Subaru Crew - Modifications II
in Subaru
your discussions from Subaru Crew - Modifications
(Topic #16) here!
Bonnie Rick
Conferences Manager, Edmunds.com Town Hall
(Topic #16) here!
Bonnie Rick
gus
..Mike
..Mike
-mike
XT coupe
XT 4wd coupe
XT6 4wd
XT6 4wd turbo
The XT6 4wd is 2795lbs, the XT6 4wd Turbo is 2865lbs.
Now in '88 there were:
XT Fwd
XT Turbo (1.8l turbo) Fwd
XT Turbo 4wd
XT6 Fwd
XT6 4wd
The XT6 never came in a turbo model.
I shall research some more and find out my results.
-mike
XT6 4wd Turbo? Best kept secret?
-juice
-mike
Bummer.
-juice
-mike
Lucien - I think the rear bar on my GT is either 15 or 16mm. Is the OB 19mm?
bit
-juice
PS You ought to play with the settings in a snowy parking lot, to see at what point oversteer appears
You can post names (and websites if you have 'em), or email to me directly at gedwards@subaru.ca.
Greg
Cobb Tuning just started carrying the Whiteline adjustable rear sway bar for 00+ Legacys:
http://www.cobbtuning.com/main.html
bit
I notive you're from Subu of Canada. Mississauga branch?
Anyways companies that makes 'em : FHI, JC Sport, MRT, Cusco, is whiteline adjustables from MRT? anyhow those are the ones I know...
errr.... I've been doing my routine oil change at a Subaru dealership sir yes sir!!!
http://home.earthlink.net/~gndiamant/subaru.htm
Look under parts & service, then americas. There are dozens of vendors.
SPT sells sway bars for the Impreza/Forester, but I'm not sure about the GT.
-juice
Sway bar suppliers:
www.spdusa.com
www.cobbtuning.com
www.rallispec.com
to name a few.
Dave
However, there are several folks on the iclub that have gotten check engine lights related to the first oxygen sensor after installing the new Borla header.
I can't recall anyone getting this with the original design, and honestly I haven't followed the threads too closely because I'm not going to buy one.
-Colin
Dave
bit
Dave-- that's exactly the problem, not enough gain for the buck FOR ME. I presume you've seen the pictures of the new Borla header, and have seen the factory setup up close and evaluated them. I could probably find pictures of both if necessary, but for now I'm just going to describe the problem.
Neither the original nor the new Borla header has equal length tubes. This is important because it keeps exhaust pulses evenly spaced, allowing better flow and low turbulence. (That's an overly simple explanation but oh well.)
The header is designed to mate to the stock catalysts, which means it terminates facing directly towards the right side of the car, and then the catalysts are curved to not-so-gently bend towards the rear of the car.
To me this is an unacceptable performance loss, and if I'm going to bother to replace the stock header, I'm going to get one that does it right even if I have to replace my defective stock catalysts. (Federal law says you can't replace a working one, therefore mine are failing.) MRT in Australia sells an equal length header that also utilizes a single straight high-flow catalyst, and thanks to the strong US dollar / weak AUD, I can get it cheap.
I wouldn't dare attempt this in California, it would surely fail a competent visual inspection. It's perfectly fine in Kansas though.
Anyway, the fact is that the Borla header does offer an improvement over the stock header and it probably does the best it can while connecting to the stock catalysts. If those things are important to you, which they would be for most normal people, then I'd say the Borla header is a good product.
-Colin
MANUFACTURERS and RETAILERS
JAPAN
http://jprova.co.jp/index.html
One word: Sweet.
http://www.syms.co.jp
SYMS parts--site needs updating
http://www.zerosports.co.jp
Excellent Japanese Subaru parts
http://www.rd-tanabe.com
Tanabe exhausts homepage--great Outback wagon exhausts here!
U.S. distributor listed below
http://www.poweraxel.com/sti/catalogue/legacy/index.html
Japanese-parts importer
http://www.subaru-sti.co.jp/contents.html
STi homepage
http://www.axa-int.com/link.html
Importer of Japanese performance parts. Get your Japan-spec parts here
U.S.A.
http://www.qsubaru.homepage.com/
DARLENE! DARLENE! DARLENE! Best prices and customer service!
http://www.writerguy.com/primitive
Oregon-based fabricator of high quality parts,
mostly for Impreza/WRX/RS, some Legacy/Forester
http://www.spdusa.com
Good 2.5RS/WRX parts source
http://www.spomotorsports.com
SYMS reseller and aftermarket
Texas-based with nice tech pages and good products--upcoming cold air intake TBA
http://www.challengerdeep.com
Japan Subaru parts reseller and aftermarket
http://www.mackinindustries.com
U.S. distributor of Tanabe
http://www.quicklink.net/bham/paeco/home.html
Paeco makes flywheels, camshafts, pulleys for Subaru and other makes
http://www.subaruparts.com
Discount Subaru parts from Tacoma, WA
http://home.cdsnet.net/~zastava/products.html
Oregon-based performance Subaru fabricator
http://www.stromung.com
Very nice mufflers w/chrome tips designed for Impreza and OB
http://www.flatlinemotorsports.com
Subaru performance in Irvine, CA
http://www.eliteone.com/
Various performance parts, tires, etc
http://home.att.net/~teaguesauto/
STI, Cusco and genuine Subaru parts and gear, updated regularly
http://autocaresubaru.com/
Scorpion lift kits(!) for Forester, STI, Cusco, more
http://www.bpmsports.com
Subaru performance
http://www.rallispec.com
Loads of cool Subaru performance parts
http://www.junusa.com/products.htm#SUBARU
Impreza parts
http://www.subysports.com/
Recent newcomer to Subaru performance, has SYMS
http://www.jcsports.net/
strut bars, nice exhausts, decent prices
OTHERS
http://www.minnamracing.com
Canadian shop--turbo specialists and other perf. parts
Still in business?
http://www.whiteline.com.au
Performance suspension products for Subaru
http://www.mrtrally.com.au/
Aussie-based, rally oriented, good parts
http://www.japaneseparts.com
Japan-only parts? Find them here
U.K. based Subaru shops
http://www.powerengineering.co.uk/index.htm
U.K.-based tuning and products for WRX Impreza
http://www.blitz-uk.co.uk/subaru.htm
Blitz product specialists
http://www.grahamgoode.com/
Subaru performance for Impreza
http://www.tdi-plc.com/Subaru_home.html
Subaru products for Legacy, Impreza
http://www.sleeze.co.uk/subaru.htm
Another UK-based shop-WRX and Impreza
LINKS and OWNERS PAGES
http://www.impreza-rs.com/
Hell of an Impreza site
http://www.imprezawrx.org/
More Impreza fanatics
http://www.cars101.com/subaru_links.html
Many many links--SVX, XT, all Subaru models!
http://www.new-impreza.com/
Impreza madness
http://dspace.dial.pipex.com/m.hunt/subaru/subaru_main.htm
U.K. owners page
http://www.ifeng.demon.co.uk/scooby/index.html
Read this for excellent Impreza/WRX info from a U.K. owner
http://www.toad.net/~rrubel/outback.html
Outback page by an owner
http://members.aol.com/Emily23PG/index.html
Murasame's page on the 2.5RS
http://importcars.net/subaru/
An owners Impreza RS site, with a great section
of pics showing how to install parts
http://www.trunkmonkey.com
Interesting
Cheers,
-wdb
Check out : http://home.earthlink.net/~gndiamant/subaru.htm
I thinkit has EVERYTHING Subaru related pretty much. It's my Subaru directory really.
Dave's Links:
http://bitman.com/sooblinks/
bit
Anyhow, the front one goes on pretty easily, using a couple of clips and some bolt-on clips that come out from under the hood. No drilling required. The rear dust deflector is a different story. It requires drilling, and also requires being able to shove some inserts into the rear hatch with a special tool. You're also supposed to slather the holes with rust inhibiter. I'm going to let a dealership do the install, I'm not up to the hassle.
Question: How much should a dealer charge me to install this thing? Has anybody else had one installed on their Subaru Forester? How much did the dealer charge? I know the install would take me several hours, but most of that would be because I've never done it before and would spend half my time rummaging through the toolbox trying to find the right sized drill bits etc. as well as running out to the local AutoShack for some rust inhibiter. I'd suppose that somebody who's done it before could probably do the install in less than an hour...
-E
-Colin
Headers would be a pain to install. You're talking about working in a tight spot with likely rusty components that are rigid and may be hard to line up. All that work and $400 or more for 3 or so horses?
I'd try the pulley first. Then a cat-back and/or intake. Just seems more cost effective.
-juice
http://subarucrew.homepage.com/juice4/page4.htm
-juice
-Colin
Now that I think about it - you have to get two of them, right, one for each bank of cylinders? I'm sure the price is much more than I thought.
-juice
Dave
http://www.wave.net/diveguy/Dave
I am not a spy. I know you all do nothing to void your warranties and have all your maintenance completed at Subaru approved facilities. If you would like to provide your VIN's I can confirm all this.
Thanks for the info!
Greg
-juice
-juice
-juice
(I used to prowl the Subaru parking lot during some lunch hours hoping to spot a 2K Legacy/Outback back in March-July of 2000. And finally after many trips I saw the new Legacy there, well before they arrived in the dealerships.)
-- ash
Had to shop around, but Ken Beard has the best prices by a long shot. $88 for the pair of E-codes with Xenon 55/60 bulbs, shipping included.
The stock lighting is PITIFUL. He said the new lamp assembly along give off nearly twice the light, so the new bulbs ought to help even more (it needs it!).
Prices were all over the map. I was quoted $130 just for the E-codes from one place! They had generic brands for $80 (no bulbs though). R speed was asking $95 plus $35 for bulbs.
It's good to shop around!
-juice
-mike
Mike, that's interesting. I've very rarely heard of H3 spots when the high bemas are on. Are they supposed to be driving lamps to supplement the brights?
Drew/aling
Edmunds.com Townhall host
The Forester got a small improvement, but the Miata desperately needs a BIG one. The OE lamps are just plain awful. Dim and scattered, is the best way to descrive them.
-juice
BG: I bet you could make your own grille. People on Miata.net do that all the time.
-juice
-juice
Challenger Deep B4 parts
Challenger Deep Blitzen parts (dunno if you can get that grille separately)
Cobb Tuning's STI offering (again, dunno if the grille can be had separately)
Prova Parts front mask
There's gotta be more out there but I'd better get back to work!
Cheers,
-wdb
