Visitor Agreement.
For the record I use Valvoline and Pennzoil.
While I have heard a few negative comments on both, they seem to be two of the most popular motor oils used.
As for Pennzoil and Valvoline being two of the most popular oils, yeah, I suppose, especially since as I understand it, Pennzoil owns Jiffy Boob. That said, I've not seen any compelling evidence in recent years that would convince me to start using oil from either brand, regardless of cost.
My personal rules for engine oil are as follows:
- Regular use cars: Mobil 1 0W-40 or Castrol Syntec 0W-30*
- Occasional use cars that don't require synthetic oil (I don't currently own any car that meets this criteria): Havoline 5W-30
- Air cooled "Boxer Six" spark ignition light aircraft engine: AeroShell W100 Plus (conventional oil)
- Water cooled I4 compression ignition light aircraft engine: AeroShell Diesel 10W-40 (synthetic oil)
- Air cooled home and lawn engines (i.e. lawn mower, garden tractor, snow thrower and household generator): Havoline 5W-30
*In the unlikely event that I get seduced by the power of something like a Chrysler Hemi, then I'd use Mobil 1 0W-20.
Best Regards,
Shipo
I use a 30 weight oil for the lawn mower. The mechanic at the Toro garage explained that 10W-30 is rated for temperatures reached in the controlled environs of the autoengine with a water-cooled jacket around it limiting temperatures. He stated that the temperature in an air-cooled product can go higher and the multiviscosity oils break down to a lower relative hot viscosity rating than do the single molecule rating oil like a 30.
So I bought a case of Shell 30 weight when on sale.
By the way, it used to be true that multiviscosity oils would break down from the heat of an air cooled engine run on a hot summer day, but that hasn't been the case for MANY years. Modern multi-weight oils are more than a match for a year's worth of operations, and then some.
Best Regards,
Shipo
Compelling evidence? I've never seen/read anything to indicate one oil is better than another...other than peoples personal opinion on the matter. Why put in the more expensive $2.50 a quart oil, whose higher price is more a reflection on recouping advertising costs... than the $1.75 oil which meets the same specifications?
You haven't? :confuse: Then apparently you haven't looked. Go and check out the VOA and UOA databases on the BITOG web site. There you will see a huge amount of evidence suggesting that (as a general rule), more expensive oils protect better and/or last longer than cheaper oils. This isn't to say that an oil that costs $1.85 won't protect better and/or last longer than an oil that costs $1.99, however, the data there will absolutely prove that oil that costs $5.00 per quart will be significantly more robust than oils costing half that much.
Best Regards,
Shipo
If modern multi's can survive the air cooled mower in our hot summers, then it should be just fine in a water cooled motor?
Currently M1 5-30 in a B&S motor. Blue smoke on start up. Think I may use the 30w bottle of B&S that came with it.
Was it in the 80's or 90's that Mobil1 would send out the one million mile bmw race track run brochure with the end result that the specs on the motor would pass the new build tolerances. 0w40 mobil 1 in our crd would produce liquid and tar and was cleaned where possible with simple green. High noack numbers and yet doubt the 40w designation. Last fill was with redline 15-40 diesel-should've used it from day one (after a break in with shell oil)and not trust dcx and 0w40.
Not trying to be a forum hog-and butting in to an old discussion-but seriously looking for a comfortable oil for both our vehicles that we love.
Vacillating from redline (poe issues at bitog) to amsoil xl [(star burst for warranty reasons) expensive groupiii?] to regular oil and even to stay with mobil1 jugs unless the price goes up.
As for Mobil 1 in your CRD, I wasn't aware that Mobil 1 0W-40 was certified for that engine. I could be wrong, however, as I've never researched that oil for Diesel applications. That said, Mobil does market at least one Mobil 1 offering made specifically for Diesels (IIRC it's a 5W-40), and it is available at Wally World amough other places.
Regarding your comments of high Noack numbers, ummmm, maybe I missed it, however, I've never seen any credible evidence to suggest that the 0W-40 Noack was at all out of line with European car standards, and as such, fairly low.
Best Regards,
Shipo
How does Quaker State(regular) shape up? I have used it in my cars for many years.
Do those makes of oil still cause the same paraffin related issues? Don't know, don't care. They stiffed me and my customers so badly once that I've never willingly used any of their products again. Biased? Yup, you bet. Short changing myself by eliminating potentially good products? Yup again. Do I care? Nope. The Mobil 1 that I've been using since the early 1980s has proven itself so capable and my engines have worn so slowly that the car itself will become toast long before any significant work on the engine mechanicals was/will be required.
Best Regards,
Shipo
Same reason that I'll only use conventional oil in a conventional (i.e. air cooled boxer style spark ignition) limited use aircraft engine, rust. There are three main reasons why limited use engines with synthetic oil in the sump are more susceptable to rust than the same engine with conventional oil in the sump:
1) Given the superior flow properties of synthetic oils, they tend to flow off internal engine components and back into the sump given enough time, thus leaving said components exposed to the water that naturally condenses and collects inside of non "pickled" engines.
2) Given the superior stability of synthetic oils, varnish is far less likely to form, varnish that tends to coat inner surfaces that don't see lots of contact, areas such as cylinder walls below the lowest point where the oil control rings reach.
3) (Or maybe better said; 2b): Given the superior cleaning abilities of synthetic oils, any varnishes that do happen to form (or were formed by previous conventional oil usage) are likely to be washed away (gradually in the case of pre-existing varnish), thus exposing engine innards to potential rust formation.
While the above issues aren't talked much about in small engine circles (no surprise, toast your lawn mower and what's the worst that can happen? you have to spend a couple of hundred bucks to buy another), however, back in the 1980s Mobil marketed a product called Mobil AV-1. That oil was a fully synthetic oil tailored specifically for the aircooled boxer engines in the General Aviation fleet, and was supposed to be the greatest thing since the integration of the tricycle landing gear for pilots. Funny thing though, a few years and a few hundred operational hours after adoption of Mobil AV-1 into the fleet at large, and airplanes started dropping out of the sky. Literally.
All of the sudden the order of magnitude of the problem went through the ceiling. No longer was this a couple hundred dollar problem, it was tens of thousands of dollars and human lives that were impacted. Needless to say, it became a much talked about issue within aviation circles. To be fair, the rust or corrosion issues were only part of the problem (I don't mean to minimize the impact here), as many heavily used engines were experiencing problems with lead fouling of the rings and valves (unlike conventional oil, synthetic oil in incapable of holding lead in suspension). It's just that it was the occasional use engines that suffered the worst impact, internal corrosion AND lead fouling.
To this day, I continue to use conventional oil in my occasional use engines.
Best Regards,
Shipo
In the case of my engines, my garden tractor and my generator both have fully pressurized oiling systems, complete with oil filters. My lawn mower has a pressurized oiling system (I think) sans oil filter while my snow blower uses a dipper/splasher method for oiling. In each case, I simply fire them up once per month (during their respective off-seasons) and get'um good and hot.
Best Regards,
Shipo
mobil 1 double digit noack, amsoil lower/better, and redline poe with a 6. Turbo blow by even by domestic diesels until the return to 15w40. Maybe the new 5w40 diesel can keep the turbo from becoming an oil pump.
FWIW, per the Mobil 1 web site, Mobil 1 Turbo Diesel Truck 5W-40 is the correct oil for your CRD, not 0W-40.
http://www.mobiloil.com/USA-English/MotorOil/Oils/Mobil_1_Turbo_Diesel_Truck_5W-- 40.aspx
http://www.mobil.com/USA-English/Lubes/PDS/GLXXENPVLMOMobil1_Turbo_Diesel_Truck_- 5W-40.asp
Best Regards,
Shipo
Stopped by the hummer dealer to see if all 3.5 motors (bought an extra drain plug from a chevy dealer last year) were now using one with a magnet (yes). Talked to a very good mechanic. Saw an h3 getting its' 30k service, and goodwrench (mobil dino) going in. Goodwrench with 3k changes-but he did say that when customers don't bring it in at 3k some nasty stuff comes out. What's with these long oil changes and oil monitors.
Just one question - believe first sl or sm oil was so slimy that i could wipe and wipe couldn't get the slickness? off my fingers. New mobil 1 - one wipe on a paper towel and can feel the ridges on my finger tips.
The real question is, did you shut down the engine immediately or kept running it? If so, the cost factor just took a huge leap upward.
I replaced a blown motor in my car about 2 months ago... and noticed the rear seal started leaking about 3 wks ago... I have a warranty on the motor for the next month... I had a personal friend install it for me and I know that it would cost me a fortune to get the motor pulled out and a new one reinstalled... The leak is very minor but enough to drip about 3-4 drops per 6 hrs or so... I was doing some research and came across several stop oil leak treatments... just wondering if it would work and if it's alright for a motor?
This is in a 95 geo prizm and the new motor has about 100k on it while the car has bout 145k on it... :confuse:
FWIW, even on cars that have the oil filter located underneath the engine, I still use the oil extractor for the oil in the pan, it's just that much easier to use.
As for availability, just query "Pela Oil Extractor" on your favorite search engine, you'll get lots of hits.
Best Regards,
Shipo
- Engine temperature gauges in recent years have become nothing more than glorified idiot lights (much thanks to the ODB-II standards). Said another way, they show cold when the engine is cold, they show normal when the engine is anywhere in the operational range, and they show hot (usually when it's already too late) when the engine is overheating.
- Just because your engine (coolant) temperature gauge is within an acceptable operational range doesn't mean your oil is. Up here in New England, the odds are pretty good that the oil in the pan of our cars stabilizes somewhere around 150 degrees on a sub-zero day while down there in Texas, the chances are high that the oil in many of y'alls cars and trucks stabilizes somewhere over 200 degrees.
- If your Owner's Manual doesn't specify synthetic oil then all recommendations are for conventional oil. Were I in your shoes I'd move to synthetic oil and enjoy the 7,500 mile OCIs that your car is supposed to have. ;-)
Best Regards,
Shipo
...and of course were the dealer here (WI) he'd say 3750 mi, because it's cold in winter.
The manuals usually have two schedules and should say under what conditions you should follow the shorter OCI. Some are more clear than others in specifying those conditions...but, the interpretation of this only really matters much, if you are under warranty.
the dealership and Cadillac confirm the car is new. The question is should I change the oil on the basis of time in the car. The oil life monitor says 87% oil life left as of today. The odometer now has about 400 miles on it. I am told that the Cadillac oil monitoring system is very dependable and can be relied on. Any knowledge on this issue or direct experience will be appreciated.
First of all, you can do a cylinder leakdown test. This should spot any serious cylinder head or ring damage.
If the oil pump gave up, then yes...once you lose oil pressure generally your crankshaft and bearings are toast.
A bad tensioner should be easily diagnosable because the noise will be all in the front of the engine, in the timing case cover. A bad crankshaft is a very deep loud noise...it's not a clatter...it's the hammers of hell. A KNOCK, not a tap.
If you engine is maintaining oil pressure, and the cylinder leakdown test shows everything tight inside, you might very well have just thrown a chain tensioner or chain guide or belt guide...I don't know what makes Suzukis go 'round and round....
Need an engine mechanic to look at it, and there are a couple basic checks he can do to see if all the pistons are still moving....how much compression you have in each cylinder.....etc. Sounds very serious though.
How many miles are on this engine?
You'll have to figure if this is worth fixing, putting a new engine in, getting a rebuilt if available, getting one from a junkyard rearend total, or rebuilding your original.
Good luck
http://www.mityvac.com/pages/products_fee.asp
Years ago, I bought a model 7400 fluid evacuator. I ordered mine through a J.C. Whitney catalog. I have gotten a lot of good use from this vacuum pump system. You might also find a cheaper type pump at:
http://www.harborfreight.com/
The average automotive oil filter is around 20 microns.
Most heavy truck engines run about 5-20 micron filters.
Another thing that causes more damage than metal shavings is cavitation. People don't realize how damaging air or coolant in the oil system is.
i hope i haven't said, actually(actually is - the plupresent tense of the verb is) or absolutely (yes).
