2024 BMW X5 Lease Deals, Incentives, Rebates, and Prices
1235721
  • Fast2upFast2up Member Posts: 1
    Need the RV and money factor for 2024 X5 50e 36/30. loyalty bonus applies. ZIP 95973
    Mark
  • kyfdxkyfdx Moderator Posts: 273,454
    Mark
    .00210 MF and 52% residual
    $1000 loyalty
  • rgm3333rgm3333 Member Posts: 12
    Hi - Looking for the residual and MF on a 2024 X5 40i please.
    Considering 36 months/12k miles but flexible to do whatever combination will provide the best result. Seeing 39/10k in the threads, is that the sweet combo?
    Zip is 75024.
    I qualify for loyalty, Tier 1 credit.
    Zip is 75024.
    .00190 MF and 51% residual
    $1000 loyalty
  • PinkFloydFan78PinkFloydFan78 Member Posts: 45
    X5, 40ix, 12/36, 92808
    MF, RV and incentives? thanks
  • MichaellMichaell Moderator Posts: 269,540
    .00210 MF and 51% RV
  • BMWGuyFromTheEastBMWGuyFromTheEast Member Posts: 2
    Hi there ... looking for the mf and res on the X5 M60i for zip 21043. 10/30 and 12/36 Thanks so much!
    .00210 MF and 51% residual
  • RShah14RShah14 Member Posts: 11
    Can I get the MF and residual?
    X5 M60i
    60143
    36 months/ 10k miles
    Quality for loyalty
    Is there a special 39/10 too on m60i?
    X5 M60i
    60143
    Quality for loyalty
    $1000 loyalty
  • dawilson56dawilson56 Member Posts: 44
    Hello. A few things:
    MF and residual for X5 50e - with loyalty and tier I credit.
    Also, do I see a MF difference between X5 50e and X5 4.0i. I'm seeing 50e at .0021 and 4.0 at .00190
    Does the X5 50e qualify for 39 month lease with 36 residual factor?
    Only the 40i qualifies for the special 39 month loyalty program, which is why the MF is different for the two models.
    How many miles per year?
  • roadrunner50roadrunner50 Member Posts: 3
    MF/ RV 2024 BMWX5 x401 AWD 36/7500
    .00210 MF and 53% residual
    sorry 15/36 for BMW x50e
    zip code 34202
    Also - did you see my question about the difference in rates between 4.0 and 50e?
    thank you
    X5 x401AWD 36/7500
    I qualify for loyalty. MF/ RV?
    Zip 14001
    zip code 34202
    thank you
    .00210 MF and 49% residual
    Did you see my response to your question? Look up a few posts.
    X5 x401AWD 36/7500
    Zip 14001
    .00190 MF and 53% RV
    $1000 loyalty
  • gadgetfreakgadgetfreak Member Posts: 4
    Hi. Looking at 50e in zip 12572.
    Nothing down (other than required amount)
    36 months. Loyalty double. Excellent credit.
    What are the current MF and residual? Thanks!
    Sorry. 12000 per year.
    $1000 loyalty
    Thank you. Do you happen to know what it was in April under the same circumstances?
    Nope, but you can scroll back through the discussion, and check. I know the residual hasn't changed, but the money factor may be slightly different.
  • surgforce1surgforce1 Member Posts: 18
    Hi guys, I am looking for MF, RV, any incentives for 2024 X5 40i 36/7.5 in 19072. Current BMW lease maturity coming up soon.
    39/7.5
    .00190 MF and 53% residual
    $1000 loyalty
  • Serafim521Serafim521 Member Posts: 1
    Hi guys, I am looking for MF, RV, any incentives for 2024 X5 M60i for 36/12k in zip code 91324. Thanks!
  • ACremona22ACremona22 Member Posts: 29
    Looking for MF RV and incentives for 2024 X5 xdrive40i.
    36/10,000
    Zip 60540
    36/10,000
    Zip 60540
  • itsrkitsrk Member Posts: 1
    Hi - Need RV and money factor for a 2024 X5 50e 30. ZIP 98052. Also if there are any lease incentives.
    RK
    RK
    .00210 MF and 49% RV
  • holaandersonholaanderson Member Posts: 7
    May I get the residual and money factor for a 2024 X5 xDrive 40i for 36/10k miles in 55391? Any incentives?
    Also, are the MF and incentives different for a 39 month lease?
    39 month term is only available to loyalty customers
  • WscanlonWscanlon Member Posts: 8
    May I get the residual and money factor for a 2024 X5 xDrive 40i for 36/10k miles and 36/12k in 06840? Any incentives?
  • sam04253sam04253 Member Posts: 41
    May I get the residual and money factor for a 2024 BMW X5 M60i for 36/12k miles in 10304?
    Any incentives?
    Any incentives?
  • hbarron3hbarron3 Member Posts: 39
    May I get the residual and money factor for a 2024 BMW X5 xdrive 40i for 36/10k miles in 79414?
    Any incentives?
    Any incentives?
  • LDTX5LDTX5 Member Posts: 1
    edited June 2023
    Pls share MF and residual for 2023 X5 M50i. Looking at 36/10 lease
  • RadmjkRadmjk Member Posts: 2
    edited June 2023
    Can you please share June MF and residual for 2024 X5 M60i for 36/12 in 48306?
    2023 X5 discussion
  • pawtatopawtato Member Posts: 2
    May I get the residual value and money factor for a 2024 BMW X5 50e for 36/15k miles in 91762?
    Any incentives for military? Not a loyalty member.
    $500 military
    $500 military
    Thank you. Is it the same rate for zip 94080?
    $500 military
    Nationwide
    Hi there, could you let me know the residual and base MF for the below:
    2024 X5M60i
    36 months
    12k miles
    Zip - 08876
    Also, the date the rates and residual are good through.
    2024 X5M60i
    36 months
    12k miles
    Zip - 08876
    Through July 4th
