Visitor Agreement.
-Dave
-mike
-mike
-Dave
-mike
-Dave
-mike
Jim
-juice
-mike
WRX Seats (front)
WRX IC
MBC
WRX Injectors
VDO Boost Guage
AGX Struts or Konis
Upgraded Springs
SP5000s on the WRX Rims
Dunlop M2 or M3 Snows on WRX Rims
WRX Rotors
WRX Front Calipers
Hawk HP+ pads
SS Lines
Catback Exhaust
That's about it for now
-mike
It's not like my wife would notice, anyway.
-juice
-mike
OK, less work for me.
-juice
Here are the plans so far...
WRX Front Buckets (Already bought)
KYB AGX Adjustable Struts (~$400 from Tirerack)
H&R Springs (~$200 from Tirerack)
WRX Front Rotor, Calipers
Hawk HP+ Brake Pads
SS Brake Lines (~$100 Goodridge)
Cat-back (undeterminded)
SP5000 Tires
-mike
Eric
P.S. I know the OB's ground clearance will make it worse--and I should've gotten the Legacy--so shoot me!
Eric
-mike
As Mike mentioned I have been checking out upgrading the rear sway bars on my 00 OBW. It looks like there are 2 main manufacturers : Cusco, and Whiteline. I just found through AZP, that Metric Subaru sells the Cusco bar for $175. I emailed him to find out if that includes the links/bushings or not. Someone earlier on this board mentioned that you should upgrade the links with the bar. I'll let you know what their answer is.
Mark
-Dennis
BTW, Dennis, Cobb lists the bar for a 96-99 Legacy/Outback. I think it may be different for a 2000.
Mark
IMHO are well worth it. I know I noticed a big difference between putting a sway and putting a sway w/ endlinks in the L. Essentially if you have a 13mm bar with rubber endlinks you are at X anti-roll. If you put a 22mm bar on w/o endlinks you are at X+22 anti-roll. If you put a 22mm bar w/endlinks you are at X+26mm (not an exact calculation)
-mike
Alan
98 OBW Ltd
Mark--we're both in the same boat with the 00 OBW. Let me know what you find out.
Mike--so you said you're running 26mm bars on the L? Is the difference significant?
Eric
Difference? HUGE. Especially cause the FWD Bias of the 4EAT trans in the L. I can now kick out the back and not plow like I did w the stock bar.
-mike
http://www.cobbtuning.com/wrx/pr-swaybar.html
He comments more over on nabisco/forester.
-Dennis
A new question:
I've tried looking it up at my.subaru, but I am having no luck. Does anyone know the correct size of windshield wiper blades for a 2000 OB? I think the drivers side is 22", the passenger 20" or 18", and the rear is 16" or 18". I'm looking to p/u winter blades, and I want to get the correct ones the first time out.
TIA,
Mark
I measured the OEM wipers that I took off my '03 OBW this weekend. The driver side is about 21.5", the passenger side is about 19.5" and the rear is about 14.5". 22" and 20" would probably work. Not sure if they come in 15" for the rear.
I'm using the Anco winter blades that I bought for my '96 OBW. The driver side is 20", the passenger side is 18" and the rear is 16". The front wipers work fine but I think the 16" rear may be a little too big since it doesn't seem to form to the curve of the upper part of the glass.
Of course I put them on AFTER this weekend's snow storm and it's raining now and probably all day tomorrow.
DaveM
Thanks for the info. This past weekends storm is what made me think of the winter blade. I realised the usefulness of winter blades after I did not have them on last years 48hr trip. We had to keep stopping periodically so that I could knock the ice and sludge off the wipers so they could work properly. This year I plan on having them!
I've noticed that the rear wiper doesn't fully cover the window at 16"; I think I may try your suggestion of 15".
Thanks again,
Mark
Check out http://www.rallispec.com/product-susp5.htm
-Dennis
Thanks for another good link. The only thing with this model is no adjsutable factor - it is 18mm only. From everything I have heard, the adjustable is more desirable. Any opinions out there?
Mark
Anything to especially watchout for and where did the factory place the unit in the trunk?
TIA,
Jim
Only seen those mounted under the driver's seat.
-Dave
-mike
i'll post a link if it i see another.
thx,
jim
Cheers Pat.
-juice
I am putting in a 5MT tranny along with the rear diffy and hubs and lateral links etc from an '03 WRX with 18K miles, got an outstanding deal on the parts so couldn't pass it up. Just need to get a flywheel for the 2.2 and a starter.
-mike
-mike
Jim
Jon
I'm sure it'll help make you more competitve at the track, though.
Ed
-juice
-Dave
-c
http://www.hockeymasks.com/masks/Gerry-Cheevers.shtml
Ed
-c
