1836837839841842854
    Assuming good mechanicals I’d take that Explorer in a heartbeat. You can’t get anything here that rust free for that price.
    I like that 91’ DeVille, my son had a 93’ with the 4.9L. It wasn’t as powerful as the Northstar but was the best of that engine series. Enough back seat room to install a pool table.
    That Lexus looks like a good transportation buy although I have trouble accepting 121k as “low mileage” even on a Lexus.
  • explorerx4explorerx4 Member Posts: 21,038
    That Explorer might have manual locking hubs.
  • sdasda Member Posts: 7,710
    The 91 DeVille has the optional Bose, probably very rare in an low optioned car. Looks decent overall.
    Other than leather what is that Caddy missing? Looks pretty loaded for the time.
    You are correct, I overlooked several features. Astroroof and leather are two that come to mind that would be nice. I wonder if the driver’s seat would clean up nicely. A thorough interior detail would make a huge difference.
    Lord help me, I also like the Explorer
    The Explorer is the pick of that litter. I'd buy it for the sheer coolness of it. But "great winter car?" Here in mid-Michigan it would dissolve away.
    It's a amazing the difference a little lot of salt makes...
    The Lexus is another solid choice.
  • tjc78tjc78 Member Posts: 17,375
    The Grand Marquis would most likely outlast anything on the list.
    edited November 2023
    ..even the Lexus?
    I had that drivetrain in an '03, and it was rust did the car in.. the engine soldiers on in another van in Northern Michigan..220k when it was transplanted. Ran like new, long-term problem was a coolant leak of the block, by a freeze plug. Stop-leak held it for the last year with us.
    A friend has a Crown Vic from the mid-aughties, and while it still runs fine, he's had problems with leaks, AC, power steering..all typical ones. It'll 'never' stop running and driving, but the economics will do it in.
    My money's on the Camry clone.
    Also wanted to add:
    Doesn't that Explorer bring back the memories? Almost makes me want to roll it B)
    cheers -mathias
  • stickguystickguy Member Posts: 54,106
    I would try not to drive my winter beater when the salt was down either, but at least I would not be afraid to. I also go to the touchless wash with the underbody rinse any time I know it got salt on it. Unless it goes above freezing and I drag the house out.
    QBs Xterra would be a great winter car. Disposable, and really good in the snow.
    The Lexus has a check engine light that the mechanic can't diagnose.
    there you go, reading all the details instead of just looking at the pictures and the headline!
    yes, that is concerning. And I would bet the reason they bought a new car. Also sounds like a lot of deferred maintenance if they needed a major rehab. An evap code is not that hard to diagnose. But an "air flow" issue is an odd way to word a leaking gas cap (and that is the easiest thing to shoot the parts cannon at)
    I’d take the Panther over the Lexus. They are truly tough to kill and easy to fix. Parts are cheap and plentiful.
    I’ve been in Town Cars with 600k on the clock.
    I could not see myself ever driving a crown vic though. I don't care if it will outlast the cockroaches.
    You think you hate it now… wait till you drive it.
    Oh Clark....
  • kyfdxkyfdx Moderator Posts: 270,975
    I've been in the back seat... :#
  • gsemikegsemike Member Posts: 2,453
    Taurus SHO
    With 146k and a new electrical problem, it may be time to move on from the BMW X5. I'm liking this and hoping some of you guys may be familiar with these.
    2011 Taurus SHO
    I'm a hyrid worker and take the train when I do go in so may only be looking at 8k to 10k miles a year. What to look out for?
    I am very fond of those and always have my eye out for them
    The left front fender and the drivers door are different shades of gray.
    Water pump is an expensive repair on those 3.5's.
    I would invest in a Carfax if you are interested.
    Anyone notice the Merkur in the background of some of the pics?
    I did. I guess he's a Ford man
    Well that may have cured me of ever wanting one. This is just part 2, but it is the more important bit. https://www.youtube.com/watch?v=_fLg9CeGUZY
  • texasestexases Member Posts: 11,183
    Holy moly! That's a LOT of work!!
    Wow, that is truly frightening. A car that can be totally by a bad water pump
    I guess the question is wht is the life expectancy on the water pump?
  • xwesxxwesx Member Posts: 17,935
    Such a PITA, but not an uncommon occurrence. Many vehicles' water pumps are driven by the timing belt/chain as opposed to an auxiliary serpentine belt.
    True, but at least with timing belts the pump gets replaced every time the belt does, which usually is easier than this job.
    This reminds me of the Audi 4.2 L V8 timing chain problems.
    edit: well, maybe not THAT bad:
    Jesus, I'll see that in my nightmares
    I guess that this is a product of trnasverse mounted engines and the need to decrease the depth of the engine.
    I think the Audi V8 is longitudinally mounted, but with the timing chains against the fire wall. Engine removal required, and the repair is pretty common.
    I watch a lot of repair videos (having no life to speak of) and the way some bays are packed in, it really could be quicker overall to pull the engine so you can get at everything.
    LOL I have that Audi picture saved somewhere, and when I get indecent thoughts about owning one, I look at it for a while.
    Also you're totally wrong about this part.
    ...because the CHAINS are fine.
    It's the plastic tensioners that go bad, in turn fouling the chains, of course.
    Nobody could have seen that coming ;)
    It's a truly inspiring storyline -- the sheer idiocy of it, and yet you can follow along step-by-perfectly-reasonable-step. I particularly like the part where the guy must have said, I have an idea, let's rotate the engine 180 degrees for better packaging, since we never need to get at the timing chain!
    That's why you can buy an older A8 for chump change, and shouldn't.
    cheers -mathias
  • fintailfintail Member Posts: 58,780
    Some cars I wouldn't take for free. Old A8 is one of them. I'd probably even rather risk a V12 W220 MB than an A8, insane but less insane.
    A 4.2 Audi V8 Timing Chain job should be mandatory apprentice training for all car mechanics. This would lower the cost of the service.
    It was a fortune even when my ultimate Audi indy shop was only charging $115/hour just not that long ago. Inflation is killer, it's $156/hour now. Can't blame them, most every other specialty German auto shop charges much more here in San Diego.
    I like the Mazda pickup
    Eldo would be so nice in white or black. That yellow is awful
    Eldo seems to be missing the ac compressor. Auto Climate Control, ha! I do like the 78 MB, especially the cloth interior.
    Isn’t that a Ford Ranger?
    That was the Mazda. Ranger came later and Mazda got a rebadge of that.
    Not sure if Fintail is going to happy or sad watching this.
    Fast forward to about 2:15 for the start of the real action.
    https://www.youtube.com/watch?v=2T5mCaWmXQc
    Ha, I saw that the other day. Pretty respectable performance from a 30+ year old car with a not overly powerful I6. Almost like the chase could be a MB commercial.
    Sad to see one get wrecked, but they aren't rare, and plenty of both good and neglected ones are still out there - pretty good survival rate on W126 I think, as build quality is immense and they are generally solidly engineered.
    Wow, Georgia troopers don’t mess around. Here in NY they’d discontinue the chase and send him a fruit basket the next day to make up for his emotional trauma.
    Thanksgiving shopping on Long Island
    This Marquis looks well preserved Get into the ride sharing biz maybe
    Whose got a spare small block
    The mileage claim for this Cougar may be legit Real Grandpa special. Always hated the center console with column shift on these
    Grandpa special Toyota truck Never see these like this anymore here
    AMC Matador The Mercury wagon may be more interesting
    Mitsu 3000 Unfortunately looks pretty base and worn out
    I like the little pickup. That would be perfect to have at my Ohio place for a runabout.
    That Cougar is about as base as I’ve ever seen.
    "minimal rust, compared to other Tacomas" :#
    That awkward roof on the Cougar has never grown on me.
    Ya, the Tacoma pictures are carefully taken. It looks great -- from above and 50 feet.
    On the other hand, at < $5 they're not trying to hurt anyone.
    Frame issues scare me. Sounds like it rotted out and they just hacked some metal onto it. I would want that one carefully looked at underneath.
    Same here - they need to have some kind of "cause" to chase I think, although I think the lives of troopers lost in chases and probable lawsuits from crashes or damage from chases might be part of it.
    That Tacoma would sell in 10 seconds at that price here, but they generally don't dissolve here either :)
    Cougar looks like it has those porous polycast wheels, maybe the only option (I am certain generic wire caps were standard, or should have been maybe). I too prefer the Bird of that generation.
    AMC looks like pics were taken by a phone camera from 1978.
    Agree. Give them credit for differentiating it from the T-bird but the rear window always looked too vertical for me
    Yes, a good thorough look is needed
