1296229632965296729683158
    VW ended up making car net free for a few years
    https://electrek.co/2023/03/07/vw-car-net-free-for-5-years-carjacking/
  • tjc78tjc78 Member Posts: 17,371
    @oldfarmer50 said:
    I wonder which engines and which years?
    It’s the 2.0 and 2.4. Seems like from 2011 on. Debris causing the rod bearing to go prematurely
    This link explains it pretty well
    https://www.thetruthaboutcars.com/cars/news-blog/hyundai-and-kia-s-decade-of-very-troublesome-engines-continues-44497118
  • ab348ab348 Member Posts: 20,613
    I assume H/K must use different engine plants for different markets. On a UK car forum I mentioned their engine problems and everyone from over there had never heard of such a thing, nor was there any service campaign or recall in the Euro market for it.
    Tell me you don’t trust your vendor to handle an emergency without telling me…
  • oldfarmer50oldfarmer50 Member Posts: 24,532
    Oh oh, I have the theta II 2.0 in my Kia. No oil burning issues so far between 5k full synthetic changes. They did a recall last year to upgrade the knock sensor.
    Currently they have a recall for emissions.
    The only real worry I have is with carbon buildup from my mainly short distance drives.
    I read somewhere that the cars built in Korea rather than elsewhere have fewer engine problems.
    40% through 60 month 0% Audi FS loan on the A7.
    Halfway through warranty, don't imagine I'll keep it too much out of warranty with the complicated flux capacitor system...
    WOW
  • stickguystickguy Member Posts: 54,096
    Need more Italian tune-ups.
    WOW
    Too bad they can't just drop one of these into their HynKias. Then they'd have a real performance car.
    (From an old newspaper ad)
    419K is pretty impressive, but that poor thing gave it's all and is ready to be buried at see.
    the not road worthy signs should give bidders pause. Not quite sure what you would do with this ratty thing. certainly not pay to get it back on the road.
    also, I don't think I could comfortably fit in a standard cab ranger. Need the extended cab to have enough room to push back and recline the seat.
  • jmonroe1jmonroe1 Member Posts: 9,684
    From the looks of that beast it doesn’t look like it would take too much pushing to move the seat into your comfort range. After that you’re on your own.
    I think that only works on port injected engines not GDI.
    I’m willing to try though.
    edited March 2023
    Lots of cars need a battery. There are concessions that have to be made when buying used. You can’t have everything.
    Speaking of H/K and their engines, etc., I've just been informed by my Genesis dealer that when I bring my car in for it's oil/filter change in 12 days, they will be using full synthetic oil as opposed to a synthetic blend which they have been using for years during their 3 year complimentary maintenance program. I am going to assume that they will not change the oil and filter as frequently as they have in the past - in other words, they would do the servicing once every 10-12 months or 12,000 miles, whichever occurs first, instead of every 6 months or 6000 miles, whichever occurs first.
    I wonder if this change is due to some of the problems they have been having with their engines. I have the 3.3 L V6 twin turbo. I've checked the oil levels frequently, but the levels are fine.
    Will, you asked me if my Ceramic Coating Dealer would do my coating for 0 dollars if he skipped the detail.
    The answer is no! In order to do the coating job, he first has to wash and detail the entire exterior of the car before applying ceramic coating. He also uses clay to remove any imperfections in the coating, especially on the hood area where the water is not beading as well as on the rest of the car. He applies the coating to not only the paint surfaces, but also to the chrome, the wheels, etc. The reason the cost is only $250 is due to the fact that the car has been given two coats of ceramic coating about 2 years ago. That involves a tremendous amount of time. I hope this answers your question, Will.
  • driver100driver100 Member Posts: 32,670
    I use Gmail. I used to send an email, and it would appear in my inbox again....I like that because sometimes I want to save my replies, or emails I send.
    All of a sudden all of my sent emails and my replies go into the trash file. I have to remember to go into trash, move the message to the inbox, and then save it.
    Does anyone know how to make sent emails return to my inbox?
    Thanx in advance. :)
  • kyfdxkyfdx Moderator Posts: 270,951
    Why don't you look in your "sent" mail?
    edited March 2023
    there are settings for what you want to happen when you delete, etc. Can go to archives or trash, can have trash automatically empty, etc. Always a good idea to just go poking in your settings and see what is checked.
    and you do have a sent folder, separate from what you see as sent in your inbox.
    Edit: answer can vary depending on what device and email program being used.
    GM offering voluntary buyouts to most salaried workers in the USA:
    https://www.cnbc.com/2023/03/09/gm-buyouts-us-salaried-workers.html
    He should be able to strip the affected hood and reapply.
    Perhaps you want all the other panels re-applied and the car detailed too though?
    For some reason it doesn't go to sent....it goes to TRASH. It makes no sense.
    Computers are pretty savvy these days. They know trash from legit. B)
    I have checked settings....can't find the place to do this.
    I tried redirecting my sent emails back to myself....but it won't allow me to do that.
    Emails I send out don't appear in my SENT file.....they seem to go directly to TRASH.
    I am trying to preserve them, maybe I'll see if there is a filter that marks them as important and gets put into the inbox.....but I have tried some similar things.
    Maybe it is a Windows 11 thing......my own emails go directly to TRASH.
    Surprised your post actually made it to this site....they need an automatic Trasher around here to save cyber space for future generations. :p
    Maybe this can help:
    https://support.google.com/mail/thread/6662624/sent-emails-are-automatically-going-to-trash-please-fix-undo?hl=en
    Thanks....I think that worked. I went into FILTERS like it said, and I said that any emails I send should go to my PRIMARY (inbox), they should be marked important, they should have a label on them (SENT label) and they should never go to SPAM.....in other words every option possible so it doesn't go to TRASH. I sent one to MrsD100 and she got it, it appeared in the inbox.....it seems to work......Thanx for finding that, the trick is to know how to word the question so you get the answer to the question you are asking.
    You helped, the guy with the fake car was of no help :p
    I noticed the recycle bin tool has been done away with in Windows?
    When you talk to computers who can’t get them upset, even when you get frustrated, or, you’ll pay for that. Are you sure that you didn’t say something about its mother (board)? :/
    edited March 2023
    It’s probably still there, just hidden away. MS likes to keep their customers confused.
    Are we talking Windows PC, Apple computer, iPad, iPhone, Android Smartphone, generic tablet, ????
  • explorerx4explorerx4 Member Posts: 21,037
    Just type in re and you should see it.
    Right click on an open area of the desktop, choose "Personalize", then choose "Desktop icon settings"
    Or, from a command prompt enter:
    %windir%\System32\rundll32.exe shell32.dll,Control_RunDLL desk.cpl,,0
    Make sure to check "Recycle Bin"
    We are talking HP laptop, bought Nov 2022, Windows 11.
    Abs fix seems to work.
    I sent an email titled "Test 1" to MrsD100 and it went to her SPAM, it probably didn't like the word "Test" in the subject line.
    I then sent her a youtube video of a Husband and Wife honesty on the golf course and it came in fine;
    https://www.youtube.com/watch?v=IicJmyzY4xk
    Had the car washed (always hand-washed) today. Ran my hand over the hood area and the rest of the car's paint surfaces and it felt like glass everywhere. That would mean that the ceramic coating is still working. I will let my ceramic coating guy assess whether it really need a renewal coat. I've been using this guy and his business for over 20 years now (for tinting and ceramic coating) and I trust him and his work.
    My brother and his friends are marshalls at the Players Championship up in Ponte Vedra where he lives. Traffic is unbearable according to him. I just got a call from him as he just got home from watching Spieth, Thomas and Homa complete their finishing holes. The course is in magnificent condition according to him. 59 of the top 60 golfers in the world are playing in the "Players Championship" at the Sawgrass TPC in Ponte Vedra. He's having the time of his life.
    I was following a KIA Telluride today and I noticed the car companies must be following my advice.....squarer lines and larger windows. I also like the way they put the KIA name on the tailgate.....it looks good painted on and the stylized word KIA works;
    The new Kia logo is seen as a stylized "KN" by many people. I don't think it really works very well, but people will eventually get used to it.
    Kia people love the new logo. I was talking to a guy that had a Telluride in the driveway. Commented on how nice it was, and he almost apologized that it was an older model with the old logo. :/
  • fintailfintail Member Posts: 58,774
    I've also heard of the new logo compared to the "NIN" logo - and that's probably not the demographic for these suburbanite cars :)
    edited March 2023
    The line on the “N” goes from bottom left to top right on the new KIA logo (so it’s not an N). I guess you see what you want to see sometimes…
    I guess maybe KIn??
    Seems like the best phone plans are for groups of four. We now have three so the deal we got from AT&T wasn't unlimited. And my wife & daughter don't want to go to MetroPC for some reason. I've seen their $25 plan for unlimited everything also but the girls won't budge. Hoping by the end of the year, I can get them to move to an unlimited plan with better rates. We still have a landline for the wife and a land line for her fax but since it's used exclusively for her business, she deducts a good part of it I think.
    Wonder what would happen if I did go over to Cricket and get their 4-line plan for $100 but only activate three numbers? Wonder if they'd squash the deal? And part of me thinks that in time, all company's will only have unlimited plans for everyone as it ould make the most sense when 5G service is universal.
    If you go Cricket just activate all four and leave the fourth one as a "house phone" and when ever you need to give someone a phone number give them that number and let calls go to voice mail and screen them there.
    Glad no injuries, certainly scary. What did you replace the CR-V with?
    You guys are going to laugh....Well, after two years, the 2020 CRV had 6000 miles on it. Our 2016 EXL CRV just turned over 20,000 miles. Because of this I decided that we don't need two new cars that barely get driven SO I started looking for something older, cheaper and smaller with the goal of being able to park both cars in our now smaller garage. I looked and looked and ended up buying an immaculate 2014 Ford Focus with 52,000 miles from a lady I volunteer with at our local Food Bank. Do I like it? No, not at all but for now, it serves the purpose. So much crap out there! Most of the Craigslist and Marketplace cars are being sold by curbstoners or flakes. Half of them (or more) have Salvage or Rebuilt titles! We just sold our big house after 34 years and downsized to a 3 bd 3 bath Townhouse in a Private Community losing about 800 square feet in the process so we had to get rid of a lot of "stuff" with more to go! I suspect I will tire of this Focus before too long!
    No, not laughing here just a lot of understanding the situation. Glad to see your back and glad you weren't hurt in the accident.
    I still have it in mine.
    Last night I had a client with a 1099-B that was over 250 pages. :o
    Took me two hours to work it up and enter the stuff into the system. :s
    Man I really hate those day traders.
    I really like the new KIA logo.....it looks a lot more modern than the old boring oval....like Ford. Since people are confused and think it is a KN car this idea of adding a single post in the A really helps;
    I don't care about the logo; I just wonder who would name a car company a name that's a military acronym for Killed In Action.
    Then there is this:
    https://youtube.com/clip/UgkxbKiGB42NHrpMxRvyTEnHTKnuhPZyVO6s
    Given their engine woes, maybe that was their intent. B)
