Visitor Agreement.
I would say it's similar, so not good.
I was looking around at used Outbacks too, and spotted a 3.6R at Carmax. Their Autocheck history doesn’t show service records, but I found a workaround to look at carfax and BOOM! Head gasket, on a 2019 with 43k.
I'm assuming that was done under warranty?
Someone in my neighborhood has a newer hybrid with a long mcarthur sticker on it. So up here in the NY boonies we have hybrids from LM and Chapman.
Banks open 7/17. Will close shortly after. 2024 changes minimal but they are eliminating base lariat. Only comes fully loaded now.
I’m Glad to not be ordering again!
Last week, the local Dirtfish rally school held a one day event at their location called Summerfest. They open up their facility, host vendors and food trucks and have a party complete with available rally car rides.
I wasn’t aware of this event but I received a reach out from Griots asking if I’d like to join them and bring my car out to their display, along with a E30 M3, a 964 Carrera RS, a 488 Pista and an Aventador. Who turns that down? Lots of cool cars to check out. Starting with an actual Lancia 037-
Give them a little more time to recondition those vehicles. Then they’ll end up at a lot near you. From what I’ve been told and heard, not many vehicles are thrown away anymore. They just need time to get the parts (usually the electronics) so they can put them on the lots.
Not good. Buyer beware!
So what’s new? That’s always going to be good advice.
A little follow up on this:
Two body shop guys I know told me the old school way of checking for a flood car by opening the trunk and looking for signs of water isn’t good enough. They put a car on the rack and look for silt in the frame holes. Then they remove the door sills and look for signs of water there. When that looks good they move onto the trunk for another check and of course make sure all the accessories work.
Not a Comp, not the perfect one.
Maybe not perfect, but lighter than yours, even with the moonroof
No way to break in a new vehicle before vacation at the end of the month, so I'll look more closely next month.
1. The turbo block is a more robust unit with better internal buttressing of the cylinder walls and the outer block. However, the design prevents them from reusing the molds, so they are sand cast (e.g., one engine per mold). The NA Block does not have this buttressing on the cylinders, so that tends to lead to more vibration at the interface with the heads, which, over time, breaks down the seal with the head gasket (HG).
2. The turbo block also has a three-part HG design that moves with the block and head components better as the engine undergoes temperature and pressure shifts. The NA block can use the same HGs, but, for whatever reason, they use a one-part HG for those from the factory. They did update this gasket so that the unit would be more likely to last beyond the warranty period (LOL), but they still tend to fail within 120,000 miles of new. The newer gasket design is far more likely to develop external oil leaks than internal coolant leaks, which is the opposite of the older design.
Ultimately, it's the lack of cylinder wall support that leads to the failure. The FB generation of engines eliminates this issue by running the coolant channel that goes between the block and the head through external plumbing rather than through a direct, internal connection. This allows for more support of the cylinder walls along with taking the mixing of coolant out of the equation. They can still develop oil leaks, but that has always been the more minor concern with any car's head gasket.
(these cars still had dipsticks, which are somewhat hard to see on the passenger side, low, and near the firewall). If you buy, change out all of those and the differentials. No mention of head gasket, so check the overflow bottle to look for any black bits floating in the coolant or stuck to the sides of the bottle. Also check under the car along the head/block seam (there are two of them prominently across the bottom!) for either blue-green staining or oil seepage/drip/stain.
Tires look old, like on my son's car, but he got another 10,000 miles out of his (trip home last fall and all this summer), so probably not an immediate need unless he's going to run the same set throughout the year.
I saw a base Maverick yesterday driving next to me on the way home. As I was the passenger, I was able to look it over closely. Seems like a pretty solid consideration for a small footprint with high utility.
I hope all is well there.
Anyway, we ended up with a '17 Forester which we've taken to AK, TX and many visits to CO & CA, such that it's pushing 93K miles. it's been totally trouble-free -- oil changes, wiper blades, that sort of thing. I tend to keep vehicles forever, especially if they've been good to me, so here's the question: Do I need to concern myself with this head gasket thing, or the rubber band transmission, or anything else?
My '08 TSX is coming up on 200K miles, and I have no intention of replacing it.
What say you?
If I'm keeping up with his family's posts correctly, they're in southern Oregon currently with no vehicular issues!
For the Forester, I think they are fairly trouble-free in those years. Outside of what a dealer will generally do, I'd suggest that, given the mileage, it's ready for new gear oil in the differentials and new fluid in the CVT if neither has been done yet. I know that, in the US anyway, dealers claim "lifetime" fluid in the CVT, but there's truly no such thing.
The manual for my friend's NV3500 claimed the same thing, yet I'm pretty sure that he'd be stranded by now on that trip if he would have tried hauling that heavy travel trailer so far on that old, brown fluid.
Hopefully a project for this weekend or next, since my wife informed me last night that she's planning to take it on our trip to Ohio this year. I thought she was set on taking the Crosstrek again, but it appears she's come to the realization that it is just too small for what we need to take with us. I'm sure we could make it work, but I don't mind not fussing with the space limit, either!
If yours has hydraulic power steering, @cdnpinhead , it might be worthwhile inspecting that and/or changing it if it's never been done before.
I'm a bit spoiled regarding where to have maintenance done on the Forester, since I've found an independent Honda service place (HonMan) that has been excellent servicing the TSX and my daughter's Civic. I've "progressed" to the point that even an oil change isn't something I'm interested in doing any more, especially in the summer. Anyway, I haven't found a Subaru independent yet, but I'll get more serious about looking.
As far as the Phoenix weather goes, I spend most of my time in our cabin in Forest Lakes which is at an elevation of ~7500 feet, which is good for 25-30 degrees of reduced temperature, relative to the "Valley of the Sun," otherwise known by me as the hellhole.
That said, the present string of 12 or 13 days at 110 or above still has a ways to go to reach the record of 18 - - that's 18 in a row, not 18 total, set a number of years ago. I won't trouble you with the day it got to 122 at PHX (the airport) when they had to ground flights outbound because the Boeing tables only went to 120. Boeing did the extrapolations over night, so by the next day tables were available to 125, which was a good thing, since it got over 120 again. This was 33 yeas ago. Everyone needs to calm down.
Fat chance.
From your description it sounds like you do a lot of highway driving which they say is very easy on a car. If you change the fluids regularly and can put up with the nickel and dime repairs you should do ok.
My nephew’s first car was a Subaru with 175k miles. For all I know he’s still driving it.
The Acura is a Honda and they run forever no matter what. I hear you don’t even need to put gas in them.😎
Decent leases yet?
Decent leases yet?
Haven’t seen the $7500 show up as an incentive from Ford. I’d think that would be next.
Of course the comments are the best! One guy stated that prior to watching the video and completing the installation of the new head gaskets (and other parts I hope) that the only automotive related repair he's ever done was jumpstart a car.
How did they know you had it?
That’s a very TALL story. However, one thing I do know, that wasn’t our poster buddy @driver100.
He'd need a 2 hour YouTube tutorial on how to assemble a socket wrench- and an equally long video on torque wrenches.
I have to accept it all because I bought the car used, and even though the Carfax said "no prior accidents" one of the fenders is giving me doubts upon very scrutinized close inspection. If I bought it new I'd be 100% certain enough Ingolstadt would never let a car like this leave the factory. Good enough for US car assembly standards I guess, and the reason DV is both real and inherent; especially in higher quality German vehicles.
At least the paint work is good! Shiny, very red, and well color sanded/polished. The owner told me he does 99.9% of the paint work in his shop, even at 72 years old. He said the only one who paints besides him is his son (Jr.) and that's only when he's on vacation.
I'm guessing he rarely takes vacations. How much longer can he keep it up though? At some point his eyes are gonna go
Man, I love the S4 after having driven the TTS daily for over 3 weeks. Keep in mind the TTS is on 200 treadwear track like tires, so it's harder riding, louder, and just a generally stiffer ride than the S4, which is sublimely quiet on All-Season Pilot Sport 4's.
