Visitor Agreement.
@stickguy
All the trim will have to be removed. They will remove the current jambs and replace with the pre-hung doors, then reinstall the trim. Easiest way.
Biggest issue you will have is the size of the opening. I believe most standard French doors are 5’ or 6’ wide (2, 30” doors or 2 36”)
Probably need about a 62” or 74” opening for something off the shelf
If you current opening measures a little less, remember you’ll pick up 1.5” when those jambs are removed.
We did this in our house and it ended up way more expensive than I’d planned because it was a nonstandard opening. I’ll try to find some photos. That said it was well well worth it.
Then, I'll think about french doors for the dining room (converted to an office).
I confirmed the measurements should work. This house is only 3 YO and I am pretty sure they designed that opening to accommodate French doors as an option, otherwise they just cased the opening. that HD door was listed as 81.75 x 61.5. The finished opening with casing as is, measures 60x81. So should be just about perfect fit.
It’s good that you checked the rough opening dimensions. My experience is that all of the manufacturers recommend rough openings that are much more (by at least 3/4 of an inch) than what is necessary. I can only assume they are over compensating for framing that is ridiculously out of plumb and square.
First off I would check the side jam casings to see if they are plumb. They are probably pretty good but I’m sure they used shims to do this. Just like you’ll need for installing the door. I would use a 6 ft. level to do this but being very careful you could use a 2 foot level (placed at the top then at the bottom) to check for plumb).
Given what you find I’m pretty sure you’ll only have to remove 1 side casing. And you DO NOT (I repeat DO NOT) remove the doors. Of course this makes the assembly VERY heavy. There is a plastic plug installed where the doors meet each other at the latch point and this is what keeps the unit from racking. That’s why you DON’T take the doors off.
I suggest you watch a few videos of how to install prehung doors especially double hung French doors.
If you plan on having Mrs. @stickguy help you, get her on a Wheaties regimen right now.
That reminds me of when we had a guy install windows on our first flip house. I complemented him on the installation. He thanked me and said, “maybe I shouldn’t say this but in the contracting biz our saying is…do your best and caulk the rest”.
I’ve seen a few flip houses where that kind of workmanship is practiced to the max.
You can take out the inside trim and one side of face trim then slide it in up against the other face in theory. I think that is what he means.
Mrs sticks only involvement will be getting the checkbook to pay the pros that install it. I will supervise.
We had our massive front door replaced (door and 2 sidelights) and it was impressive how fast they had the old one out.
I bought a sliding door and made the opening with a chainsaw to install it.
Your “theory” makes you sound like a typical flipper. Both side casings have to be removed because shims MUST be installed from BOTH sides so they form parallel surfaces to each other (one side at the side jam rough opening and the other against the outside of the pre-hung door jam) and not tapered which would result when installing a single shim from one side.
As for demo work, that’s always faster than a good install.
The other night I was on the side of the house and I noticed water coming out of the outside vent. I get the plumber in and he recommends a power flush of the kitchen drains. He also says the water level in the septic tank is too high. He routed out an internal baffle pipe and the water level dropped to normal. The kitchen drain still didn’t flow though.
On a hunch while waiting for the tank pumper I dug out my old fashion snake and ran it through the inlet pipe from the house and now it seems to be draining properly. I’ll test the drain and dishwasher over the next few days and see if it’s fixed.
Meanwhile the crew is finishing up on the bathroom and should be done in one day.
I realize I’m getting too old for this drama. Maybe I’ll start living in a tent. 😜
Done!
Geeze, I couldn’t open up a box of screws that fast.
Good luck and enjoy it.
the edger took longer because that is a plug in electric and the 100' electric cord was tangled, so I had to unravel that. but once plugged in, worked like always!
the gas mower worked today but it still does not work perfectly. probably should have pulled the tank off and tried to flush that out too... but I didn't.
just going to get a can of cleaner to spray in and see how long it will run, then either park it or tear it apart again! I saved the old carb and some day will take it apart to clean it. Will just keep swapping them back and forth.
And if the old story about one being born every minute is true, your guess as to how long this will last is as good as any of your poster buddies in here.
The dealers are NUTS. I can show you endless examples of them having reserve or asking prices AT AUCTION for many many thousands above what even the auction house says it is worth RETAIL.
Most atrocious one I spotted yet: dealer in NJ has a Top Banana 2007 Charger Daytona. Very low miles, but they want $35k!!! I am tempted to run my Daytona over there and offer it for the “insanely low price” of $20k cash.
I follow flying wheels on Youtube (sometimes hard to watch but has good info) and he was giving real results about prices at the auctions he goes to, when bids started falling and dealers were still holding to big reserves and no sales shot up. and the same units kept coming back week after week.
So I got a good one for you all…
We have a trade show exhibit that we are doing in Las Vegas next week. My guys will set and take down the booth and I’ll work the show floor with a bunch of others. When we met about the show, I said I’d grab a car since I’ll be in first and leaving last. We have 10 of us, so I grabbed a minivan thinking that if some one got a normal car we would be set. The minivan was a great price versus a large SUV (half price)
Get a Teams message the other day from the boss….
“are you really renting a mini van for Vegas?… you need to change that to an SUV please”
So I looked and it was only 200 more for 8 days and it isn’t my money, but wow those vans really do have a stigma. Booked a Tahoe or equivalent.
Can’t make this stuff up.
Actually they finished 3 hours ahead of schedule.
That’s absurd. Also is his time really best served ensuring you rented a car?
Got cheap yesterday and removed a rock wall myself instead of paying the landscaper. 6 carts later of rocks to the back yard pile I was regretting it. It got it done.
They came today to put in a new concrete edge row in front of the beds around the porch. Looks way better and unlike the loose stack rocks grass won’t grow between them. New mulch too. Looks much better.
I don't know why dealers are being stubborn. It is like they keep asking for a card when their hand already busted 21. You just gotta take the loss now cause it ain't gonna get better.
Looks like a Genny with a puny badge.
Totally out of character for him too. I just had to laugh….
2013 LX 570 2016 LS 460
the prior owners really liked collecting rocks. Including some pretty big ones. Lots of construction going on so there is an unlimited supply or rocks/stones/small boulders of every size to collect. If I never figure out a use for them, eventually the woods will reclaim them.
My next door neighbor said he had 3 discovered on his lot when building the house.
One of them got stolen!
BTW, instant backyard today.
also got our front landscape beds spruced up. Had a landscaper but in some nice concrete running blocks to replace the rocks I pulled out yesterday. Came out even better than we hoped. vast improvement, and at least I did not have to do all that digging!
