2023 Porsche Lease Deals and Prices (All Models)
1246710
  • paxton98144paxton98144 Member Posts: 6
    Hi there - Looking for MF, Residual and MRM for 2023 992 Turbo S Cabriolet for 24/36/39 with 5K per year.
    Zip 98144
  • MichaellMichaell Moderator Posts: 266,285
    Zip 98144
    .00340 MF
    65% / 56% / 56%
    $271,700 MRM
  • fabbfabb Member Posts: 3
    Hi there - looking for MF, rv, mrm for 2023 Taycan 4s in 98052. Aiming for 36mo and 48mo and 10k, 7.5k, 5k if possible.
    Thanks so much!
  • kyfdxkyfdx Moderator Posts: 269,288
    Thanks so much!
    36/10: .00340 MF and 53% residual
    39/10: .00340 MF and 53% residual
    48/10: .00360 MF and 38% residual
    MRM = $142,200
  • drejw2drejw2 Member Posts: 3
    .00340 MF and 60% RV
    $134,200 MRM
    How about 39/10k?
    Is it customary for dealer to add .0004 to the MF, and how do you get them to remove it?
    $134,200 MRM
    How about 39/10k?
    59% RV for 39/10
    Negotiate, like you would with the price.
    And, shop multiple dealers, if that's possible.
  • Drench321Drench321 Member Posts: 13
    Hello, Could you please provide the current MF, RV and MRM for a 2023 Cayenne Turbo S E-Hybrid Coupe with 36/12 and 39/12 terms. Zip is 92649. Thank you!
    .00340 and 51%
    $214,500 MRM
    Either term
    edited January 2023
    .00340 and 51%
    $214,500 MRM
    Either term
    Thank you, Could you tell me the residual for a Cayenne Turbo GT for the same term?
    Drench321 said:
    .00340 and 51%
    $214,500 MRM
    Either term
    49%
    $221,400
    (assuming you still want the coupe)
  • ICON617ICON617 Member Posts: 1
    Hello, Could you please provide the current MF, RV and MRM for a 2022 Taycan GTS with
    36 months with 12/10/7500k Terms and 39months 12/10/7500k terms and 42months with 12/10/7500k terms. Zip is 92101. Thank you!
    12K/yr
    .00340 MF
    52%/52%/48% residual for 36/39/42 months
    MRM = $152,300
  • lwlqk3lwlqk3 Member Posts: 5
    Thanks for your help. I was able to get a porsche Cayenne platinum 2023. They gave me the MF off .0034 and 63% RV by adding a year of PSMP. They had dealer additives like a clear bra but I was able to negotiate my adjusted cap cost close to sticker. A lot of dealerships had .0042MF or had dealer set price starting at 100K. If you are looking in NCAL Porsche Monterey is who I worked with. Thanks again!
    Congrats! Thanks for the report
  • leasehnterleasehnter Member Posts: 80
    2023 Taycan RWD 39/7.5k. zip 11385. Thank you.
    .00340 and 53%
  • neburnebur Member Posts: 1
    2023 Taycan GTS sedan
    36months/10k miles Zip code: 28173
    .00340 MF and 52% residual
    Either 36/10 or 39/10
  • DDT99DDT99 Member Posts: 64
    Can I get the MF Residual and MRM on a Taycan GTS in 91436
    Thanks in advance.
    Thanks in advance.
    39/15
    .00340 MF and 49% residual
    MRM = $152,300
    Thanks in advance.
    39/15
    MRM = $152,300
    Sorry for not clarifying. Can I get 36/12 and 36/10?
    DDT99 said:
    Thanks in advance.
    39/15
    MRM = $152,300
    Same MF
    51% 36/12
    52% 36/10
    (however, the 36 and 39 month residuals are identical for Porsche, this quarter).
  • WowsersWowsers Member Posts: 47
    Can i get a RV, MF and rebates or incentives for 2023 Panamera E hybrids? Also MRM
    Both 4wd or 2wd
    edited February 2023
    Both 4wd or 2wd
    Too many models to list them all.
    Give me your top 3 choices.
    Also, term and mileage?
  • MkahlonMkahlon Member Posts: 10
    May I please have the MF, RV, and any incentives for a 2023 Macan S and GTS (both awd).
    Lowest miles and longest term.
    Zip 20155
    Zip 20155
    60 months
    5K miles
    .00375 MF
    44% S
    46% GTS
  • MerdiniMerdini Member Posts: 4
    Can you please share the RV, MF, MrM for the 2023 cayenne base for 36mo, 12k miles? Zip 22204
    Can you please share the RV, MF, MrM for the 2023 macan base for 36mo, 12k miles? Zip 22204
    .00340 MF
    62% residual. $94,500 MRM
    64% residual. $73,500 MRM
    Same numbers for 36 or 39 months
    Could you please share the RV and MF for the 2023 cayenne base for 36mo, 12k miles? Zip 19711
    Could you please share the RV and MF for the 2023 macan base for 36mo, 12k miles? Zip 19711
    Porsche numbers are national
  • Bigtony1660Bigtony1660 Member Posts: 23
    Can you provide the MF, MRM and residual for a Tycan Cross Turismo 4 36/12? Does the $7500 lease rebate apply to the Cross Turismo?
    .00340 MF and 52% RV
    $127,900 MRM
  • nkcnkc Member Posts: 7
    Can you provide the Money factor and residuals for a 2023 Taycan GTS? zip code is 06830. Looking at 24/36/39 months at 10k and 12k miles/yr. Thank you!
    .00340 MF
    60%, 51%, 51% for 24/36/39 and 12K
  • ckvdmckvdm Member Posts: 8
    Hello, can you please let me know the RV and MF for the below:
    2023 macan base for 36mo/12k miles and 36 mo/10k miles in Zip 92091
    2023 cayman 718 base for 36mo/12k miles and 36 mo/10k miles in Zip 92091
    36/12 (and 39/12)
    .00340 MF
    63% Cayman
    64% Macan
  • gerardpkgerardpk Member Posts: 46
    Could I get MF, RV and any incentives for Taycan 4 Cross Turismo in 90034?
    36/10.
    36/10.
    .00340 MF and 53% RV
  • vchauvchau Member Posts: 4
    Hello -may I have the residual and MF for Cayenne S, zip code 19123, 36/39/42 with 12k. Thank you!
    .00340 MF
    60% / 60% / 56% RV
  • calkarcalkar Member Posts: 6
    2023 Taycan 4S
    MF
    RV
    MRM
    36/12k @94566
    calkar said:
    2023 Taycan 4S
    MF
    RV
    MRM
    36/12k @94566
    52%
    $142,200
    Either 36/12 or 39/12
  • TuceTuce Member Posts: 15
    2023 911 Carrera 4S coupe
    MF
    RV
    MRM
    36/7.5k and 39/7.5k
    10576
    MF
    RV
    MRM
    36/7.5k and 39/7.5k
    10576
    .00340 MF
    66% RV
    $171,00 MRM
    Either term
  • dsamardsamar Member Posts: 2
    Hello -may I have the residual and MF for Cayenne S, zip code 07726, 36/39/42 with 12k. Thank you!
    .00340 MF
    60%/60%/56% residual
  • KarlaHKarlaH Member Posts: 8
    Hi, can I get the MF & Res for Panamera 4S? 15k/36 Thx!
    .00340 MF and 58% residual
    For either 36 or 39 months
  • jeanpaultujeanpaultu Member Posts: 7
    Hi there, can I get the residual, MF, and MRM on a 2023 Cayenne S (Platinum Edition, if it matters) for 36/39/42 months with 7.5k/10k/12k miles? Thank you.
    12K/yr
    .00340 MF
    60%, 60%, 56% residual
    MRM = $116,300
