Visitor Agreement.
Go figure!
keep it between min-max.
but to satisfy the fool-on-the-street while selling your car, top it off to max. Customer satisfaction is No.1
How about when you change your oil and filter you add back the amount of oil specified in your manual! When I do that it puts the oil level right at the full mark on the dipstick.
If the oil level starts to drop, then add more oil. When, maybe half between full and add.
I can't believe this can be that big of a deal. We are debating the merits of ounces of oil! Have you ever seen oil being pumped through an engine? Ounces don't matter.
You could safely fun your engine half low on oil in the short term. A good portion of your oil is always in the pan. The oil capacity is higher than needed to allow for better dispersion of impurities as well as better cooling of the oil.
Don't worry about a quarter of quart low, you're fine.
is it suitable for extended drain intervals and is it formulated with PAO like mobil1 and valvoline? tks
Here's the problem...
My '89 S-10, 2.8 L V6, 2WD truck's owners manual calls for 4.5 quarts of oil when the oil and filter are changed, but when I had the oil changed for the first time since buying the truck, 4.0 quarts brought the oil level up exactly to the full mark even though the filter was also changed.
I didn't have an owners manual at the time the oil was changed, but I thought that it was supposed to get 4.0 quarts, so that's what I had them put in, and, sure enough, the oil level was exactly on the full mark after starting the engine and letting it run to allow the filter to fill up and to check for leaks.
A couple days later, the owners manual that I had ordered came in, and it said that I should have put in 4.5 quarts.
My dipstick does not have a "maximum overfill" line or anything. It simply has a crosshatched area representing the "normal operating range."
After the oil change, the level was exactly at the top of the normal operating range.
I have verified that I have the right dipstick by going to the GM.com web site. They got back to me via email and the part number they quoted for the dipstick matched what was stamped on mine.
Also, I have the proper filter, the AC PF52, which GM says has replaced the PF51 that the owners manual calls for (the PF52 has an anti-drainback valve, which the PF51 did not).
So, do I believe the dipstick or the owners manual?
If I go by the dipstick and use 4.0 quarts, then I could be leaving the crankcase half a quart low, if the owners manual is correct in calling for 4.5 quarts. That would be better than overfilling by half a quart if the dipstick is actually correct and the owners manual is wrong.
Then again, I could use 4.25 quarts, huh? Then I wouldn't be grossly overfilling if it really only should get 4.0 quarts.
tom
One thought you could check a haynes manuel to see what the state as the capacity level
Does anyone know for sure who makes Motorcraft oil? It's distributed by Ford by I know they don't make it.
Thanks for any assistance
To me, this argument seems similar to the claims made by the guy who changes dino oil & filter every 3k miles-- 'my engines have always lasted a long time. It's because I take care of it by changing the oil every 3000 miles.' Of course, most folks on this forum agree that this theory is not sound. What do they say in psychology? Correlation is not causation.
I'm guessing that nobody on this forum has run any tests on the same vehicle in an attempt to determine which dipstick reading results in greater oil consumption (or if there's any difference in consumption at all).
I do agree that running just above the Min mark is unwise for the reason that it's too easy for the level to drop dangerously low. If you're maintaining at a quart below the max and your engine burns another quart, now you're 2 quarts low and that's generally not good.
I may run a mini-test on my 98 Isuzu Trooper to see if the oil consumption rate is any different with the dipstick halfway between Min & Max. It's worth a shot. I typically keep the level at Max. The 3.5L V6 in the Trooper, and its 3.2L predecessor, are well-known to consume quite a bit of oil (1 quart every 1-3k miles) even in newer and well-maintained vehicles. BTW, ours consumes a quart every 2000-2800 miles.
just dont know whether its a true PAO synthetic or it falls in the "castrol" league of things.
with havoline syn prices in the same league as mobil, its cost advantage is lost.
10W-30 Mobil 1 Havoline
pour point (celcius) -54 -51 flash point (celcius) 243 250
viscocity index 147 148
5W-30 Mobil 1 Havoline
pour point (celcius) -54 -54 flash point (celcius) 235 242
viscocity index 162 160
I was going to be sure that the engine was warmed up properly next time so the oil would flow more freely the next time that I have the oil changed.
Someone also pointed out that with the engine warmed up, the dirt should be in suspension better and more likely to drain out with the oil rather than being settled out in the bottom of the pan, only to go back into suspension in the fresh oil after the oil change.
tom
Mark, did you know there's a web site for S-10 owners? I don't remember seeing any posts from you there. It's www.s-series.org. There's a world of stuff there pertaining to S-10's.
I had one car, a Merc where the manual had misleading info on oil quantity. Lube place put in enough to get it to the min alright, after 100 miles the ole red light came on, low oil level. Keep it between the hash marks, I personally keep all 5 of mine near the top. Does the philosophy of keeping fluid near the min mark go for power steering fluid, coolant level, brake fluid and tranny fluid as well. Sorry, I am not willing to take that chance!
In my prior post, I was just trying to point out that none of us has any first-hand experience/evidence to prove lower oil consumption when maintained at the Max mark.
Who knows - it may actually be better for oil consumption if the level is kept below the Max mark, but manufacturers state/imply to keep it at the Max mark because that provides the average consumer (who rarely checks oil level) with additional margin for error.
the Min mark is at approx 3/4" and the Max/full
is approx 2"
this is the reason why i dont mind that my oil
level is not exactly at the max/full mark,
considering the fact that the level falls at
certain scenarios.
You could have done some damage by running that vehicle with the oil level that much over the full mark! It might not be something that would show up right away.
It would bother me to no end, if that had happened to me.
tom
pressure if the oil level is too high.
after 3K miles, i have no problems whatsoever.
i'm scheduled for oil change at 3750mi or 6mos
whichever comes first.
i think that the "idiot factor" comes into play
here where the dealer/mfr assumes that the
customer does not check oil until the scheduled
maintenance. anyways, the car is still under
warranty so the dealer would step to the plate
if anything wrong happens.
If anyone else out there has had a bad experience with it, please post!
Would also like to hear positive comments, if you have had good experience with it.
A few people have been kind enough to express their opinions, but I would love to hear from others too.
I have bought the oil, but I'm not due for the next oil change for another 1500 miles.
tom
Thanks for the thoughts
Ron
Also, most modern enignes do not suggest anything above a 30W so 10W30 would be the max under most conditions. I would not put a 5W50 in a new Ford van!
schedule and check fluids religiously.
Light (thin) oils such as 5 weight have elastomers added that react to elevating temperatures. At engine cold temps, you seem to have no effect, but as the engine warms, the elastomers begin morphing in ways that make the oil the thickness that a bit heavier oil without elastomers would have at that higher temp. This process continues, and at full hot engine temp, the elastomers reach max weight equivalency of the equal heavy oil at THAT temp. Upon cooling, this reverses.
http://www.redlineoil.com/redlineoil/engoilti.htm
“These polymeric thickeners are very large molecules which will suffer from thermal cracking when exposed to high temperatures. When these molecules crack, they reform to create varnish deposits which can stick rings and plug turbo passages. For this reason most turbocharged cars recommend against using wide-range multigrades.”
Looked at how fast their 5W50 degrades on the "Reduced Friction" bar graph after only 5,000 miles.
--- Bror Jace
SAAB says 5/30 10/30 10/40 and 5/40 are all perfectly fine oils, and that 15/40 is ok for summer use. The saab runs pretty hot, so we use the thick stuff.
OTOH, my saturn dealer said anything but 5w30 would endanger the warranty on the engine.
I was looking at the AMSOIL site, and their tests indicate that mobil1 is the WORST oil on their tests of several. That's what i use, and was buying for my service this week! Was their change to tri-syntheitc disasterous, or is marketing likely involved? I was actually planning on using the 15w50.
dave
Although these oils are promoted as "energy conserving" they generally trade a gain of less than 0.1 MPG in Corporate Average Fuel Economy (CAFE) for shorter useful engine life.
FORD which has previously designed cars to have 10 year or 150,000 miles life has reduced the mileage life expectation to "beyond 100,000 miles" on vehicles that are operated on SAE 5W-20 Motor Oil.
HONDA only claims "useful life" as 7-years or 70,000 miles in EPA certifications for their CIVIC which uses SAE 5W-20 Motor Oil, while the previous model that utilized SAE 5W-30 Motor Oil was certified for 10 year or 100,000 mile durability.
Since both HONDA and FORD Warranty their NEW cars for ONLY 3-years or 36,000-miles the reduction in engine life expectancy is not a factor.
By contrast Mercedes-Benz recommends use of ONLY Synthetic Motor Oil that is at least SAE 5W-40! This is a recent increase in recommended viscosity from SAE 5W-30. Apparently customer research indicated that engine longevity is more important to typical MB customer than fuel economy.
Even more important is the High-Shear High-Temperature MINIMUM specification in SAE J300. In tables below you will notice that there are "two" SAE 40 specifications, one with minimum HSHT value of 2.9 cP for Automotive Oils (SAE 0W-40; 5W-40; 10W-40) and the other for Heavy Duty Oils (HDO) (SAE 15W-40; 20W-40; 25W-40; 40).
This double specification is at insistence of heavy duty engine manufacturers who have required HSHT viscosity limits consistent with good engine durability in high-load, severe service operation. HSHT value of 3.7 cP or 27% more viscous oil at 150ºC (300ºF).
Yes, a 27% increase in viscosity makes a difference between Automotive engine that lasts 100,000 miles and Truck engine that lasts 1,000,000 miles!
I may be confused I thought that synthetics were much superior and due to their inherent properties the amount of VI improvers used in a syn are very little to that used in a petroleum additonally some syns like Mobil 1 do not use VI improvers to achieve their objective, for their 5w-30, 10w-30 or 0w-30 qualify, they may use and very little for there 15w-50 same rule applies with amsoil relative to their 10w-40, 20w-50 oils the amount of elastomers used for the spread is small not equal to what is needed in a petro base oil. This is what I've read in some technical journals on the subject of synthetic oils
Then again I may need to see the light, could be totally confused
