Visitor Agreement.
I spoke to a Quaker State Rep and he told me directly that their SL does have some synthetic in it. He also said that it was not as high as the synthetic blends.
I have found this information.
Specially formulated for higher mileage engines
Valvoline's MaxLife motor oil is designed specifically for higher mileage engines with over 75,000 miles. Higher mileage engines may perform differently than newer ones - engines lose compression, gaskets become brittle, rings wear and valves do not seal tightly. This contributes to increased oil consumption, reduced gas mileage, decreased engine performance and a more rapid oil breakdown. MaxLife is safe for new and rebuilt engines.
MaxLife:
Helps condition seals and prevent leaks
Helps reduce oil consumption
Helps reduce deposit formation
Helps provide easier cold starts
and These Faqs
FAQ
Are there advantages to using this oil in a car with less than 75,000 miles?
Yes. MaxLife will not harm a car with less than 75,000 miles and will begin the preventative stages to help preserve the life of your vehicle's engine.
Is MaxLife motor oil a synthetic product?
No. MaxLife is made with premium base oils and special components to help slow the aging process of a vehicle's engine.
Can you alternate this product with conventional oil and still get the same results?
No. While it will not harm your car to switch back and forth, we do not recommend interchanging between MaxLife and All-Climate if you want to experience the full benefits of MaxLife.
Where is MaxLife available?
MaxLife is at all major automotive retailers and mass merchandisers nationwide.
Product Specs
MaxLife is formulated with extra anti-wear additives to exceed the engine protection requirements of ILSAC GF-1, GF-2, and API SJ, SH, SG standards, is safe for use in new and rebuilt engines, and will not void new car warranties.
What is this stuff?
Once again, we descend into the depths of the definitions of exactly what is a 'synthetic' oil.
There is no real answer ... at least not from the manufacturers.
Valvoline Max-Life is Group III hydrocracked stocks ... but they only call their group IV oil (PAO - Synpower) 'synthetic'.
Castrol Syntec is Group III as well ... but they call theirs synthetic. Many of the newer SL grades are using some hydrocracked/isodewaxed/isomerized crude oil and by some definitions these (Group II, IIa, etc ...) are synthetic.
I find the statement that the "reformulated SL oils are synthetic blends, to an extent" to be a very fair generalization ... but that's it, it's just a generalization. They are all using at least Group II base stocks ... in varying amounts. That's why they are claiming better mileage on most of the containers.
--- Bror Jace
The dealers people are high school graduates. Toyota employees Mechanical Engineers to reccomend oil changes.
5w30 is prefeered but I have been using 10w30 because we get some hot summers .
Questions: Can I change to synthetic now ? Can I use 5w30 even though we get a few 95-100 degree days .
Have you checked your engine for sludge? Have you read the posts in the sludge thread?
I was wondering if I could I drive it uptown maybe four (4) miles to get the oil changed or should I do the oil change myself before even starting the vehicle?
I know a guy who used to add a quart of tranny fluid to the engine oil as a heavy detergent. He would put it in, drive a 100 or so miles and then change it. This was not his regular practice, just something he did to a car he bought that had high mileage and a suspect maintenance history.
I should mention that it was only maybe 2/10th of a quart I put in before realizing what I had done.
Then again, I'm not a chemist, or even very knowledgeable in the matter.
I'd almost be tempted to ignore it and leave my oil alone until the next change.
Oil consumption on an engine run under severe conditions was reduced by an average of 25%. At least 3 of the 7 engines had a 15% reduction.
Average deposit reduction about 8.5, average wtih conventional oil 7.6. The tech support didn't know what this meant on a percentage basis.
Softening of seals that were hardened in a lab. Improved from 1--5%
The Oil thickening test was significant. An engine running under stress conditions generally thickened 250% in about 75 hours. The Maxlife run over the same interval thickened only 50%
You can email Valvoline from their site at www.valvoline.com and request the same document that I got just by asking for the specifications of Maxlife Oil.
In the letter they also said some interesting comments.
If you do have an older engine, may be better to go with the Max-Life oil rather than synthetic, as long as it is a gasoline engine. The synthetic oil may increase your chances for a leak or oil consumption.
Also Recommend staying with original manufacturer's guideline for oil drain intervals
I contacted Tech support at 1-800-354-8957. They indicated that the seal protection was for small leaks. It wouldn't stop any thing significant. Synthetic has nothing to block small leaks, and runs out easier. They also verified that it was a Class III hydrocracked base stock.
I have a car with small camshaft leak. I'm going to give it a try at the next oil change. It doesn't cost any more than the synthetic blend I now use, and might help me delay a fairly expensive repair for a while.
I have switched my '89 S-10 pickup to the Max Life as of my last oil change, which was 2300 miles ago. Previously, I had used regular Valvoline 5W-30.
I have only owned the truck since 7/16/01, and I know nothing about the history of it prior to my purchase. The truck had 134,502 miles on it when I bought it.
The engine is the 2.8 V6, and I have a five speed manual transmission.
So far, I have seen no difference in oil consumption (has used about half a quart in the 2300 miles since the oil change, which is the same rate as before the switch), cold start engine noise (didn't make much noise anyway), or leaking (doesn't have any).
At this point, all I can say is that it hasn't hurt anything. Whether I'm doing the engine any good by using this product is a question that will be very tough to answer. Whatever service I get out of that old engine, how will I know what it would have done if I had stayed with the regular Valvoline that I was using before?
The truck now has 141,935 miles on it. It has sure been a great little truck for the 7400 miles that I have owned it.
I'll let you guys know every once in a while how things are going.
tom
The difference in the Sludging test was amazing, and if I can get it for half the price of Castrol Syntec
Distilling base oils
Lubricant base oils are made from the higher boiling fraction of crude oil which remains after removal of the lighter fractions (fuels such as diesel and gasoline). Components that would reduce the thermal and oxidative stability of a lubricant are removed, along with wax, which would cause a lubricant to solidify at low temperatures.
Hydrocracking - a different method
A different approach to obtaining lubricant base oils from crude oil uses a chemical process known as hydrocracking. The process reacts a crude oil fraction with hydrogen to break up many of the molecules. This removes the unwanted molecules and reduces the wax content. Base oils produced in this way are intermediate in performance between conventionally refined base oils and synthetic base oils.
Creating synthetic stock
Synthetic base fluid is manufactured chemically to possess superior viscosity characteristics at low temperatures, improved thermal and oxidative stability, and reduced volatility. Synthetic stock is created in the laboratory from small molecules which are reacted together to produce bigger "pure" molecules. As a result, the molecular structure of the lubricant can be precisely arranged to meet specific thermal or physical requirements and often exceed manufacturers' criteria for high performance engines.
Notice they don't say that they start with crude oil and merely refine it more carefully to make their 'synthetic'?
>;^D
--- Bror Jace
For the record, the newest of the three (all Honda/Acuras) has 70,000 miles on the odometer.
--- Bror Jace
tom
--- Bror Jace
I had forgotten, but, just 1 month before the oil change I replaced the aluminium valve cover and put in a new gasket.
The Universal averages are in parenthesis.
Aluminum: 14 (5)
Chromium: 2 (6)
Iron: 37 (39)
Copper: 31 (15)
Lead: 12 (9)
Tin: 1 (1)
Molybdenum: 4 (9)
Nickel: 1 (1)
Manganese: 18 (0)
Silver: 0 (0)
Titanium: 0 (0)
Vanadium: 0 (0)
Boron: 20 (21)
Silicon: 28 (12)
Sodium: 91 (190)
Calcium: 1564 (774)
Magnesium: 684 (604)
Phosphorous: 1049 (824)
Zinc: 1132 (942)
Barium: 1 (9)
Flash Point: 395
Fuel: <0.5%
Sustained viscosity @210 63.4
Antifreeze: ?%
Water: 0.0%
Insolubles: 0.5%
They added this comment. Silicon and sodium can show anti-freeze in the oil, depending on the type coolant and oil in use. If that is the source in this sample, it probably would not be enough to harm the engine. No moisture found and this oil does not appear to be moisture damaged. copper could from bronze or brass engine parts, but could be an oil additive. Aluminium, common to pistons, was high, reading near three times normal. It is possible to have a contamination problem at the upper end where little gets down into the used oil. TBN was 3.5.
My questions:
Could the installation of the new Valve Cover be the cause of the increase in Aluminium and Silicon? The air filter was clean after 3,000 miles.
What is TBN, and is 3.5 good or bad?
Assuming that the copper is caused by engine wear what can be done to minimize it?
TBN is an indicator of the ability of the oil to continue functioning and deal with acid build up. 3.5 may be okay, depends what the oil was to begin with. Rule of thumb is that the oil starts to lose its value when the TBN becomes less then 50% of new oil or 2 or lower. So in your case at 3.5 it is okay. Synthetics start around 10-12 TBN but the blends are probably lower and I cannot help you there. In some engines higher copper may be normal other it could be iron, it depends on each engine and the metals used in construction. You have 170,000 miles on this engine, if you asssume that these results are normal for this engine there is nothing to worry about. Too bad there was no sample from 50,000 miles or 75,000 etc. Then we could see if more wear is occuring. remember, zero wear is impossible
The new valve cover could most definitely contribute to both the high aluminum and silicon. It is very common for a little anti-freeze to get into the oil when a valve cover is changed.
When asked about the excessive copper, he said, "if there is any metal you want to be high, it's copper. Copper is quite high in the brand of oil I was using, Quaker State.
They also said that a synthetic has a normal TBN of 10, and conventional oil generally has a TBN of 4. So 3.5 was well within normal tolerances. If conventional is below 2 then the acids are too high.
Unfortunately when my timing belt was changed for the first time at 90,000 they didn't tell me that cam and crankshaft seals should have also been replaced as a maintenence item. Now at 119K I have a very small leak. Visible, but no appreciable lowering of oil levels like before my valve cover seal was replaced last summer.
Am thinking of mixing one quart of Valvoline Synpower with 3 quarts of Maxlife.
Any thoughts on this?
I have Mobil 1 10W-30 in my 2001 Jeep Wrangler Sport. The oil has turned very, very dark after several months. Is this normal? The engine only has about 3500 miles on it since the last oil change, but a lot of time has gone by (I think about six months).
I was drving the Jeep daily to work, which is a 27 mile drive one way. Since almost all of my miles are highway miles, I was going with 5K intervals and Mobil 1 oil.
In mid July, I bought an '89 S-10 pickup to drive to work, and the Jeep now gets very few miles put on it. It sits in the garage up to two weeks at a time without even being started. I try to pick a dry day so it won't get dirty and drive it to work one day a week, but if there is a lot of rain, I may skip a week.
OK, I know it's a Jeep and I shouldn't be afraid to get it dirty, but if I have a choice two vechicles to drive to work, and one is clean and the other dirty, I drive the dirty one when the roads are wet.
The question is, should I be concerned about the dark color of the oil? (it is black) Apparently it is just the time factor causing the dark color, since I have only put about 3500 miles on that oil.
When you guys go 7K or 10K on your intervals, is your oil real dark after a few months?
Really would appreciate hearing from some of you.
tom
My Toyota truck gets dark oil after about 6-8K. Thats when I change (That works out to be about 10 months worth. My Sentra which now has 13K on it has had the oil changed 9K ago and is still a nice noney color. Thats been 8 months. It has however had 2 filter changes on this oil. Perhaps you could throw another filter on and see if that helps.
That's my experience.
I think the fact that it sits so much without being started may have something to do with the oil darkening. Think it could?
To be safe, I'll just go ahead and have it changed. I'll shorten the interval next time, or at least check the color more often to see when it gets dark.
I still hope this does not indicate that I have let it go too long. Maybe the dark color doesn't matter, but it bothers me.
tom
If it sits a long time, it may be building up more moisture than it can burn off. Just a WILD guess.
Also, if you can find an ace Jeep mechanic at your dealer, he may know why this particular vehicle has the attribute of oil turning dark quickly.
I sure hope that I have not done any damage to that new Jeep! I'm still clinging to the hope that the dark color does not really indicate a problem, but to know for sure, I think the analysis would be the way to go.
I might also contact Mobil and see what they have to say.
tom
One thing to check. Your antifreeze-make sure it isn't leaking into your oil. An oil analysis could tell you that.
How dark does your oil ever get between changes? Mine is virtually black now.
I see no foamy or creamy stuff on the dipstick. If coolant were getting into the oil, I would see something like that, right?
I have emailed Mobil with a question about oil color. There is also an 800 number, but I'll bet that no one answers after hours or on weekends. I guess I could try, but it will probably be Monday before I can reach anyone there.
Thanks again.
tom
Thx
Yes, I have the 4.0 L engine. The Jeep is a 2001 Wrangler Sport with currently 13,500 miles on it.
The oil was last changed at 10,000 miles, but because I have a work truck now and the Jeep is not driven daily, I have only put 3500 miles on the Jeep in the last six months.
I love that Jeep and plan on keeping her many years. That's why I want to use the right oil and the right change interval. I am convinced that the Mobil 1 is the right oil, but under the current set of circumstances, I am not sure what change interval is apporpriate.
The Jeep still sees mainly highway driving, but it may sit up to two weeks without even being started. When I do start her, it's usually to drive her to work, and that is 27 miles one way of highway driving.
Thanks again!
tom
tom
