2023 Nissan Frontier Lease Deals and Prices Paid
178101213
  • kyfdxkyfdx Moderator Posts: 272,633
    Hello, could I get the (updated) RV, MF, incentives for April:
    2023 Frontier Pro-4X 18/10 45458
    .00376 MF and 93% residual
    one-pay is .00291 MF
  • kaylubbbkaylubbb Member Posts: 12
    Could I please get the updated RV and MF for all of the 2023 Nissan Frontier 4x4 trims at 18/10, 49067
    Am I allowed to ask for that many? Sorry, I just had a deal fall through because the updated 4x4 Pro4x crew cab RV went down and the MF went up. So I'm trying to sorta through all the 4x4 models and find a better RV/MF combo.
  • MichaellMichaell Moderator Posts: 269,020
    The S trim crew cab will always have the highest residual.
    .00358 MF and 93% RV
    Okay ty!
  • Hello-
    RV, MF and Incentives for 06320 on a Pro-X Frontier @ 18m/10k with One Pay Lease up front.
    Hello-
    .00376 MF and 91% RV
    .00291 MF for one-pay
  • Thank you!
  • bag73bag73 Member Posts: 8
    Hi, can I get the MF and RV for 11563 on the 2023 Frontier Pro 4x at 10k & 12k.
    What lease term?
    What lease term?
    18 months and 24 months
    bag73 said:
    What lease term?
    .00376 MF
    91% / 87% for 18/24 and 12K
    bag73 said:
    What lease term?
    .00376 MF
    Hey, sorry to question you. The MF works out to 9.02%, are you sure that is correct?
    bag73 said:
    bag73 said:
    What lease term?
    .00376 MF
    I am.
    The lease market is awful at the moment.
  • 95jersey95jersey Member Posts: 26
    Hello, looking for lease factor for NISSAN FRONTIER CREW CAB PRO-4X
    18 month / 12k and 15k miles
    What is your location?
    Hi. My leasehackr calculator is showing me that the current (04/05/2023, 6:11pm Eastern Time) RV/MF for a 2023 Frontier Pro4x 4x4 Crew Cab in 49067 are 93%/.00291. Are these accurate? Yesterday it showed me that the MF was .00376 and now it's showing .00291 for sure. I double and triple checked the trim and model.
    18/10
    .00291 is the single-pay money factor
    Hmmm, that's very unfortunate. My calculator is showing me .00291 pre-MSDs. then it's showing me .00201 after MSDs. It has the updated RV at 93% from the NMAC changes yesterday, and I saw it as .00376 yesterday. I'm assuming this is just a glitch? I'm new to this whole lease hacking scene though. When NMAC releases new numbers, is it just one change for the month then it stays the same until the next numbers drop? Or are there fluctuations throughout the month?
    Can't help you with the accuracy of the LH calculator; perhaps you can reach out to them and ask.
    Usually, just one change for the month, then stable until they expire.
    08009
    08009
    18/15
    .00376 MF and 90% RV
  • MIhonda1MIhonda1 Member Posts: 3
    Can you assure the numbers for Frontier PRO-4X Truck Crew Cab 4x4
    zip code 48108
    18/ 10
    18/12
    24/12
    thank you so much
    zip code 48108
    18/ 10
    18/12
    24/12
    thank you so much
    .00376 MF
    91%
    89%
    83% residual
  • nm365nm365 Member Posts: 3
    edited April 2023
    Hello, looking for MF and RV for 53202 on the 2023 Frontier Pro 4x at 18/10
    regular and one-pay
    regular and one-pay
    .00376 MF and 93% RV
    Thanks, also can you do 53202 RV for a sv crew cab 4x4? Still 95%? We just found one we like. Thanks
    MFs and residuals are nationwide
    Thanks, I wasn't sure on that as it seemed different zips were getting different RVs.
    I'm now looking at a Sv crew cab 4x4 in 53202, instead of the pro-4x.
    question...when 18/10 or 18/15 is requested, is the 10k or 15k per year? or per the entire 18 months?
    It's per year - for an 18 month term, the 10K allowance gives you 15,000 miles over the lease term.
    AH!! ok, then can i get a 18/10k quote for 08009, same pro-x top of line vehicle. thank you!
  • AjedmAjedm Member Posts: 11
    18/10 for 98007 (pro-4x)
    08009
    18/15
    Hello again! Can I get this same deal but with 12k miles please! I assume just the residual changes.
    08009
    18/15
    Correct - 91% residual for 12K
    08009
    18/15
    Interesting! Just so it helps others reading this, based on the 2% reduction in residual for 12k miles, it raises the payment $51 per month. If you actually do 12k miles a year and just pay the 15 cents per mile overage, it is $450 dollars at the end of the lease vs. $51 x 18 months = $918. Also, there is a 98% chance if you go back to the dealer to get a new lease, they will waive the $450 overage charge. So either way it makes total sense to stick with the 10k miles even if you know your going to do 12k miles.
    95jersey said:
    08009
    18/15
    Only Nissan has a 2% drop from 10K to 12K/yr. Your math is correct in this case, and of course it's more advantageous at shorter terms. Once you hit 36 months and/or any other make (with 1% drop), then it rarely works out.
  • arameth1arameth1 Member Posts: 23
    Looking for mf and resid for Nissan Frontier Crew Cab 4x2 for 18/10, 30040. Unless there is a more attractive (cheaper) combo than S crew? :)
    .00358 MF and 93% residual
    $500 incentive for 4WD only
  • Mtzl33Mtzl33 Member Posts: 13
    Hey!
    Looking for MF, RV and any lease incentives for:
    Midnight 4x2 crew
    Midnight 4x4 crew
    SV 4x4 crew
    SV 4x2 crew
    S 4x4 crew
    S 4x2 crew
    Zip: 68130
    Sorry for all the options - Thank you in advance!
    Mtzl33 said:
    Hey!
    Midnight 4x2 crew
    Midnight 4x4 crew
    SV 4x4 crew
    SV 4x2 crew
    S 4x4 crew
    S 4x2 crew
    Zip: 68130
    I don't see a Midnight trim - is that a package added to another trim?
    edited April 2023
    It might be - not sure. I just saw on their website listed as a separate trim option. If you can’t find it, don’t worry about that one.
    Mtzl33 said:
    Hey!
    Midnight 4x2 crew
    Midnight 4x4 crew
    SV 4x4 crew
    SV 4x2 crew
    S 4x4 crew
    S 4x2 crew
    Zip: 68130
    My data only shows S and SV; I'll guess Midnight is a trim package available on one or both of those.
    .00358 MF
    78%
    75%
    82%
    79%
    Looking for MF & RV
    S 4x4 crew 18/10
    68130
    Mtzl33 said:
    Looking for MF & RV
    S 4x4 crew 18/10
    68130
  • ottoman1384ottoman1384 Member Posts: 18
    edited April 2023
    MF & RV for a 2022 and 2023 Nissan Frontier Pro-X Crew Cab 2WD
    18/10 and 24/10
    77079
    Any incentives?
    I asked last month but need updated numbers. Thank you!
    18/10 and 24/10
    77079
    Any incentives?
    2023
    .00376 MF
    $500 incentive
    91%/85% residual
    No lease support for the 2022 model
  • TimDeRadaTimDeRada Member Posts: 5
    Can I please have MF, RV and Incentives if any for a 2023 Pro 4x, 18/12, 24/12 for zip: 32548
