-juice
Bob
-mike
My next door neighbor just got a new '03 Explorer Limited a few days ago. The thing is loaded. He has a couple of boats, so he did get the optional tow package. Because he and his wife don't have kids, they did not get the 3rd row seat option. By doing so, the have an extra good sized hidden storage area under the rear floor, just behind the 2nd row seats. This is their 3rd Explorer, and they seem very happy with the new one.
Bob
-juice
-mike
And another question, when I flush out my tranny, do i have have to worry about air in the torque converter? Too much conflicting information on the web, some people say a complete flush is no good as it will trap air in the converter if you're not careful, other people say it dosen't matter. Since I was going to disconnect the hose to the cooler anyway, I was going to just change the fluid too. but now I'm thinking I might just drain the pan only. Not sure what to believe.
Has anyone installed a wire harness for the 2000 outbacks? wondering if the vehicle can handle the extra amperage needed to power the extra trailer lights.
ps I would start a new discussion for towing...only if I knew how??!
Cheers, Dave
Bob - forgot to mention I didn't have time to look at that burned out bulb, sorry 'bout that.
-juice
Hope that helps,
Steve
http://www.snopes.com/photos/lumber.asp
-tom
Great picture/story! It was nice to have something to laugh about-it's a wet dreary weekend coming up in the NE.
Mark
-juice
While I was at it, I changed the spark plugs, flushed out the cooling system, changed all the filters, and changed the power steering and tranny oil. I was going to change the steering rack bushings, but for some reason one of the bushings didn't fit, so I'll have to wait on that one.
Now I'm ready to go camping too.
-mike
Also, when I replaced my spark plugs, I found out that the factory plugs were worn down, the gap was almost .080", almost double the specification. I don't know if that affects anything, my car still ran fine, but I'm glad I changed them.
Good job on the tranny cooler. Did you get pics?
-juice
Jon
I looked at the accessory brochure for an '02 Outback and online at Subaru.com and I don't see the additional power outlets offered. I know they were offer for the last generation ('96-'99) and I believe they went in the location that you described (behind the parking brake).
DaveM
I'd like to know more to see if it's a way to quiet our new Forester down a little, for long road trips, etc. Hopefully it 's something hidden that doesn't reduce the space in the car? Otherwise I'm picturing something like a padded cell and I don't want that, though some might disagree
Has anybody heard of or done this? Is it something I could DIY?
JL
Hope this helps
Mike
For those with interior air filters, check them annually. Mine were filthy! Time to change them.
-juice
Ken
I've also used a spray-on coating before. can't recall the name unfortunately.
-Colin
Ed
-mike
But the least expensive adhesive-backed dampening sheets I've found are here: http://www.mcmaster.com/ Search for product number: 9709T19. At least one person reported this was satisfactory stuff, but for $15, it wouldn't hurt to buy a sheet and check it out.
-tom
I was looking into this as a possible solution to elminating some noise up from the pavement and also dampening some of the fine tremor that we feel in the new Forester when it's in a drive gear. I'm going to check it out but I may wait a bit on the insulation and give the car a little time to see if some of the noise/buzzz settles. We've only got 120 miles on it. It seems like it's not quite as apparent as it was the first few days.
On my 98 Forester the engine has gotten more rumbly so there's not the same kind of rhythm. I think the new car maybe just has a more even humm than we're not used to lately. And my wife had a manual transmission in her Outback so she usually had the clutch disengaged when crawling through city traffic, sitting at a light, etc. which is when she most notices the vibration in the new car. She doesn't like switching in and out of neutral with the automatic just to avoid the hum.
jl
The '02 road test pretty much described the sensation of the drive train, road feel, etc. and even suggested a little eventual sound dampening by the manufactuer as a solution. We're getting more used to it but maybe the matting everyone's suggested would still be interesting to try one of these days.
-mike
-juice
http://lighting.mbz.org/tech/relays/relays.html
Jim
By the way another good reason not to route high current through switches is so that you can do cool things like controlling them with computers :-)
Cheers,
-wdb
-mike
-Colin
Fixed it and bam running like a champ.
-mike
Who's car did you work on?
-Dennis
-mike
I believe I went with a 6x11" tranny cooler from B&M. I forgot the actual size already, but it was one of the smaller ones they had. I installed it in series after the stock cooler, so the hose on the passanger side connects to the cooler, and the output of the cooler connects back into the hard lines. No snags, it's easy to install if you remove the radiator to gain more room inside. I installed mine in front of the condenser, but to attach the clips I needed to remove the radiator. Since i was flushing out the coolant at the same time, it's no big deal, there's only 2 or 3 bolts you need to undo. Probably takes an hour or two if it's your first time.
Also, most newer cars all use relays for the headlights, but subaru uses a switched ground system rather than a normal ground. I found this out while installing HID's. The three plugs for the H4 headlights are normally HighBeam: Ground: Low Beam. Under normal operation (low beams) the wires are 0V: 0V: +12V. When you switch to high beam, the ground becomes +12V, so it switches off the lowbeam and switches on the highbeam in one operation.
On another note I did order a replacement grill and badge from Liberty, along with the cabin air filters; thanks to the recommendation from those on this board. Turn-a-round time was 4 business days from when I mailed it. Not bad at all. Now, I actually have to do the replacement. I also finally ordered the skid plates from Primitive which should be coming in any day now. Now I won't have to worry so much if I go to the Pine Barrens, or any dirt roads.
Mark
It's an Anti-Lift Kit offered by Whiteline, Comfort being one of the variations of the type of kit offered.
This might shed some light:-
http://www.whiteline.com.au/articles/AS_Rex_on_rails_3.pdf
-Dave
Mark
Also, consider the source of that ALK review for a moment....think back about 6 months ago....lots of exclamation points.... compulsive/obsessive car buying...
