 231 and the 350 have their roots in the old Buick smallblock from the 60's. In most years, the Buick V6 was just the V8 with two cylinders lopped off. But where they parted company was 1968. Buick sold its V6 tooling to Jeep, and used the Chevy inline-6 for what little demand there was for a 6-cyl Buick.
    GM bought the tooling back in the 1970's, boring it out a bit, so that it could use the same pistons as the 350 V8, which brought its displacement to 231 CID. The '67 version had been a 225. But, something must have been done to the engine, between 1967 and 1975, to make it the crap-fest it became.
    My 76 Sunbird with the odd firing 231 was reliable and didn't require any type of repair other than regular maintenance. The fact I was OCD with 2-3k oil change probably helped. I increased the idle speed a smidgen which smoothed it and I don't think hurt it other than reduce mpg slightly. I may have dodged a bullet with self destruction as it had 82K when I traded it in 84 for an 80 Mazda 626 coupe.
