Visitor Agreement.
Mike, start saving those pennys now.
Bob
Bob
I do think, for an IFS/IRS to really work off-road, this may be the best solution to the articulation/suspension travel question that has haunted off-road IFS/IRS systems in the past.
If the RR system proves to be a winner off road, then it's only a matter of time before less costly air-units make their way into mainstream brands. After all, almost all high-tech stuff first shows up on the high-end brands, and then eventually trickles down to lesser brands.
Bob
Haaa. That is the same exact type system that the XT6 had.
ECU was mounted under the driver's seat, onboard compressor in the driver's side fender. Sensors to detect the height of the vehicle above the road. Above 50mph, it would drop it down, slower speeds would have it raised. On the canadian models you could manually adjust it for additional clearance.
Are there any traditional springs/shocks in the vehicle? If not, I'll pass thank you, been there, done that.
-mike
That's hilarious, though. Imagine you high center and get stuck. All of the sudden, "Beam me up, Scotty", and it frees itself! Neat.
I wonder if the bladders are still natural rubber. Synthetic materials last longer and can resist corrosion when in contact with solvents. Audi also emulated the XT6 with the allroad quattro (lower case is theirs).
-juice
Jon
-juice
Did they remove that before bringing it here??
I find it interesting because it basically has the same AWD setup that my Forester has, plus traction control and HDC.
-juice
Do you know what the Range Rover use an even steeper gear reduction? If so, how, besides having a synchro between high and low range, are they able to do this without damage? What's the maximum speed you can downshift from high to low range?
Bob
Bob
They're cute, but once you put the stuff I'd want on them, they're a tad pricey for their size.
-juice
I sat in the Freelander at the Seattle Autoshow last Sat. Other than the pukey orange color(seems to be the rage this year on a lot of cars) it was pretty nice but nothing outstanding. I think it will do more for Landrover than adding anything exceptional to the small SUV crop available here in the States.
Stephen
I would actually consider a 2003 Forester, or especially a 2004 Forester Turbo, if the 626 lasts that long.
-juice
I do believe the Forester is an exceptional vehicle, heck I own one.
They do have a heated windshield standard on the S models, though. Isn't that the same basic thing?
They aren't really competitors, though. I'm sure the Land Rover will have wonderful wood and leather and the cache a Subaru can't match (for now).
-juice
-mike
I have a fancy high-tech feature on mine called "heat". Crank it up on defrost and get out and scrape!
Actually, I'm fortunate to park in a car port at home and a garage at work, so Sandy rarely gets exposed.
-juice
A good friend of mine leased a Disco II a few years ago. He didn't tell me until afterwards because he didn't want to hear me preach Subaru (I don't blame him ;-)). Less than a week after he got it, he and his family were left stranded by the road in snowy Vermont in the middle of winter. A problem traced to the stability control that later led to a recall. Any improvement over the years Chuck?
Don't more Disco's go off-road than RR's?
Scooby's have hill descent control. It's called lower gears. :-D
Dennis
It was this crappy attitude that led to demise of the rover group, quality was in the crapper.
They are pretty expensive when stacked up against the forester. IMHO.anyway.
Cheers Pat.
I remember Land Rover basically owned the market for UN-Spec cars my dad used to order for his fleets in Suriname and Belize. They swapped to Toyota because those were more reliable, though. I think they are so small that they needed a parent company to share resources with in order to survive in a cut-throat industry.
Manufacturers in general need to design fault-tolerant systems. I mean, look at computers. They never fail, and *&# $%*#^$# #$ #$(*#$ #$ #$(*#$ #$ #$(*#$|#$# $# $)(*#$
-juice
Bob
Bob
-mike
Bob
-mike
Bob
trailers w/o brakes 1,650 lbs
trailers w brakes 2,500 lbs
Bob
-mike
Bob
I'll keep you in the loop! I know that they tried to incoporate some of the Edmunds "wishes" in the Forester. I just don't know which things though.
Patti
Bob
Dennis
here's to hoping the Brat isn't nearly as ugly! how could it be, hehe
-Colin
Land Rover have been and still are beset with quality control problems, when I say it will take an attitude change thats what needs to happen before you will have a quality product.
Throwing large infusions of cash at the problem will not do it, BMW almost went broke trying to go the same route with Rover, and it was not lack of cash that did them in, it was years of piss poor quality.
I lived in Ireland for half my life and I speak from a consumer point of view I experienced it first hand.
Cheers Pat.
Stephen
• Feels much like the Forester on the highway, in terms of power and comfort.
• Much more refined than previous model.
• Loved the hand brake, auto gear shift fine, once you get used to it.
• Adjustable for/aft split rear seat. Although, I would probably keep it in its most rearward position. If you move it forward, you really sacrifice legroom. This would come in handy if you had a large item in the trunk, and needed to move the seat forward because of space.
• Interior is very well thought out.
• Towing is 1500 pounds, with or without trailer brakes.
• Auto up/down driver's window, which goes up and down very fast.
• Huge cargo area.
• Has green cruise control engaged light.
• $22,700 for EX automatic. This includes an average-sized moonroof.
Dislikes:
• Want more power still.
• Roof rack cross bars an option. I don't know rack capacity.
• No heated outside mirrors.
• Fixed intermittent front wiper, no variable speed feature. 1-speed rear wiper.
• Headroom marginal for such a tall vehicle. If it had a large moonroof, like the Forester, it could be problem for rear seat passengers.
• No front ash tray.
• Rear cargo cover is an option, and not standard. It is unique, in that it appears to retract both front and rear. It has a feature that allows for the reclinging split rear seat—which is good.
• Forester still feels a bit sportier in terms of handling.
Verdict:
Until the new Forester arrives, this is IMO, the new king of the hill.
Patti- better get that new '03 Forester info out there ASAP!
Bob
IMHO. this is a move forward.
Cheers Pat.
Ross
You can never get the smell out either, about six years ago I bought a used Honda Accord, it had low milage was absolutely mint no scratchs or dings,truly showroom condition.
The downside was it had belonged to a smoker,part of the purchase agreement was that the dealer get the smell out,
he did for about a month then it returned, I had it professionally valeted and detailed twice myself, I finished up selling it just could not get the smell out.
Cheers Pat.
-mike
