2024 Lincoln Nautilus Lease Deals, Incentives, Rebates, and Prices
2456
  • woodenheart32woodenheart32 Member Posts: 46
    Here's another sheet. Don't see an interest rate on here. Thanks in advance
  • MichaellMichaell Moderator Posts: 269,540
    The dealer is trying to hide the APR on you by not showing their "internal" lease worksheet. Which leads me to believe it may be marked up for extra profit.
    If I add the sales tax amount to the "net cap cost" and use the base APR, I get $827/mo.
    Simply ask the dealer if they are using the base 4.30% APR for the 48 month term, or not.
    Thank you. That's what I believe as well. Am I correct that a 36 month lease using these numbers but using an the APR (2.86) and residual (55) would be close to 880 per month assuming zero down and 880 drive off?
    This is calculated for a 36 month term so at 857 for 48 doesn't seem right at all.
    I get $907/mo using the same prices.
    I'm getting 880 give or take. What can I be missing?
    Adjusted cap cost minus residual gets me a base payment of 704
    Adj. Cap cost plus residual x 0.0011875 = 104
    808x 9% tax rate
    Forgive me if I'm not understanding. Just trying to figure out what I can be missing.
    808x 9% tax rate
    What are you using for the money factor? 2.85% / 2400 = .00119, roughly.
    I was calculating the tax wrong. Now I get $882/mo.
    Yes. I was using that MF and got the same.
    So 36 term comes in at a 1.00 a mile. 48 term .93 per mile. Any reason to not go with 48? I personally never have. This vehicle will be under warranty the whole term. Probably have more maintenance from yr 3 to 4 that could negate that 7 cents though. Thank you for your time. Always appreciated!
    I see some pups in your avatar.. I'll donate to my local shelter on your behalf, for your time!
    You got it ... consumables like tires and brakes may need to be replaced in year 4.
    Thanks for the thoughts on the puppers, but it's not necessary. Only two of them are still with us.
    Yes. My thoughts exactly.
    Very sorry to hear that. Having a dog will bless you with the happiest days of your life, and one of the worst.
    We donate locally when we can. Our shelter runs out of supplies ,it seems, too often.
    Thank you again!
  • CandyMan70CandyMan70 Member Posts: 74
    Hello, can you provide lease terms for Hybrid Nautilus Reserve 2 and Hybrid Nautilus Premier 2, 12k miles, 39 and 48 mos for 01030?
  • kyfdxkyfdx Moderator Posts: 273,418
    Appears that the February numbers have been extended through the weekend.
    Ok. Are the terms the same for Reserve and Premier trim levels?
    Premier residuals are 2% higher than Reserve
    All else is the same
  • Hello! Can you please provide the Residual Value and Money Factor for a 2024 Lincoln Nautilus Reserve HYBRID I-4 for 36 month lease for 10,500 miles in 89117. Thank you!
  • Gakic316Gakic316 Member Posts: 36
    Hey folks, looking for MF and residual on Reserve 3, non-hybrid. 39/10k. Located in Miami,Fl 33133. I would also be trading in a Lincoln if there are any Red Carpet Incentives. Thanks!!
    2.85% APR
    55% residual
    3.10% APR
    54% residual
    Most of Lincolns loyalty offers are private/direct. I don't have any info
  • AMS1985AMS1985 Member Posts: 8
    Hi all. Looking for help figuring out what a reasonably good deal would be on a 2024 Lincoln Reserve I would be with $9,525 in options, for a total MSRP of $66,515. Would lease for 36/10k or 48/10k. Zip code is 20814. Appreciate any help you can offer. Would also appreciate the MF and residual. Thanks in advance.
    2.85% APR and 55% RV
    4.30% APR and 49% RV
    We don't track pricing; use the Price Checker link below for Edmunds research.
    Hello, can you also provide me the lease terms for Black Label, Hybrid engine, AWD for 12k miles, 39 months for 01030?
    3.10% APR
    52% residual
    3.10% APR
    54% residual
    Thanks, just wanted to update you, and so that others can have an idea.
    MSRP 68400
    Xplan 64,640
    39/10
    1K out of pocket
    981/month. Tax in
    I passed on deal. Was looking to be at 850.
    Gakic316 said:
    3.10% APR
    54% residual
    MSRP 68400
    Xplan 64,640
    39/10
    1K out of pocket
    981/month. Tax in
    Thanks for the report!
  • blhowardblhoward Member Posts: 1
    Can I please have the money factor, residual value, and rebates or incentives on a 2024 Lincoln Nautilus Premiere on a 12K mileage and 36 month lease. Zip code: 27707
    2.85% APR
    57% residual
  • dkadka Member Posts: 14
    edited March 2024
    Hi - I am looking for the MF, RV, and rebates/incentives for a 2024 Nautilus for a 36 month/10k miles lease. If possible, please tell me if there are differences between Premiere/Reserve and regular engine/hybrid. Zip is 90049.
    2.85% APR
    PRM: 58% residual
    RSV: 55% residual
    2.85% APR
    PRM: 58% residual
    RSV: 55% residual
    Thanks! Any difference if its regular vs. hybrid?
    dka said:
    2.85% APR
    PRM: 58% residual
    RSV: 55% residual
    Nope
  • JENNTL90JENNTL90 Member Posts: 6
    Hallo! Looking for all the standard deets on a Reserve III (non hybrid) with 12k and 15K in 98027. Thank you!
    2.85% APR
    52% residual
    edited March 2024
    Thank you! And residual on 12K? I presume 55%?
    +2% from 15K to 12K
    Sorry - so can I get confirmation that the residual on a Reserve III (non hybrid) for 36 mos 12k is 54%? I have a dealer trying to tell me it's 52%. Thanks!
    52% is the 15K residual, which is the default for the computer system.
    Likely a simple misunderstanding; once they adjust for the 12k mileage, the correct number will appear.
    Either way, the dealer cannot alter the residual; it's set by the bank.
  • 814Pilot814Pilot Member Posts: 2
    Looking at leasing a 2024 Reserve III Hybrid with a $70,600 MSRP. They quoted me a $901 monthly payment after trading in my vehicle for $9500. Okay lease deal? 16066 zip
    Sorry, we don't know what they sell for.
    You can compare you selling price to Edmunds research via the Price Checker link, below.
    I’m not purchasing the vehicle I’m checking on the lease they wrote me for
    Can't calculate a lease payment without knowing the selling price and/or the adjusted CAP cost.
  • Phil111Phil111 Member Posts: 25
    HELLO! Could I please get the MF and RV for 2024 NAUTILUS PREMIER II
    Incentives?
    Zip: 89144
    Thank You!
    Incentives?
    Zip: 89144
    Thank You!
    2.85% APR and 57% RV
    Thanks for the previous Information! Forgot to ask for the 2024 Nautilus Reserve II, Can you please provide the same below?
    Incentives?
    Zip: 89144
    Greatly Appreciated!
    Incentives?
    Zip: 89144
    54% residual is the only difference
    Do you have the April lease numbers yet? Reserve hybrid 36 and 39 months, 12k miles for 01030
  • FyzzlFyzzl Member Posts: 4
    Hi! Could I please get the April MF and RV for 2024 NAUTILUS PREMIER 36/12 for 44133
    2.00% APR and 52% residual
    2.25% APR and 50% residual
    2.00% APR
    55% residual
  • rtarmolrtarmol Member Posts: 33
    Could I please get the current MF and RV for 2024 Nautilus Premiere I ($54,510). 36/10500 and 36/7500
    and for Premiere II ($60,085) 36/10500 and 36/7500 In Zip 01001
    36/10.5
    2.00% APR
    56% residual
    For All Premiere trim
