2023 Jeep Wrangler Lease Deals and Prices
145791029
  • kyfdxkyfdx Moderator Posts: 272,631
    txdude said:
    I'm seeing updated MFs by trim, e.g. 0.00178 for Sahara 4xe. (at least in zip 63005)
    That's correct
    For Sahara trim:
    .00178 MF and 57% residual for 36/10
    @txdude I don't know when those updated.. Sometime after the first of January, obviously.
  • MikeInColoradoMikeInColorado Member Posts: 4
    Good morning, I’m contemplating upgrading my 2022 Rubicon 4xe today. I was wondering what the mfr and residual values would be for a ‘23 Wrangler Rubicon 4xe and Wrangler Sahara 4xe on a 36/10 lease, in 80111 zip code. Also I see CCAP is still doing the $7500 as a cap cost reduction, as well as a CARB $3,000 taxable rebate (which ends today, correct)? Thank you for your time.
  • MichaellMichaell Moderator Posts: 268,943
    RUB - .00237 and 59%
    SAH - .00178 and 57%
    $3000 incentives
    $7500 federal tax credit pass through
    Yes, programs expire today.
  • txdudetxdude Member Posts: 6
    Best I can tell, around Jan 20th. A rare mid-month update. Must need to move some units.
  • dalemadalema Member Posts: 93
    edited January 2023
    $3000 incentives
    That sounds around the right date - one of the dealers mentioned in on one of the Jeep wrangler forums.
    I can confirm those numbers on the Sahara 4xe as I picked one up just now - looks like excess inventory / they had pumped a bunch of the hybrids out before the end of the year so have a build up of them this month.
    Also, dealers were willing to do between 4% and 8% off invoice for in stock units - normally that was just reserved for if you ordered / built one.
    Not sure if this is a good sign going forward or just temporary though!
  • Htownfanatic1Htownfanatic1 Member Posts: 5
    Hi! May I get the RV/ MF/ Incentives on a
    23' Wrangler Sahara 4xe
    and 23' Wrangler Rubicon 4xe
    zip 77379 and for 36 months/10k . Thanks a lot.
  • Tim5150Tim5150 Member Posts: 101
    Can I please get MF/RV for a Wrangler Unlimited Willys edition? Zip Code 32547.
    48/10
    48/10
    Standard MF
    57%
    62% residual
    What is the Standard MF?
    We don't yet have the actual rates for February.
  • NightRiderNightRider Member Posts: 6
    Can I please get MF/RV for a Wrangler 4xe Willys edition? Zip Code 70503
    Ehichever terms are allowed
    24/7.5
    24/10
    36/7.5
    24/7.5
    24/10
    36/7.5
    24/10 - .00419 MF and 62% RV
    36/10 - .00185 MF and 58% RV
  • Awl1123aAwl1123a Member Posts: 14
    Can I get MF/RV for Wrangler 4XE both Sahara & Rubicon? Zip -21014
    36/10 & 36/12
    36/10 & 36/12
  • SmashvilleSmashville Member Posts: 6
    Could I get the Residual Value and Money Factor for a 2023 Jeep Sahara Wrangler 4XE in the zip code 37174 for 48 months and 10,000 miles? Please provide the standard Money Factor rate for a Tier 1 at 48 months and 10,000 miles. Thank you!
  • Paradise01Paradise01 Member Posts: 7
    Hello, Can I please get MF/RV for a Jeep Wrangler High-Altitude edition in Zip Code 18337?
    36 months is the longest with lease support
    .00178 MF and 54% residual
  • sheerheresheerhere Member Posts: 16
    Hello, can you tell me what the MF/RV is for a Wrangler 4xe Willys and Rubi 36m/ 12K and 15K in 20854
    Willy - .00185 MF and 55% RV
    RUB - .00237 MF and 56% RV
    $4000 incentives
    Besides the $7500 PHEV credit, are there any other lease incentives for 75074?
    No
  • cndnbkncndnbkn Member Posts: 76
    Any incentives for 4xe rubicon or Sahara for 27517 zip?
    No incentives for your region
  • Hello - can you provide MF and Res for:
    Sahara 4xe - 36/12 and 36/15
    Sahara - 36/12 and 36/15
    Also, any incentives for zip code 60175?
    Thanks in advance!
    Thanks in advance!
    $7500 lease credit
    Standard MF and 56% residual
  • Thanks - what
    Thanks in advance!
    $7500 lease credit
    Thanks. What about the 36/12 options? Can't find them.
    Thanks - what
    Thanks in advance!
    $7500 lease credit
    +2%
  • kyfdx said:
    Thanks - what
    Thanks in advance!
    $7500 lease credit
    +2%
    Thanks!!
  • sonu79sonu79 Member Posts: 28
    edited February 2023
    Hi, Looking for MF and Residual for 2023 highaltitude 4xe, Sahara4xe in 92128 along with incentives.
    36/10.
    36/10.
    $3000 incentives
    Either trim
  • ExotichExotich Member Posts: 1
    Dear Mod - can you please provide MF and Res for:
    Sahara 4xe - 36/12
    Sahara 4xe high altitude- 36/12
    Also, any incentives for zip code 21228?
    Thank you so much!
    Sahara 4xe - 36/12
    Thank you so much!
    .00178 MF and 56% RV
    $4000 incentives
    Either trim
    Hi, Looking for MF and Residual for 2023:
    -Rubicon 4xe
    -Sahara4xe
    Zip 27517 along with incentives.
    36/10. TIA
    -Rubicon 4xe
    -Sahara4xe
    36/10. TIA
    .00237 MF and 59% residual
    $7500 EV rebate
  • zosuwbmzosuwbm Member Posts: 10
    Question about the Zip Code portion for the incentives... are the Jeep incentives based on the zip code I'll register the vehicle in (99223) or the dealer's zip code (e.g. 98133). The dealer's zip code has more incentive lease cash than my home zip code.
    It's the dealer, in most cases, but we don't know specifically about Chrysler Capital.
  • JCMJCM Member Posts: 11
    What are lease options for Wrangler Sahara 4xE, 36/15k, zip 13439
    $4000 incentive
  • 1jarretts1jarretts Member Posts: 4
    Hi!
    Can I please get the MF and residual for 2023 Willy’s and Sahara 4xe. 36/10. Zip 06907. Any incentives? Thank you!
    1jarretts said:
    Hi!
    Willys - .00185 and 58%
    Sahara - .00178 and 57%
    $4000 incentives
    $7500 PHEV credit
  • ec1ec1 Member Posts: 80
    Can you provide the same info as requested by
    1jarretts above for zip 37203? Thanks!
    The same, but the $4000 doesn't apply to your state. Just the $7500 credit is valid
  • nickndounickndou Member Posts: 1
    Lease options for a Willys 4xe for 36/12? Zip Code 48315 and incentives, or EV credit?
    .00185 MF and 57% residual
    $7500 PHEV lease cash
  • henrymphhenrymph Member Posts: 14
    Can I please have the MF, RV, on a 2023 Jeep Sahara 4Xe, for 36/10k in zip 30326. Incentives? PHEV Credit?
    .00178 and 57%
    $7500 PHEV Credit
  • FloridaGator727FloridaGator727 Member Posts: 18
    Hi!
    Can I please get the MF and residual for 2023 Willy’s 4xe. 36/10. Zip 33616. Any incentives? Thank you!
