“you gonna make it all 220?”
“yeah, 200…, 221 whatever it takes”
Better get it fixed fast.😨
Also, think I'm going to change our phone plan to AT&T's Unlimited 55+ Plan as with today being the last day of our current 6 gig plan, we're just at 5.67 gigs of use before the rollover kicks in. We'd be paying a few dollars less but getting unlimited data. But, we'd no longer have my postal discount or the loyalty discount which are both in place now. The good thing with my postal discount is we don't pay any up charge when we get a new cell phone, that $30 fee is negated on our bill. But, since we don't get new phones that often, I've got a 12 and the wife has an XR, might be worth just getting the peace of mind with the 55+ plan. I'd no longer have to monitor our data usage which I do now. And with our daughter moving over to her sisters cell plan, makes total sense to do the move today, the last day of the current cycle. As it stands now, if I wait a month, we'll only have like 6.23 gigs for December and my wife used a whole lot this month, the most ever. And it's $15/gig if we do go over our plans coverage, a total rip off! Still have some time to think about it.
We have a Medicare supplement (Plan G), and except for a $250/yr deductible, we have virtually zero out of pocket, other than the premiums.
Chronic Medicare buyers anonymous??
That said, I like to keep a short list on hand at all times, just in case....
I think transmission fluid or CVT fluid in general contributes to the longevity. People get scared off by a lot of “power purge” services offered by dealers when a simple drain & fill will do the trick.
I plan on having the coolant, brake fluid, & transmission fluid changed at 50K miles on our Highlander
Sandy, maybe you should get a Kona for yourself and let her take the Golf off your hands.
You may have already done this but make sure all individual breaker wires are tight and make sure the breakers themselves are gripping tightly on the panel bus bars.
Make sure the incoming 220 lines that are connected to the line side of the panel disconnect breaker are tight. Also make sure the incoming neutral is tight and there isn’t any corrosion on any wires. If it were me I’d yank the meter and check for tight connections and no corrosion in the meter box as well. You might even have a loose meter.
If you have good, clean and tight connections everywhere call the utility so they can check the lines at the pole and transformer.
One of your neighbor might have a heavy duty welder or something like that that’s causing the lights to flicker when it’s being used. So, the utility has to check out and possibly upgrade the transformer if it can’t handle the load of all the houses properly.
In my case, we finished the lower level in 2009. When we re-did the kitchen this year, I needed a new 40A circuit for the electric cooktop (old cooktop took a 30A circuit). The cooktop is as far as possible from the panel in the lower level. $750 just for that one wire. If I'd had a panel in the garage, I could have run it from there, with no dry wall repair, and 50 feet less of wire. Also, I could have a Level 2 car charger, at minimum expense. I've also considered putting in a new A/C system for the 2nd floor, with the air handler above the garage, but again, I'd have to run 220 across the house, and repair more drywall.
"Mustang Mach-E: Ford began increasing production of the Mustang Mach-E this week. Changes at the plant will allow Ford to nearly double its hourly production and bring its annual manufacturing run rate to a targeted 210,000 units by year's end."
https://media.ford.com/content/fordmedia/fna/us/en/news/2023/03/03/ford-increasing-production-of-popular-electric--gas--hybrid-vehi.html
So Ford was projecting sales around 17,500 a month for the Mach-E by now, in order to reach that sales goal of 210k a year by 2024. But instead sales of the Mach-E in October of 2023 were 2732, which means sales were about 80% lower a month than Ford was projecting in March.
https://www.goodcarbadcar.net/ford-mustang-mach-e-sales-figures/
For calendar year 2023, sales of the Mach-E will probably end up at around 40,000, which would be about the same as 2022. 40,000 compared to a goal of 210,000 by 2024. Wow.
The lowest priced Mach-E on our local lots has an msrp of nearly $50,000. Only a small percentage of the population can afford that, even with government rebates.
The most affordable vehicle in Ford's line-up is the Maverick, which starts at around $26k. But Ford can't make enough Mavericks to keep up with demand, and many are loaded Lariats with msrps in the high 30s.
Seems like Ford needs to remember that the vehicles that made the company successful were models like the Model T, the Ford Falcon, the original Mustang from the 1960s, the LTD, and so on, including the more basic F-150, which was once an affordable work truck. The lowest priced F-150 at my local dealer is $44k.
The lack of inexpensive vehicles is definitely a problem for Ford. They banked on big rebates, discounts, and near zero money to sell expensive trucks and SUVs. Although, to their credit, when they did make inexpensive vehicles they weren’t very good.
Ford made the mistake of going “all in” on hybrids way back when gas 1st shot up. I remember bill ford jr. professing they are going to have 250,000 hybrid vehicles on the road by (insert date). The 1st Escape Hybrid was a great compact SUV. While it didn’t achieve Prius like gas mileage numbers, it looked like a regular Escape that just got better gas mileage. Once gas prices came down, you didn’t hear a peep about Ford Hybrids…
The car my parents had when I was a little kid was a 1960 4-door Falcon station wagon, which was running fine when my parents traded it in for a 1969 VW Bus. When I was in grad school one of my professors, who happened to be from Germany, said one day when we were at a party that he had a Falcon in the 1970s too when he was in grad school. When I told him the Falcon's mastermind was none other than Robert McNamara, he was amazed. He laughed and said, "My Falcon lasted a long time—even longer than the Vietnam War that McNamara also helped mastermind."
In 1965 Ford sold more than half a million of the affordable Mustang, which of course was based on Falcon platform.
Today Ford's affordable vehicle that I think could sell in those kind of numbers is the Maverick. With starting list price of $24,995, the Maverick is actually only slightly more than the price of a Falcon when you adjust for inflation. And obviously the Maverick is much faster and much safer than the Falcon was. It's overall a much better value than even the bargain-priced Falcon of 63 years ago. But Ford can only make about 90,000 Mavericks this year, and I read somewhere that only about 15% are the base model—not because there isn't demand for the XL, but because the others make more profit. But it seems like Ford should try to find or build another factory so that they can build at least 300,000 Mavericks a year, and make maybe a quarter of them base models so that when people with average incomes walk onto a Ford lot they can drive out with one that day.
If you ran 221 for the cooktop, you would have had the spare line you need for the 2nd floor AC system.
https://www.paducahford.com/new-Paducah-2023-Ford-F+150+Lightning-LARIAT-1FTVW1EL8PWG22916
A local dealer is advertising $10k off a Mach 1. They have many. I don't know the details.
there will be 220 close since the kitchen backs up to the garage and there will be an electric oven which I assume needs 220. so adding a wire over to the garage should be easy enough. I hope.
not too worried about the outlet in the garage. What I do want to figure out is how best to prepare for a potential stand alone garage addition. that would be near the attached garage, but further away from where I expect the main panel to be. That won't need a large power supply (not planning to have high draw equipment, just normal lights and outlets) but want to make it easy to get that when needed.
I'm no electrician, but I am smart enough to know it is way easier and cheaper to do it when you are roughing everything in, than it is to do after the walls are in!
I don’t know what wall will be closest to where your additional garage will be but let’s say it’s in an unfinished part of the basement. Have the electrician run a 6/3 with ground copper cable to a surface mounted junction box at that point. That will give you the capability of a 50 amp panel in the new garage unless the TOTAL wire run length is too long for a 50 amp load on 6/3 cable. If that’s the case run the 6/3 cable but install a 40 amp panel in the garage which should be enough for a home owners garage. Just be sure that he installs a large box to make the splice of that size wire for the panel in the new garage. I’d install a box that is at LEAST 4 inches square and 2 inches deep for the connection. It can be done with a smaller box but I like large boxes given the choice.
I’d also have the electrician install the 50 amp breaker (40 amp if the wire run is long) in your main panel not just coiled up near the main panel for when you get the new garage. That way once the splice is made and the new garage panel is installed all you have to do is turn on the breaker in the main panel for the new garage.
There are other ways to do this but that’s too involved to explain here. Your electrician should know the other ways. Even if the wall is finished.
Hopefully the code in your area will allow for this type of future service.
"With the expansion, Ford will have ability to produce the F-150 Lightning at an annualized rate of 150,000 units by this fall."
https://media.ford.com/content/fordmedia/fna/us/en/news/2023/08/01/ford-restarts-expanded-rouge-electric-vehicle-center--f-150-ligh.html#:~:text=DEARBORN, Mich., Aug.,the award-winning electric truck.
150k a year translates to 12,500 Lightnings a month. Last month Ford sold 4,400 F-150 Lightnings in the US. That's a record, but still it's far below where they were hoping to be at this point. I'm guessing some Lightnings are going to other markets.
https://electrek.co/2023/12/01/ford-f-150-lightning-breaks-monthly-sales-record-november/
For someone who needs an F-150, at this point with the gov't tax credit the Lightning is less than an equivalent gas model
I will just ask the electrician when we meet what the options are and the costs now, vs. how hard/costly if I do need it in the future. I was thinking of what I think JM described (running power to a point that would be easy to connect to if needed).
Maybe a panel of some sort in the corner of the garage that could run the 220 outlet, and be the connection point for future use which probably would not involve much more than a 20-30' run)
Didn’t that happen when you turned the lights on/off?
You have to pay attention to who’s trying to create the hype.
Contrast that with a couple of dealers in the Cincinnati area who actually treated me very well. The Fighter Jet Gray Mach 1 I considered in Northern KY was a great car, but the thought of dealing with local dealers for warranty work was a major demerit; my uncle is a retired Ford employee and even he is unhappy with the quality of the Ford service departments in Louisville. I know @corvette has had some entrtaining dealings with them as well.
What’s the odds that you need a Ford dealer in warranty though? 😂
Guess I fell asleep and left my phone in the bathroom as the kids & my wife were blowing my phone up! Turns out, she bought the 2023 Kona Limited AWD in gray over black with navigation and the Harman Kardon audio system. Got a good deal off being that the 2024's are already out. Gave her a little less on the A3 then they said three weeks ago but she still did just fine. Went over & did the paperwork and now, it's sitting on her side of the garage.
She's very happy with her choice and just glad it's all over. At least now, I know what to try when my turn comes around. Very impressed with the Buick Encore GX & the Kia Seltos and now, need to drive the 2024 Hyundai Kona Limited or N-Line. Still keeping the Mini Cooper Countryman on the list though would prefer a loaner if they have one available. But, no rush here.
Hoping she'll want to take the new Kona up to St. Augustine if we go on the 22nd of December. I have to work on the 26th but since TurboTax is closed that week, she can spend more time there. So either she'll take the train up to Palatka and our kid will pick her up there or I might drive her and the Golf up there and come home on the 25th alone & let her take the train back to Deerfield Beach & pick her up there. No way would I take her Kona if she wasn't coming both ways as it's not mine to take. Am sure the Golf will be just fine but don't want to look for any trouble. Good thing is with her now taken care of vehicle wise, I can pick the time I'm ready to purchase my next ride. And really think 2025 will be the year to do this but that's always subject to change.
36 so far this year, counting Sandy's wife's punch.
