1304930503052305430553158
    edited October 2023
    @stickguy said:
    A question for Mr. Flip-it JMonroe, and anyone else that wants to chime in.
    we have to decide on how to do our shower room (yes, it is a room, not a shower, I think it is 6x5). It is fully tiled walls and ceiling, but standard is a white shower pan. We can pay extra ($850) to have the floor tiled also (plus I guess an overage on the tile allowance!).
    question is, what would you do for effect and bang for the buck? I am considering not tiling the floor because I really hate grout and tile in the shower to start with. Especially on the floor since the water sits there. we did add the tiling into the initial contract but could always swap that out since they are far from that stage.
    one thing I am not quite sure of though (question for the builder) is how he does a pan in a stick built room like that (I assume he must frame it to fit, unless they custom make pans for that application).
    In a primary bathroom? Tile. Tile. Tile all day. Personally the number one thing I look at as a tell of someone investing in a Reno, flip, or new build is a tiled shower pan in the primary bath.
    Edit to add: I am not mr flip it. Just someone with expensive taste.
  • stickguystickguy Member Posts: 54,125
    it's the master bathroom, so I guess that would be primary. The hall bath comes with a tub. And both have tile floors.
    Grout on the shower floor just bugs me to no end. I hate dealing with discolored or mildewy grout! Really need a convincing faux-tile material for that. They actually make panel walls for the shower that look like tile. One neighborhood we looked at offered it as a middle ground between a full tile job, and a fiberglass insert.
  • tjc78tjc78 Member Posts: 17,380
    I hate our shower pan and wish it was tile. It makes an otherwise nicely done tile shower feel builder grade.
    Philly taking a major haircut. plenty in San Diego though so Andre should be happy.
    I might think that but not when I am cursing at the stupid grout for being dirty again.
    we did a parade of houses last weekend, and I was surprised at how many very nice, and expensive, new houses had shower pans with tiled walls. So it got me thinking.
    Many large retailers are closing urban locations. Rent is high, shrink is high, and while top line sales are high most of the time the stores are losers.
    Back when I was at my past employer we opened a giant store at Broad and Chestnut in Philly. Most days except Sunday they led the chain in sales… yet it lost 7 figures at the end of the year.
    Even if you consider that loss a marketing expense (which many retailers do with flagship stores in major cities) it still is a big number.
    I struggle with the joint between the tile and shower pan too. I’ve already dug out the caulk once and it may need it again soon. I guess that is still easier to deal with than many lines of grout.
    My suggestion would be to use a larger tile to minimize the grout lines. As for waterproofing they have amazing membrane systems today. Schluter is one brand.
    I’ve already been “debating” with the wife about shower tile. She’s thinking subway style so smaller tiles. I want the biggest ones possible. Bigger tiles = less grout!
    In our last house we had to have part of the shower rebuilt due to water leakage at the pan/wall tile joint.
    After it was fixed, since there was a horizontal lip at the joint, I caulked in some vinyl quarter round and never had a problem after that.
  • ab348ab348 Member Posts: 20,623
    When my bathroom was redone in 2017 I wanted a tile shower floor for the 3'x5' shower, but the cost quoted by the builder and the opinion of the plumbing guys was not to do it and get a pan instead. I wasn't thrilled but took their advice. The only problem with the pan has been that it has a center drain which I do not like. I wish it had been pitched to one end. The wall tiles are 12"x24" and the grout needs specific cleaning a couple of times a year. I use a general shower cleaning foam to start and then once that is done a Vim product that contains bleach to really clean it up and make it bright.
    The caulk seal at the base where it meets the wall was a problem only because the builders used the wrong type of caulk. I also cleaned that out and redid it with GE white silicone and it has not been a problem since. It responds well to the cleaners above.
  • kyfdxkyfdx Moderator Posts: 271,029
    I know the stores are under pressure to sell extra services. The previous manager at
    that store left because he didn't like having the pressure for unecessary sales.
    Tire Discounters?
    I'm with the tile floor contingent. Shower pans look cheap in an upscale house.
    I look cheap in an upscale house, so a match made in heaven.
    Our downsizing plan seems to be snowballing the other way. new place started at 2,400 SF, expanded(we pushed the entire back of the house out 2') to almost 2,600 SF, then went up another 40 or so when the builder tweaked the front facade and pulled a couple of rooms out 2', and with the latest change (adding a room over the garage) will be 2,800+ when that is fully finished out.
    I think we are finally going to get in and wander around lost, wondering why we have such a big house. Hopefully my son and his fiancée start popping out grandkids soon after getting married in case we want to downsize again so we can sell it to them.
    I did confirm with the builder there is room for building a garage (the lot is 3/4 acres but there are various setbacks that limit the building envelope) and he said where they sited the house allows for about a 22x22. He is going to shift it a few feet to allow for a 24x24 one, even though I doubt I would put more than a big 1 car space up. the main garage is already 612 SF and I don't have that much stuff to store! and won't get more than 1 extra car.
    Now they definitely won’t take the watch back at those locations 😂
    I hope you kept your stuff in the boxes for the next move!
    Most of it still is.
    In my last house I had walk in access to over the garage space from the 2nd floor of the house instead of the garage ceiling.
    That’s what he offered to do with ours. Only problem is the door will be off the back of the master closet so can’t serve as a bonus room or bedroom. Working on those details now.
    edited October 2023
    We can get to the space over the garage via an access panel in one of the upstairs bedroom walls. That’s a very large attic space if needed. The second attic space is accessed through another bedroom via a small hatch. I’ll never put anything up there.
    Maybe you should add a third floor. B)
    That is out of budget.
    Issue with ours is the design just has full trusses in the dead space over the garage. What he wants to do is change that to attic style trusses to carve out about a 10x20 room, and add a window at the front (over the garage but on the front facade since the garage is side entry. Basically another window in the dormer). And add a normal door so it is fully accessible. We are thinking of taking part of the space to push back the master closet (doubling that which have my wife drooling) and doing about a 10x14 room off that to use as an office maybe, but to start walk in storage.
    It looks like it will be relatively cheap to add lots of function and 200SF to the house.
  • jmonroe1jmonroe1 Member Posts: 9,691
    one thing I am not quite sure of if you only plan to staythough (question for the builder) is how he does a pan in a stick built room like that (I assume he must frame it to fit, unless they custom make pans for that application).
    I’m getting in here late and I’ve seen other’s opinions but here’s mine:
    There is no way in hell that I’d want a tile floor in a shower. If you only plan to stay 5 or 6 years then maybe I’d be fine with that. Even if they installed the old style 2 or 3 inch mud floor before tiling (that almost no one does today plus you’d fall over when you got the price to do that), I still wouldn’t want a tile floor. You don’t have to get plain white, although we go with white just to be sure the pan doesn’t clash with the tiled walls. And you don’t have to get a center drain. Once the builder knows where you want the drain, his plumber will place the drain line based on the pan you select. And yes, the pan goes in after the builder frames the walls to fit the pan. The pan manufacturer provides the rough opening for the pan.
    As for caulking where the tile meets the shower base we rough up the base with 100 grit sandpaper being sure to get the rounded edge where the pan makes the turn from the wall lip to pan itself before we install the pan. This insures the best grip for the caulk. And here’s the most important part about the caulk, use ONLY the GE 100% Silicon Caulk (don’t use anything else) to fill the at least 1/8 inch (preferably 3/16 inch) gap where the bottom tile meets the pan. It’s your choice of color (we use clear) so it goes well with any tile grout.
    I’d be willing to bet the builder or the plumber will tell you the grout they make today is better than years ago so you can use grout where the tile meets the pan, don’t believe that because it will definitively crack over time. It might take a few years but it WILL crack. If they don’t want to use the GE caulk tell him to use it anyway. I am 100% adamant about that.
    25 years... we've re-grouted the shower floor, once.
    I’m betting with GE caulk you wouldn’t have had to do it at all.
    It's tile..
    It's tile..
    Oops, I read that wrong.
    Are you satisfied with the life you got out of the first grout job?
    It's tile..
    Yes.. 15 years. Re-grouted mostly for cosmetic purposes.
    Didn't have to look at that ugly floor pan, either.. :o
    We wnt with tile in the shower as well.
    I guess I’m the odd ball about this but I’m still going to install pans.
    I’ll discuss with the builder. Our last house we tiled the floor during the remodel. After 11 years when we moved was in fine condition just a bit discolored. I did seal the shower tile a couple (well, at least 1) times per year.
    I like that idea. Seems like a win for a nice amount of extra space.
    we do too. just need to get an actual quote but when he first mentioned adding the room (without the closet bump out, which really should not cost much at all), it was only about $3k to add a 10x20 room, including the different trusses (no clear if they cost more), a window and fire rated door, floor decking, and insulation. Seemed like a screaming deal, other than losing too much usable closest space without or reconfiguring added in ..
  • oldfarmer50oldfarmer50 Member Posts: 24,541
    Go with your gut and skip the tile on the floor. Sure it looks pretty when new but you’ll be doing a lot of cleaning.
    How about using it as a secret man cave?
    don't think that did not cross my mind. Office, exercise room, man hideout. All work!
    If you look at picture 24 you can see the 8x20 attic floor space over the 2 car garage.
    https://www.realtor.com/realestateandhomes-detail/24-Centerbrook-Dr_Farmington_CT_06032_M32697-82440
    that looks like it would come in real handy.
    Make sure they have a plan for ventilation
    Can always open the window. We are waiting for options on running HVAC to it. Might put in piping to allow a mini split later on. Still TBD
    edited October 2023
    The past couple of weeks, my new Explorer seemed to have been riding a bit rough.
    It does have a sport suspension.
    Checked the tire pressures and they were actually a bit low, so added some air.
    Took it for about a 35 mile ride and after a while, it seemed fine.
    Then I remembered, Pirelli tires. They start out rough then smooth out after a few miles.
    Guess I was just taking too many short trips.
    Picked the Explorer up on 9/30 and still on my first tank of gas.
    I would not bother with extra space on a 2nd floor that didn't have A/C ductwork.
    We had similar experience with my wife's X3. The Pirellis were stiffer, but miles better in tracking and handling.
  • sdasda Member Posts: 7,711
    edited October 2023
    Do they flat spot a little? I believe the tires on my Passat do the same if not driven daily. I get some minor roughness/vibration around 50 mph. After I’ve driven a while, smooth going.
    Ugh ! Phillies giving me heartburn early!
    @sda,
    The ride was somewhat harsh not bumpy.
    I never thought I’d be bringing the discussion back to appliances but I need opinions on electric stoves. The one we have is old enough that I don’t remember when we bought it. It’s a GE stove which seems to be having a problem with the controls. Once turned on you can’t modulate the heat so it’s basically on or off.
    I’m sure it’s a problem with the control circuits.
    My question, will a repair be as expensive as just buying a new stove?
    That old might not even be able to get parts. If you feel handy, just take it apart and see what you find. Might be videos on YouTube.
    Otherwise go to the scratch and dent section and look for a deal. I’d bet a repair call will be at least half the cost of a new one
    I’m depressed today.
    I don’t understand letting Kimbrel blow it 2 days in a row. He shouldn’t have even been available last night. Ridiculous.
