Mystery car pix
1137513761378138013811477
    You guys have sgarp eyes but the blue roadster could be either a Sprite or a TR3 IMHO. At TOM they say Sprite but sure it could be a Triumph.
  • texasestexases Member Posts: 11,177
    I think you can see a bit of the Bugeye grill surround.
  • ab348ab348 Member Posts: 20,601
    The TR3 also has a bit of a bugeye vibe to the front end/headlights, though they are better integrated on the Triumph. I don’t know how you can tell for certain from the little we see in that picture but TR3 was my first reaction. Definitely old Las Vegas.
  • explorerx4explorerx4 Member Posts: 21,030
    My original thought was a Bugeye but now I'm on the TR3 bandwagon.
    The grille seems too wide for a Bugeye.
  • fintailfintail Member Posts: 58,763
    Aurora Village Mall, Seattle, 1990 - malaise fest. This mall was ahead of its time, closing in 1992 and demolished in 1994 (zooms well enough):
    Jeep Comanche with a cap front left.
    A Fox Body Mustang, Fox Body LTD, Isuzu P'UP.
  • MichaellMichaell Moderator Posts: 267,493
    Taurus wagon and an F-150.
    Car beside the Jeep is a 78-79 Audi 5000 missing a headlight bezel, and the white car continues on a theme, appearing to be a VW Fox wagon.
  • stickguystickguy Member Posts: 54,071
    S10 Blazer far right.
  • xwesxxwesx Member Posts: 17,923
    edited May 2023
    The Ford Pickup is the early 70s iteration. It's too far away for me to see enough detail to pinpoint a year, so I'll just guess a 72 or 73. I liked the light modifications they made to the front end of the 76/77, before they went to the rectangular headlights in 78.
  • sdasda Member Posts: 7,708
    Chevy Monza coupe far right of the maroon F-150. I came close to buying a 78 medium metallic blue Audi 5000 in 82 for $2600. I really liked it but it had needed front struts and some other work. CR showed it had a horrible repair record so I passed on it and later bought my 80 Mazda 626 coupe.
    You made a wise choice. Aside from the Mazda being a relatively pretty and reliable car, those early 5000s were apparently something to avoid - even in the online newspaper archives I read now and then, depreciation was catastrophic, and that was a time when MBs and BMWs depreciate quite slowly. Kind of a shame, I don't mind the look of those cars, especially the 80+ facelift to rectangular headlights.
    Aberdeen WA, May 29 1972 (should zoom well):
    Coming in 2nd to the 63 Impala is a 70 Mustang.
    behind the Mustang is a very beat up 60s Dodge PU camper. much nicer Chevy behind that one.
    back a ways in that row is a Vega. next row over a tiny white car between a Chevy and Caddy, probably a 2 door Corolla.
    edited May 2023
    A couple of oddballs spotted while walking the grand-dogs.
    How about this one? Hit a huge pothole on the highway.
    edited May 2023
    Car behind the VW Thing the short lived Taurus X, from Ford's weird short flash of time?
    Sad about the Lincoln LS ,looks to have been clean beforehand. Rarely see those anymore.
    Hat Trick for Fintail!
    the X was the Freestyle before the name change. Unless it was after. I forget which order it came in!
    I think you are right. At least per my anecdotal memory, the oddly badged Taurus version is less common.
    Correct; originally Freestyle and Ford Five Hundred. Then the Five Hundred became Taurus and Freestyle became Taurus X. LOL
    That's because they barely sold any.
    I can't find a 1960 Ford anywhere in the pic.
    I do see a 1960 El Camino parked below the SPAR sign.
    edited May 2023
    Those '60 Fords seemed to have a short shelf life, I doubt many survived to 1972.
    Vega in back.
    Two vehicles back of the El Camino is a '68 Cutlass.
    Oooh, that '69 or '70 Suburban is the pick of the crop!
    Not a '69 - that has a '70 to '72 grille.
    edited May 2023
    Seattle 1996 - longer ago than it seems (should zoom nicely):
    early Legacy center. I had the wagon version of this vintage. Right, the rump of a Mazda 323 2 door. Red 4 door dodge colt in the center of the lot. and a nice steel blue 2 door Integra under the giant sign.
  • tjc78tjc78 Member Posts: 17,361
    edited May 2023
    In the middle: First gen Taurus, Cavalier, Bronco II and a short wheelbase 91-95 Caravan or Voyager
    VW Rabbit leaving the lot on the left. White Chevy Cavalier closest car under the work Giant.
    Red Subaru wagon behind the Integra?
    The image is not high enough resolution, and the angle/light isn't good enough, for me to distinguish the subtle differences between 69 and 70, but it is definitely the 69/70 grille pattern having that strong stripe across the middle. 71/72 has the crate pattern with no stripe and the bowtie in the middle.
    On second look, though, this one has the bowtie in the middle of the stripe, which, by the look of the openings to top and bottom of the stripe, means it is probably a 1968. The 67-68 had a far lower angle on the crease at the front of the hood, but this angle just doesn't allow us to see that very well one way or another. From what we can see, this one is most likely a '68 unless it just happened to be a custom job!
    I was in error by thinking the ‘70 had what you call the crate pattern - that didn’t appear until ‘71. The pic blows up well enough on my iPad to see that it is a ‘71 or ‘72 grille. When you blow it up I don’t see any stripe across the grille at all, though the bow tie is clearly visible.
    Aberdeen WA, October 1960 - zooms fine:
    2 tone '60 Ford 4 door far left.
    58 Chevy up against the A&W.
  • tmarttmart Member Posts: 2,420
    52 Ford front and center, 59 Ford wagon, probably a Ranch Wagon, under the Coke sign.
  • kyfdxkyfdx Moderator Posts: 270,831
    MMMMMM.... A&W
  • Lostwrench3Lostwrench3 Member Posts: 837
    MMMMMM.... A&W
    My hangout during high school days.
    Yep the 59 Ford wagon appears to be a two door model.
    What's the mystery car parked nearest the building? Hint: it's newer than it looks
    I remember going to an A&W in the early 1980s, though I don't remember where it was. I just recall that the root beer float was so tasty! I didn't go to another until a good twenty years later, and by then it was just another fast food restaurant. Such a disappointment.
    Our regular A&W was in Lucasville, OH. early '70s
    A proper root beer or coca cola float, yum. I can't remember that last time I had one.
    Red Robin had a good "bottomless" root beer float a while back. I always made sure to get my money's worth :)
    The mystery car at the drive-in is an Austin A40, which sold in some numbers stateside around 1950.
    Aberdeen WA, same date in 1972 facing the other direction, should zoom ok:
    nice Chevy II convert at the bottom.
    Mustang and 61Ford Country Squire
    edited May 2023
    I don't think the 'vert beyond the mobile home is a Mustang. Looks like a 60s era Malibu .
    White Chevy parked on right is a'65-66 Impala
