Visitor Agreement.
I don't believe that's true.
However that single weight oil should be used for your lawn mower and other small motors that are air cooled. It will protect them better than multigrades will do.
If indeed your oil consumption would be 3/5 of a quart over 3,600 miles, that isn't even worth worrying about.
The manual for my Toro didn't mention needing to use or recommending to use synthetic. I'll see what I can look up.
use a high quality detergent oil classified "For Service SF, SG, SHSJ" or higher, such as Briggs & Stratton SAE 30, Part Number 100005....
However they show a chart with temps below 40 deg. F. suggesting 10W-30 and 5W-30; above 40 deg. F., 30.
There is a box saying SJ/CF synthetic oil is an acceptable at all temperatures and shows 10W-30 and 5W-30. It does not say preferred neither does it say suggested for synthetic. It does say acceptable at any temperature.
This was the first BS motor manual I could come up with. I can give the URL if you need. If you like synthetic have at it. But they're not saying it's preferred.
http://shop.briggsandstratton.com/BShopProductPage.asp?CatalogID=56B2B9AF-283C-1- 1D4-8886-00B0D0203414&MECID=100&SessionID=9F2DA7EB-3494-42B5-A871-296DD16086C3&C- ategoryID=&lrid=&ProductID=86A671AC-176E-4669-845A-642F2689A011#
The site did note that below 40 deg F the use of 30W was possibly able to cause more wear in cylinder. But how many of us mow our grass under 50 and 60 degrees. I may use 5W30 in early and late mowing. But the straight weight does not break down viscosity-wise at higher than normal wall temps due to less cooling on air air-cooled motor like 10W-30, will due to the viscosity change molecules. In your auto the motor is water-cooled and the walls don't go above a certain temp, higher than 225 but the temperature increase is limited by the water cooling, else the water starts boiling.
In an air-cooled motor the wall temperature can increase drastically on a 100 deg day when you're mowing that 7 inch grass from the rains last week. So the solid molecular structure of the 30W is preferred for the durability it has.
It's not how much oil is used. It's whether the oil keeps a high enough viscosity to protect the walls and the rings.
On a mower who cares, they are of little value. My last one went 18 yrs, too long.
you must think it's overkill to do that many huh?
well... i'd certainly would like to think that i've gotten rid of about 90% of all the 'metal shavings' off of a brand new engine. Peace of mind you might say..
One always hope to pick up the occasional piece of grit that might be left over from the assembly process but the oil filter should catch that right from the get-go on the first few hundred miles.
It was just discussed in our newspaper this morning.
A recent immigrant brings his car for oil change. He repeats it the next day, and the following day again. The service adviser asks, why he does it?
- Well, I work across a street from your station. I just got a job. I work hard on the new job. My English is bad. I can leave my car at your service station in the morning and to pick it up after work. The only parking I know nearby is more expensive than changing my oil. I had no time to look for a inexpensive parking.
Krzys
Best Regards,
Shipo
P.S.
I am joking by the way.
Are synthetics known to be higher detergents?
To that question at least, I can offer an answer. Yes! As true synthetic oils are more stable by their very nature (i.e. their viscosity isn't as temperature sensitive*), the manufacturer can add more detergents per unit of oil and still leave LOTS of extra room in the formulation to hold engine contaminants in suspension.
* Apparently Mobil now has a version of Mobil 1 that is effectively a "straight weight" 40 weight oil (i.e. an oil with zero viscosity enhancers) that exhibits 0 weight cold pour properties. Said another way, that particular oil can be called both S.A.E. 40 and 0W-40 with equal correctness.
Best Regards,
Shipo
1. Transmission fluid.
2. Brake Fluid.
3. Power steering fluid.
4. Coolant etc
Hence the engine is outlasting everything else and people trade in their cars (with pristine synthetic maintained engines) the moment their transmissions start slipping (dark burnt fluid - tranny toast) :sick: etc.. you get the idea.
A bit of trivia:
My family moved to the Detroit suburb of Bloomfield Hills in 1969 and as such I attended my last six years of school and rubbed shoulders with LOTS of kids who's parents were engineers for the "Autos" (as they were collectively known), not to mention the kids of more than a few sports luminaries (the children of Al Kaline and Gordie Howe to name two, yeah, yeah, yeah, I know, "Name Dropper!"). A guy I knew (I won't call him a friend, long story) whose father was an engineer with GM was working on their Wankel engines (specifically the 4-Rotor unit earmarked for mid-engined Corvette prototype). As the story goes, GM had a heck of a time developing an Apex Seal that would last the life of the car. Eventually they happened upon a formulation for the seal that was estimated to be good for at least a million miles; the only problem was that the twelve seals that would be required for the 4-Rotor engine would have cost more than the entire rest of the car.
Best Regards,
Shipo
Brake fluid: 24 months.
Best Regards,
Shipo
1) I've never seen a recommendation to replace the PS fluid from any manufacturer (although admittedly I haven't looked real hard to find such recommendations either)
2) Over the years I've wrenched on hundreds of cars and have yet to see one that has had a P.S. failure that was old fluid related. Does that mean that this type of failure isn't possible? Nope.
The flip side of the above is that if your fluid is indeed "burnt" smelling, it might could well be worth a change.
I hope this helps. ;-)
Best Regards,
Shipo
There aren't really 'metals' in the oil from a new engine, of course, more like debris or very minute particles as Shiftright said, im just using the coined phrase of 'metal shavings' to describe any grits/debris/minute particles or what not...
POWER STEERING--it's always been my understanding that the reason to change PS fluid was not because the oil broke down, but just to eliminate dirt particles that might foul up the valving in the hydraulic ram.
My point? If there is one, it is that p.s. fluid does deteriorate. I suggest that what; maybe every 50K miles would be a good interval? Anyway, never say never about changing power steering fluid.
By the way, I did the change by dilution: I pumped the reservoir fluid out and replaced it with the new, which then mixed with the system fluid. Again, I repeated the procedure of dilution about two years later and the power steering unit got even better. I may need to do it again, due to the sounds reappearing in cold weather now.
Does the Mobil 1 ATF make good power steering fluid? Will it serve as long as a usual PS fluid - way longer than "every oil change"?
Even Honda makes a lot of noise in their owner's manual about using Honda-spec'd fluids.
You are absoltely correct. The only reason I mentioned M1 ATF is because the E36 Bimmers use ATF. My 1999 Wrangler only gets Mopar PS fluid.
My Infiniti dealer was using Castrol across the board to service all customer vehicles. They abruptly changed to Mobil. This is not synthetic, remember. Would you be concerned?
Change intervals are 3750 miles according to the manual.
It reminds of Coke and Pepsi, restaurants switch when they get a better deal.
Last I knew GM Goodwrench oil is Mobil.
