The more I read analysis results from various posters, the more happy I become that I have continued to do 3K oil and filter changes. I don't analyze my oil, and my periodicity is likely very safe for my various engines.
Americanflag: I have seen your post in various forms in several forums. Consider this posting my reply to you also! (:o]
American flag, I would go qith 3000 every 3months in the winter months due to your very short trips. Engine doesn't heat up and will not burn off contaminants. You may see a milky white residue on dipstick if moisture is building up. Suggest taking the long way home every other day from work.
She doesn't believe me when I tell her the risks with not getting the engine hot enough. Is there a article, web site or a analysis available somewhere that I can show her that can give her a professionals point of view?
Thanks, all, for your help
Fleetwood, I have a pretty boring life, but I am learning alot about cars, appreciate the help!
So now I do 3 things. Change oil under the severe service schedule, emphasizing the recommended TIME, not distance. I make sure to take at least a 50 mile trip once a month, especially in cold weather. Take a long trip at least once a year of 250 miles or more. (The engine always runs quieter after the longer trip anyway)
My current short trip vehicle following this formula has got over 175K now.
I know about multi-vis oil and how it works but all the sudden I am questioning my knowledge of what should be basic info...
Take 15w40 as an example.
Does that mean that when cold the oil will only thicken to a 40 weight and when it warms it will flow like a 15 weight? Or is it like a 15 weight when cold and flows like a 40 weight when it warms up. I believe it is the first scenario but I am deferring to the group to set me straight.
Thanx!
R. J.
you can buy 5w30 here for 98c a quart.
Ken
Related question-- What color is Shell? Since the PZ/QS buyout, Havoline is being shifted from Shell (Equilon) to Chevron. What's taking its place? The company announced that they were closing the Shreveport blending plant that made the SuperTech oils, one of my assumptions was that ST would be shifted to take up Equilon plant capacity.
I just put ST 5W30 in for the winter. Looks a lot lighter than the 10W30 did. Almost like Pennzoil. Although Pennzoil is the best of the Equilon/PZ/QS stuff IMHO, I'm not crazy about really light oil since it's hard to read on a dip stick until it darkens up a bit. This is probably a normal variation between 10W30 and 5W30 since I doubt if the Shreveport blending plant is closed yet, but the difference in color is noticible. Think I'll pose this question to Johnny on Bob's page...
Incidently, the vehicle now has 21k miles - all dino oil drains. Can/should I switch at this time to syn. And if so, which one? Thanks, all, for your help.
At 2400 miles, the bulk oil my dealer used was down to 20w from 30w. The Chevron was down to 5w from 30w at 3900 miles. So it looks like I'll try the next change at 3k and see how it tests.
This engine is also putting a lot of lead into the oil but the amount with the latest analysis is much lower than the original test. The amount is still high though...so much so the lab ran a second test to verify the result. Hopefully it is just bearings getting seated...but at approx 13k miles I would have thought it would be broken in by now.
The Chevron oil still had reserve additives and at 3.9k the TBN was 4.5. The Bulk Pennzoil had a TBN of .5 at 2.4k. I'm going to stick with the Chevron but I'd recommend anyone with this engine to err on the safe side by using short change intervals.
All things considered, the Highlander is a beautiful vehicle and am very happy with it, obviously I want to keep it a long time. Nonetheless, unless I hear otherwise, I'm sticking to my 3500 mile oil changes and hoping for the best - but I sure would like to know what other Highlander/Toyota owners are doing. Pdalspher - very much appreciate your post and any future analysis - THX
I really believe that dino. oil is all you need in most engines, but this might be the case for a synthetic.
Question for you, how the castrol gtx 5w30 compares to other 5w30 ? (dino juice only )
Can you give me your 5 w 30 top ten ?
If you can resist dont tell me story about your old uncle or the I've heard a guy....let stick to the fact , data sheet etc.
I'm driving a Pontiac Montana 2002 3.4 not versatrack and I dont tow if that matters.I'm using AC filters PF47.
Thanks a millions of time
Richard
The data from the the various oil analysis reported on this site indicate that the Nissan engine takes a long time to break in, i.e.: 10,000 miles. Now a Nissan engine isn't a Honda, I know. But there may be a good reason why the manufacturer recommends a long break-in. Most don't. So when one actually does, you may want to pay attention.
BRAVEUX: If you read thru the above mentioned oil analysis spreadsheet at the Maxima site, you'll also see some fairly convincing data supporting Castrol GTX dino when is has been changed at modest intervals, if that's your favorite brew. The forums at BOBISTHEOILGUY also report various oil analysis. There have been some good showings for Castrol dino there too. Other facts about Castrol are hard to come by as that comapany does not make data specifications on its oil readily available for some strange reason. On the back of the quart container however, it does state that the 5w30 meets the ACEC A1-98 standard, which few other 5W30 dinos are able to match. It also says this is oil for sale in the USA. Not sure about Canada.
Other top 10? I suspect there are as many top 10 oil lists as there are people you ask.
I was just wondering if as many of you are still using the Chevron, and if so, what do you think of it?
Overall, I still have a high opinion of the Chevron Supreme. On one of these Town Hall forums, tntitan has posted the results of an oil analysis done on a sample of used Chevron Supreme from one of his vehicles. You may want to search around for it.
Any thoughts.
